Gerofi
Reconnect ethernet raspberry
Tue Sep 18, 2018 8:33 pm
My english is bad, I need that when my raspberry does not find internet, do not leave the code, any ideas?
I tried this code to check if there is internet connection
import urllib2
def internet_on():
    try:
        urllib2.urlopen('http://www.google.com', timeout=1)
        return True
    except urllib2.URLError as err:
        return False
But I do not know how to make it to try again to connect
bertlea
Re: Reconnect ethernet raspberry
Wed Sep 19, 2018 1:41 am
If you mean you want to test the connection every minute, then just write a loop to call your function to report the return value (or do something according to the return value). You should also call the
time.sleep(60)
function in your loop to only test it once a minute, to prevent it keep trying too frequently.
LeslieSantos
Wed Sep 26, 2018 5:28 am
There must be some error in the program. I also think to use the loop function.
