[humour]
That should require a mention of Harald Bluetooth, for whom the protocol is named. He was a late 10th century Danish king.
Electrical fuse, not electronic."Polyfuse" - A self-resetting electronic fuse fitted to the Pi board which can help protect your Pi from electrical damage.
Perhaps "mAh, Ah and Wh are units of power capacity commonly used in rechargeable batteries/powerbanks, not to be confused with mA, A or W"W. H. Heydt wrote: ↑Tue Oct 02, 2018 3:31 amI don't *think* you need to add Wh (Watt-hour == energy).
davidcoton wrote: ↑Sat Nov 03, 2018 10:33 am"Poppycock and Balderdash" -- a signal to the mods that a thread needs closing. Works in a matter of hours. The preferred method is to use the "report" icon. See viewtopic.php?f=62&t=226114#p1387472
Unfortunately it often is used that way and you seem to forget the one rule this forum has; "be nice to each other". If you don't have anything good to say it is perhaps better to not say anything at all or have the decency to explain why - in your opinion - something is absurd, claptrap, drivel, hogwash, poppycock and balderdashfruitoftheloom wrote: ↑Sat Nov 03, 2018 10:50 amdavidcoton wrote: ↑Sat Nov 03, 2018 10:33 am"Poppycock and Balderdash" -- a signal to the mods that a thread needs closing. Works in a matter of hours. The preferred method is to use the "report" icon. See viewtopic.php?f=62&t=226114#p1387472
Claptrap
Drivel
Hogwash
It no way is intended to close a thread, it is just easier than writing a diatribe in response to an absurd post !
Yeah...except mAh and Ah *aren't* units of energy, which Wh is. The problem with so many batteries being given mAh/Ah ratings is that far to many people don't realize that the implied voltage for the rating is 3.7v, rather than the 5v output. That's why I usually tell people to convert everything to W and Wh's to see the true capacity and load. Fortunately, all of this is DC so RMS and phase angles don't enter the picture.rpdom wrote: ↑Tue Oct 02, 2018 5:31 amPerhaps "mAh, Ah and Wh are units of power capacity commonly used in rechargeable batteries/powerbanks, not to be confused with mA, A or W"W. H. Heydt wrote: ↑Tue Oct 02, 2018 3:31 amI don't *think* you need to add Wh (Watt-hour == energy).
mAh is a human readable form of coulomb, a unit of charge.W. H. Heydt wrote: ↑Sat Nov 03, 2018 5:41 pmYeah...except mAh and Ah *aren't* units of energy, which Wh is. The problem with so many batteries being given mAh/Ah ratings is that far to many people don't realize that the implied voltage for the rating is 3.7v, rather than the 5v output. That's why I usually tell people to convert everything to W and Wh's to see the true capacity and load. Fortunately, all of this is DC so RMS and phase angles don't enter the picture.rpdom wrote: ↑Tue Oct 02, 2018 5:31 amPerhaps "mAh, Ah and Wh are units of power capacity commonly used in rechargeable batteries/powerbanks, not to be confused with mA, A or W"W. H. Heydt wrote: ↑Tue Oct 02, 2018 3:31 amI don't *think* you need to add Wh (Watt-hour == energy).
Perhaps a mention of "dimensional analysis", aka Keep Your Units Consistent.
Since everything Pi is either 3.3v or 5v--and when you're sealing with anything more that a few mA, it's 5v--the problem area that comes up time and time again is basically an advertising problem. Companies tout LiPo battery capacities in mAh (or--occasionally--Ah). Since that is based on a 3.7v cell voltage, it makes nice impressive numbers. The problem comes when people try to treat that as being at 5v, as that's the converted and regulated output. So...people overestimate battery storage capacity and then get all flustered and confused when those who do know what is going on point out that the battery capacity is a lot less than they think it is.bensimmo wrote: ↑Sat Nov 03, 2018 9:42 pmmAh is a human readable form of coulomb, a unit of charge.W. H. Heydt wrote: ↑Sat Nov 03, 2018 5:41 pmYeah...except mAh and Ah *aren't* units of energy, which Wh is. The problem with so many batteries being given mAh/Ah ratings is that far to many people don't realize that the implied voltage for the rating is 3.7v, rather than the 5v output. That's why I usually tell people to convert everything to W and Wh's to see the true capacity and load. Fortunately, all of this is DC so RMS and phase angles don't enter the picture.
though I see you're getting at Wh (which isn't a unit of charge), now I read again![]()
Me too.W. H. Heydt wrote: ↑Mon Nov 05, 2018 3:54 pmThe version of that I heard....entirely too many years ago...was "Never Twice the Same Color".
