Raspberry Pi and HCF 4094B shift register
Posted: Tue Aug 28, 2018 9:00 am
by vachhaninimiT
Greetings People,
I have board with 6 digit 7 segment display using HCF4094B shift registers. I have interfaced it with arduino and it displays 6 digits successfully.
Now on Raspberry Pi i want to do the same thing using python. Is it possible ?
Re: Raspberry Pi and HCF 4094B shift register
Posted: Tue Aug 28, 2018 9:29 am
by davidcoton
Yes, but if you need help you will have to give far more details, like:
  • Which model Pi?
  • Which OS (and date)?
  • Show your existing circuit.
  • What else is connected to your Pi?
  • What (if anything) have you tried? What ideas do you have?
Perhaps the most important thing to remember is that the Pi GPIOs run at 3V3. If your Arduino runs at 5V, then you may need level shifters -- or some other adaptation of your existing hardware. Get it wrong, and Bang goes your Pi.
Posted: Tue Aug 28, 2018 9:44 am
by vachhaninimiT
Well its raspberry Pi 2B.
Below is the code that i have tried...
import wiringpi
import time
wiringpi.wiringPiSetupGpio()
_DATA 		= 23
_STRB 		= 24
_CLK 		= 25
_DIGITS     = 6
_7SEGTYPE   = 'A'
_DIGITS		= [0x00, 0x00, 0x00, 0x00, 0x00, 0x00]
			# 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, Blank, -
_NUMBERS = [bytes(b'xB11100111'),
			bytes(b'xB10000100'),
			bytes(b'xB11010011'),
			bytes(b'xB11010110'),
			bytes(b'xB10110100'),
			bytes(b'xB01110110'),
			bytes(b'xB01110111'),
			bytes(b'xB11000100'),
			bytes(b'xB11110111'),
			bytes(b'xB11110110'),
			bytes(b'xB00000000'),
			bytes(b'xB00010000')]
_NUMBERS1 = [231,
			 132,
			 211,
			 214,
			 180,
			 118,
			 119,
			 196,
			 247,
			 246,
			 0,
			 16]
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(_DATA , GPIO.OUT)
GPIO.setup(_STRB , GPIO.OUT)
GPIO.output(_STRB, 1)
GPIO.setup(_CLK , GPIO.OUT)
wiringpi.pinMode(_DATA, 1)
wiringpi.pinMode(_STRB, 1)
wiringpi.pinMode(_CLK, 	1)
#wiringpi.digitalWrite(_STRB, 0)
def Print(number, digits, dp):
	negate = False
	x = int(dp)
	y = int(0)
	tmp = long(number)
	if(tmp <  0):
		negate = 1
		tmp = tmp * -1
		if(tmp > 999999):
			tmp /= 10
			if(x > 0):
				x = x-1
	else:
		if(tmp > 999999):
			tmp /= 10
			if(x > 0):
				x = x-1
	while(tmp > 0 and y < digits):
		_DIGITS[y] = tmp % 10
		tmp /= 10
		y += 1
	while(y < digits):
		_DIGITS[y] = 0
		y += 1
	if(negate):
		_DIGITS[digits - 1] = 11
	#for x in range(6):
		#print _DIGITS[x]
	PrintDigits(digits, x)
def PrintDigits(digits, dp):
	global _DIGITS
	global _7SEGTYPE
	for i in range(6):
		dig = _NUMBERS[_DIGITS[i]]
		print dig
		#if(dp > 0):
			#if(i == dp):
				#dig |= xB00001000
		if(_7SEGTYPE == 'C'):
			PrintHex(dig, 0)
		elif (_7SEGTYPE == 'A')	:
			PrintHex(dig, 0)
	wiringpi.digitalWrite(_STRB, 1)
def PrintHex( x, y):
	wiringpi.shiftOut(_DATA, _CLK, 0, x)
if __name__ == "__main__":
	Print(1, 6, 0)
_DATA = 23(according to wiringpi pin#)
_STRB = 24(according to wiringpi pin#)
_CLK = 25(according to wiringpi pin#)
Posted: Tue Sep 04, 2018 5:50 pm
by danjperron
Be aware that if your power on the 74HCF4094 is 5V the VIH is 0.7 * 5V = 3.5V. Then it won't work. You will need to reduce VCC or add a level converter from 3.3V to 5V.
Also Why using wiringpi? it is so simple with spidev
ex:
import spidev
import time
spi = spidev.SpiDev()
spi.open(0,0)
Counter=0;
#Digits   Convert nibble  value into  the correct segment led  digit
Digits = [63,6,91,79,102,109,125,7,127,111,119,124,57,94,121,113]
while True:
  D1 =  Digits[Counter % 10]
  D2 =  Digits[(Counter / 10) % 10]
  D3 =  Digits[(Counter / 100) % 10]
  D4 =  Digits[(Counter / 1000) % 10]
  #this is actually the single command to send info ( 4 bytes)
  spi.xfer2([D1,D2,D3,D4]);
  Counter = Counter + 1
  time.sleep(0.1)
