Potatotata123
Cannot FTP or SFTP to my RASPBERRY PI
Thu Sep 13, 2018 2:05 pm
Estado:	Conectando a 192.168.1.50...
Respuesta:	fzSftp started, protocol_version=8
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\raspberryfinal.ppk"
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\GCloud\CuentaGrana10.ppk"
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\tribal2.ppk"
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\GCloud\Cuenta2.ppk"
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\GCloud\testsftp.ppk"
Comando:	keyfile "C:\Users\Private\Desktop\Tribalwars\keys\GCloud\juanpetruj.ppk"
Comando:	open "[email protected]" 22
Error:	Server sent disconnect message
Error:	type 2 (protocol error):
Error:	"Too many authentication failures"
Error:	No se pudo conectar al servidor
Estado:	Esperando para reintentar...
Basically it says It cant be connected to server, too manu autentication failures.
pws
Re: Cannot FTP or SFTP to my RASPBERRY PI
Thu Sep 13, 2018 7:00 pm
I use Filezilla and SFTP to all my Rpi's without issue.
tpyo kingg
Thu Sep 13, 2018 7:12 pm
Please say more about how you are trying to connect. Is the SSH/SFTP server set to allow passwords or set to allow only keys? How were the keys generated and are they in a format usable by the client?
What happens when you use more verbosity in the client using -v, -vv, or -vvv for that?
ssh -v potatotata123@192.168.1.50
sftp -v potatotata123@192.168.1.50
pcmanbob
Thu Sep 13, 2018 7:20 pm
Just a thought have you enabled SSH its not enabled by default.
Potatotata123
Fri Sep 14, 2018 11:25 am
I use also both, but since 3 days ago i cannot acces. i dont know why, 4 days ago since 10 months from now, it worked 100%
Potatotata123
Fri Sep 14, 2018 11:27 am
Yes, i have some keys, but in local im accesing through pi password.
Key was generated by puttygen but it worked atleast. 4 months.
B.Goode
Fri Sep 14, 2018 11:33 am
Could anything have happened to the configuration of the local network you are using that might mean the host 192.168.1.50 is no longer the Raspberry Pi you are attempting to access?
Potatotata123
Fri Sep 14, 2018 7:28 pm
I dont think so cause 1
[email protected]:~ $ sudo ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.50  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::8871:2700:7439:337a  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:8b:81:57  txqueuelen 1000  (Ethernet)
        RX packets 488251  bytes 506581553 (483.1 MiB)
        RX errors 0  dropped 1333  overruns 0  frame 0
        TX packets 278311  bytes 33349751 (31.8 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 5168  bytes 256274 (250.2 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5168  bytes 256274 (250.2 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:de:d4:02  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
2- I continue accesing raspberry with the saved session in putty witouth changing thath IP and its working.
