257986
Pi VPN Walkthru for PIA Private Internet Access
Thu Sep 27, 2018 11:53 pm
So a while ago a setup a Pi 3B that automatically goes into a VPN on boot, can communicate back and forth across the local network, and has a killswitch if the VPN goes down or the service is disconnected. I figure that I spent some time on it and I would share.
This is was setup with 2018-06-27-raspbian-stretch. This can be setup with lite, but due to the nature of this, it's best setup with stretch due to the easability of using a https://dnsleaktest.com
Let's start off with the basics. Get it updated.
sudo apt-get update -y
sudo apt-get upgrade -y
From there you'll want to go into config. You can use the one built into the interface or raspi-config if at the cli. You want to set a good password and enable SSH and/or VNC for network access at the minimum. Setting the local settings, like timezone and keyboard layouts are good to do here as well.
sudo raspi-config
Best to check the public IP right off the bat so that we have the current IP.
curl icanhazip.com
This configuration is going to be setting a static IP address, so it is probably a good idea to jot down your local IP address as well as the interface that it is conencted to. In this example I am using 192.168.0.35 connected onto eth0
ifconfig
Make a copy of your current network configuration
sudo cp /etc/network/interfaces /etc/network/interfaces.bak
Change your network configuration file
sudo nano /etc/network/interfaces
Depending on your network configuration this is going to change. Add this to the end of the file. The gateway address is usually the address of your router and the network address (or -add-net, in the example), usually is the same address as your router but the last octet is a 0.
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static
	address 192.168.0.35
	netmask 255.255.255.0
	gateway 192.168.0.35
	dns-nameservers 1.1.1.1 1.0.0.1
up route add -net 192.168.0.0 netmask 255.255.255.0 gw 192.168.0.1 metric 300
Reboot the Pi to verify that all the settings are looking good and you can still go online.
sudo reboot now
If using lite ping a website, like http://www.google.com and press Ctrl+C to stop the pinging.
ping google.com
Install OpenVPN.
sudo apt-get install openvpn -y
Get the VPN configuration files for the VPN. I use PIA
sudo wget https://www.privateinternetaccess.com/openvpn/openvpn.zip
Unzip the configuration files and move a few of them with the OenVPN files
sudo unzip openvpn.zip -d openvpn
sudo cp openvpn/ca.rsa.2048.crt openvpn/crl.rsa.2048.pem /etc/openvpn/
Each of the configuration files goes to a particular region/area. For this example, France is being used. Change the filename accordingly.
sudo cp openvpn/France.ovpn /etc/openvpn/ex.conf
Create a login file. There's multiple ways to do this. USERNAME and PASSWORD are your login credentials for the VPN.
sudo su
touch /etc/openvpn/login
echo "USERNAME" >> /etc/openvpn/login
echo "PASSWORD" >> /etc/openvpn/login
exit
Edit the configuration file
sudo nano /etc/openvpn/ex.conf
CHANGE
auth-user-pass
ca ca.rsa.2048.crt
crl-verif crl.rsa.2048.pem
TO
auth-user-pass /etc/openvpn/login
crl-verif /etc/openvpn/crl.rsa.2048.pem
ca /etc/openvpn/ca.rsa.2048.crt
Test the VPN. At this point note that you may loose connection to the Pi if connected thru VNC/SSH if there is anything mistyped.
sudo openvpn --config /etc/openvpn/ex.conf
You can check your IP again to verify that you have a different IP address or go to https://www.dnsleaktest.com and do the standard test.
curl icanhazip.com
Enable the VPN to enable itself at boot
sudo systemctl enable openvpn@ex
Reboot the Pi and verify that the VPN is operational by doing another test
sudo reboot now
Add iptable rules. If connecting into the Pi thru a network connection, paste the entire list and don't manually type, connection will be lost before finishing. PIA uses port 1198 for establishing the connection and 53 for locating the PIA DNS server. If directing to an IP address directly, the lines that reference port 53 can be omitted as 53 will not have to be open. Other VPNs may require different ports.
