DanielChai
"Real-time" object detection on Raspberry Pi
Wed Aug 29, 2018 3:18 am
Tried the instruction in https://github.com/shizukachan/darknet-nnpack and wrote some Python wrapper, I managed to run "real-time" object detection using Raspberry Pi camera + Yolo object detection algorithm. The frame rate is about 1FPS on RPI v3 model B+. Here is the results
Check my blog:)
http://funofdiy.blogspot.com/2018/08/de ... -real.html
I think 1FPS could really enable some very fun project, like robotic cars, drones, surveillance cameras, etc. Maybe not something super fancy. But, hey, it is only a $35 device!
ChicagoBob123
Re: "Real-time" object detection on Raspberry Pi
Fri Aug 31, 2018 2:01 pm
You need to investigate the Movidius Compute stick. Costs a bit but it will further your journey in Deep Learning
mic_s
Fri Aug 31, 2018 5:27 pm
You dosn't need to invest in a Movidius Compute Stick. The very well dokumented GPU Processing Units in your extrem-low-cost Rasp-Zero are perfectly adequate for a journey in deep learning / object recognition :
details:
https://youtu.be/zRaQS5MA2fU
(no additional hardware, besides the cam and the sd is required)
victagayun
Mon Nov 05, 2018 9:07 am
Could you reduce the resolution to increase the framerate?
openMV and pixycam2 are using only 640 x 480.
victagayun
Wed Nov 07, 2018 6:13 am
@ Install qmkl
sudo apt-get install flex
git clone https://github.com/Terminus-IMRC/qpu-assembler2
cd qpu-assembler2
make
I got this error
[email protected]:~/qmkl $ make
make: *** No targets specified and no makefile found.  Stop.
