ravi134
Raspberry Pi and 3G
Sat Aug 11, 2018 10:49 am
I want to connect a SIM card to Raspberry Pi 3. My requirement is stable connection of 3G so that my Pi can operate outdoor and connect to my remote servers. I read a lot about 3G Dongle but also heard about instability. Appreciate your help on this.
Buzz2006
Re: Raspberry Pi and 3G
Sat Aug 11, 2018 11:03 am
Im no expert. Try connecting your raspberry pi to a mobile hotspot on your phone. I know this works with Apple phones, but I'm clueless when it comes to Android.
Sat Aug 11, 2018 11:11 am
Different countries have different standards, but a HAT may suffice:
https://www.pianywhere.com
Asus ChromeBox 3 Celeron is my other computer.
Sat Aug 11, 2018 1:27 pm
I have a bunch of devices, including Pi, that are in remote locations and communicate with servers in google cloud via 3G or 4G. Both in the USA and in Europe.
In most cases the Pi or other device connects to a cellular modem or dongle using WiFi.
In general these systems have worked well. However one will always get occasional disconnects and connection failures of the cellular network.
In the USA they like to put data caps on everything so every month we get informed that we have used our limit for the month and data rate will be throttled to 200K bytes per second. That's OK our devices are only streaming at 100KBs.
If your Pi are at remote locations were it is hard or expensive to visit and fix them be sure to take some precautions to ensure reliability...
Use the hardware watchdog on the Pi to reboot the thing in case of an OS crash or other catastrophe.
Make your root file system read only so as to avoid file system corruption and failure to reboot after power interruptions.
Think about arranging that the cellular modem can be power cycled. Some times they get stuck and that is all one can do.
ravi134
Sat Aug 11, 2018 3:25 pm
First of all Thanks a ton for replying in details. You got my problem and scenario so well.. Thanks again
Few questions again:
1) I will try USB dongle. Do you think there is any custom made board to connect SIM card to Pi?
2) Any suggestions for hardware watchdog?
3) My Pi wont requires much of data in most of the case but I have to make a design in such a way that in some situation it can use. What best I can do to do for the reliability, like force reboot etc.? (Think it goes back to my #2)
Appreciate your help.
ravi134
Sat Aug 11, 2018 3:31 pm
Thank you for the post, I got that too but it is not fitting in my requirement as 1) it is expensive (as I expect to use many Pis) and 2) I want to create something (if possible).
Thanks again for your reply : -)
Sat Aug 11, 2018 5:26 pm
ravi134,
I cannot imagine there is any useful way to connect a SIM card to a Pi.
The SIM card goes in the GSM module/dongle/modem. The Pi connects to the GSM module/dongle/modem via ethernet, WiFi, USB.
The Pi has built in watchdog hardware. Use the watchdog package with it. Google it.
As for a real, external, hardware watchdog that can power cycle the Pi and anything connected to it, that is something I have discovered is essential for utmost failure recovery. It's also something I have yet to find or create.
As for cost, the cellular modems we are using range from a thousand Euro at the top end down to about 50 Euro for a domestic cellular "dongle".
mosespi
Sat Aug 11, 2018 7:52 pm
Lots of inexpensive (less then $100) USB cell modems around, not the most reliable for unattended/sever use, but they work. I usually write scripts that power cycle the USB power on the Pi to reset these types of modems, it helps bring them back up most of the time.
Better reliability exists at a price.. there are industrial cellular modems like the following:
https://www.sierrawireless.com/products ... ways/rv50/
Pricing at around $600 in the US, not cheap but they are solid performers.
Here is a UPS of my own design that has an actual hardware watchdog: http://www.allspectrum.com/mopower/
It will cut and reapply power if it doesn't hear back from the Pi in a set amount of time.
Good luck.
Regards,
-Moses
Power problems? MoPower UPS for the Pi
6by9
Sun Aug 12, 2018 8:19 am
Zte mf823 works nicely for me, and just shows up as a network interface instead of having to mess with wvdial or ppp setup.