# Allow loopback device (internal communication)
sudo iptables -A INPUT -i lo -j ACCEPT
sudo iptables -A OUTPUT -o lo -j ACCEPT
#Allow all local traffic.
sudo iptables -A INPUT -s 192.168.0.0/24 -j ACCEPT
sudo iptables -A OUTPUT -d 192.168.0.0/24 -j ACCEPT
# Allow VPN establishment
# Only 2 ports open, 1 for DNS and 1 for VPN
# If establishing thru an IP and not a name, the ones with port 53 can be removed
# Port 1198 may be different depending on the VPN
sudo iptables -A OUTPUT -p udp --dport 53 -j ACCEPT
sudo iptables -A INPUT -p udp --sport 53 -j ACCEPT
sudo iptables -A OUTPUT -p udp --dport 1198 -j ACCEPT
sudo iptables -A INPUT -p udp --sport 1198 -j ACCEPT
#Accept all TUN connections (tun = VPN tunnel)
sudo iptables -A OUTPUT -o tun+ -j ACCEPT
sudo iptables -A INPUT -i tun+ -j ACCEPT
#Set default policies to drop all communication unless specifically allowed
sudo iptables -P INPUT DROP
sudo iptables -P OUTPUT DROP
sudo iptables -P FORWARD DROP
Install the ability of the tables to save thru reboots. Click Y on bind to IPv4
sudo apt-get install iptables-persistent -y
Ensure that the service runs and saves the settings
sudo netfilter-persistent save
sudo systemctl enable netfilter-persistent
Reboot
sudo reboot now
Verifiy that everything is operating as should be. On reboot of the Pi, websites should be available. You can check your IP or pull up https://dnsleaktest.com.
Disabling the VPN should render the internet useless.
sudo service openvpn stop
Pull up the same website and verify that the internet does not work.
Turn OpenVPN back on and verify that all is operational again.
sudo service openvpn start
Ocasionally, due to the order of all the services starting on Pi on boot, the VPN will not start properly and will require restarting after boot.
This issue can be remedied one of two ways.
  • In raspi-config there is a wait on network option. Enable that to see if it fixes the issue.
  • Restart the service automatically on reboot
Option 2 can be done with a task scheduler.
sudo apt-get install gnome-schedule -y
When it's installed the application icon is added under System Tools, or just manually run it.
gnome-schedule
Schedule this task on reboot.
sudo service openvpn restart
Reboot and verify proper operation.
sudo reboot now
Enjoy
Here's a few of my sources:
Let me know what you guys think please
epoch1970
Re: Pi VPN Walkthru for Private Internet Access
Fri Sep 28, 2018 3:57 pm
Are you sure this works with Raspbian Stretch as-is?
Why not use dhcpcd.conf for such as straightforward config?
sudo systemctl enable openvpn@sw
Shouldn't that be "systemctl enable openvpn@ex"?
What about /etc/defaults/openvpn?
257986
Re: Pi VPN Walkthru for PIA Private Internet Access
Fri Sep 28, 2018 9:19 pm
This does work as-is. It has been tested across several Pi's.
True, that could be omitted. No sense in backing up a file that's basically empty.
Had issues with that type of a config leaking DNS after the tunnel was secure. Going to explore it again when have some time to do so
Thanks. That was a typo. Correcting it.
257986
Sat Sep 29, 2018 11:20 pm
I looked more into DHCP. If you want to DHCP here's a few steps to accomplish this
Modify the interfaces file
Following the example, the end of the file should look like this
auto lo
auto eth0
allow-hotplug eth0
Install dnsmasq
sudo apt-get install dnsmasq
Modify the dnsmasq.config file
sudo nano /etc/dnsmasq.conf
Put this at the end
no-resolv
server=1.1.1.1
server=1.0.0.1
Go ahead and reboot
sudo reboot now
Test with https://www.dnsleaktest.com
If you want to check to make sure that the VPN killswitch is working, the best way is to just rename the config file and reboot.
sudo mv /etc/openvpn/ex.conf /etc/openvpn/ex1.conf
sudo reboot now
Just don't forget to name it back
sudo mv /etc/openvpn/ex1.conf /etc/openvpn/ex.conf
sudo reboot now
Works pretty good. Thanks for the suggestion
When I have some time I'm going to throw another post with the modifications for DHCP in it.
257986
Sun Feb 03, 2019 11:51 pm
Created Pi VPN Setup for PIA with killswitch and DHCP.
Same basic setup but with DHCP
https://www.raspberrypi.org/forums/view ... 3&t=223733
rpifive
Fri Feb 15, 2019 9:22 pm
You have a typo:
should be
crl-verify /etc/openvpn/crl.rsa.2048.pem
Tonya2534
Thu Feb 21, 2019 10:51 am
You may be using the wrong words here. See the VPN server is the host itself. If you want traffic to reach the Internet through your Pi, then you need the VPN Client vivavideo
Gudlad
Mon Mar 04, 2019 2:22 pm
Hya - not sure if I"m missing something here but the second and third line of this code isn't in the file when I copy it from the zipped folder - only the auth-user-pass. The VPN seems to work without it but I get the feeling they should be in.
auth-user-pass
ca ca.rsa.2048.crt
TO
ca /etc/openvpn/ca.rsa.2048.crt048.crt
Any advice for a Pi newbie or thoughts on why this would be missing would be greatly appreciated...
Plex7
Mon Nov 11, 2019 9:13 am
I have tried and researched extensively how to fix this DNS leak. About 4 servers in the standard test and about 5-6 in the extensive test all connected to my ISP. My only other alternative is to block those IP addresses. But how?
Also, the post before me is true. Tutorial is slightly outdated.
Please help!
Plex7
Tue Nov 12, 2019 9:02 am
FIX DNS LEAK!
Open Terminal and edit the resolv.conf file by typing
nano /etc/resolv.conf
go ahead and delete all the other DNS servers there...
then add the server IP of the Private Internet Access DNS Servers
nameserver 209.222.18.222
nameserver 209.222.18.218
Save and exit the file and then reboot.
You will need to grant access to pi to edit the file. Prior to this, input this: sudo chown -R pi /etc/resolv.conf
Do the changes above and grant access back to root otherwise "sudo" won't work anymore with
pkexec chown root:root /etc/sudoers /etc/sudoers.d -R
Cob
Tue Nov 12, 2019 5:10 pm
That change does not persist after the reboot.
will5023
Thu Feb 06, 2020 9:40 pm
When I run this part:
I get the following
cp: target '/etc/openvpn/ex.conf' is not a directory
Can you advise? I'm pretty new to Raspberry Pi/Linux.
iknowreal
Fri Mar 20, 2020 11:34 pm
A Few questions the first is how do I use a VPN location that has spaces for example New York?
Also I have the same exact problem the previous poster had.
"cp: target '/etc/openvpn/ex.conf' is not a directory"
Please advise.
ggervais5
Sun Apr 12, 2020 5:33 pm
I followed these instructions for my Raspberry PI 4, which I typically run headless and connect to via VNC. To complete the iptables commands, I had to connect it to a monitor and keyboard/mouse - it kept killing my VNC connection. With a monitor and keyboard/mouse, I was able to complete the rest of the setup. However, I can no longer connect to the PI via VNC nor SSH. I tried adding ports 22 and 5900 as INPUT in iptables, but still no access. When directly connected to the PI, I am able to browse the web over VPN just fine.
What am I missing?
Prior to setting up for PIA, I had set up a static IP using dhcpcd.conf with these lines:
interface eth0
static ip_address=192.168.1.15/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
So, I did not add the lines suggested in /etc/network/interfaces.
ggervais5
Sun Apr 12, 2020 7:36 pm
I figured it out. The iptables settings were not being made persistent. It is all working now.
ramsdale
Sat Apr 18, 2020 8:23 am
I have followed the guide and it works fine. I have one problem though. After a while I get disconnected from the VPN, does this happen to anybody else?
paqman
Mon Apr 20, 2020 10:18 pm
So this works for me pretty flawlessly. dnsleaktest shows good, everything working. But I'm not sure how to add iptables rules back in to allow me to ssh in remotely? Also going to be running it headless and need to be able to ssh in. How do I allow port 22 in with iptables?
Edit: My bad, I didn't look at the rules closely when I pasted them in. My local network is 192.168.1.x. Now I just need to figure out how to delete all these rules lol.
bobmcguffin
Thu Aug 20, 2020 3:44 am
I might try this tutorial out as a last resort, but I have a question that I think you guys might be able to answer.
I want to install the Private Internet Access App on my Raspberry Pi, directly from the website, they have a download link for Linux in 64bit. When I try to run it, the mousepad will appear with 2 error messages before I can install it:
The Document Was Not UTF-8 Valid
Invalid Byte Sequence In Conversion Input
Does anyone know if there's an easy fix to this? This came as a huge surprise to me because I have the Raspberry Pi 4 model B and I've done sudo apt-get update and sudo apt-get upgrade and I'm running Raspbian with Debian. As far as I know this model of Pi can run 64bit apps for sure. I meet all the requirements to install PIA on my Raspberry PI, I've successfully paid for it and the "torrent box" tutorial I'm watching from techwiztime specifically suggests to be using PIA as your VPN.
I'm so confused, if you guys would know something about this I could use the help.
fixxer5150
Thu Oct 29, 2020 4:29 am
UPDATE 28 OCT 2020:
Install OpenVPN.
This has changed since the PIA has went to "NextGen". US locations no longer work and this is going to be world-wide soon. Albania.ovpn (and probaby some others) still works on with the old config files but not for long.
The new wget is
wget https://www.privateinternetaccess.com/openvpn/openvpn-nextgen.zip
They are denying access to the US locations and mine failed a few days ago.
Found the announcment for "NextGen" in their announcements pages.
I had no need for most of the above process for checking the IP and setup and used much simpler checks before/after.
I also validated my deluge port was tunneling through the VPN appropriately with torrent tracking. Google one and find the one you like that does not want private info. You basically seed it in your torrent manager and check the IP it advertises and then delete it when you are done.
I also found it much easier to create a two-line document in the same directory called "pass.txt" with the only two entries:
(insert your username here)
(insert your password here)
and appending to the bottom of the .ovpn I use:
auth-user-pass pass.txt
Then used Chron-e to setup the autostart. Chron has been much more reliable for me on debian using the Pi4B and latest Raspberry OS.
Hope this helps someone.
-fixxer5150
paqman
Thu Oct 29, 2020 4:16 pm
So I set this up last April, and it has been working flawlessly since then. Then all of the sudden this week I noticed it wasn't working. When I logged onto my pi to check it out, I noticed that I was not able to ping out to google or get my IP address. I shut down the iptables rules, and then I was able to ping out again. Openvpn seemed to be running, but I am still showing my local IP address. So I stopped openvpn, and started it on the console so I could read the output. About once a minute, it is giving me these errors:
Thu Oct 29 09:48:25 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Oct 29 09:48:25 2020 TLS Error: TLS handshake failed
Thu Oct 29 09:48:25 2020 SIGUSR1[soft,tls-error] received, process restarting
Thu Oct 29 09:48:55 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]xxx.xxx.xxx.xxx:1198
Thu Oct 29 09:48:55 2020 UDP link local: (not bound)
Thu Oct 29 09:48:55 2020 UDP link remote: [AF_INET]xxx.xxx.xxx.xxx:1198
The IP address it shows (that I x'd out), is not my local IP, so it looks like that is the IP address it is trying to assign me (from the PIA denver region). However when I curl icanhazip.com, it takes quite a while before coming back with my regular IP, not the PIA one.
Any idea why this is happening? I haven't made any changes to it, or to my network. This just started happening on it's own.
Zeno013
Thu Oct 29, 2020 5:00 pm
have you tired openvpn-nextgen that fixxer5150 posted?
I had the same problem it died this morning after working for months. I upgraded to openvpn-nextgen then back up. I think this walk through needs to be updated now.
