geffers
Network Monitoring
Sat Jun 23, 2018 11:15 am
Folks,
One of my numerous Pi devices is on 24/7 and is used merely as a server, have https, dlna, samba, xsane etc all running on Stretch Lite
It has a fixed IP so is a separate device but am wondering; is there any way it can monitor network traffic from other devices on my network?
I've had a wee bit of experience with ntopng but think that shows traffic passing through that specific device.
Geffers
allfox
Re: Network Monitoring
Sat Jun 23, 2018 12:35 pm
I think iptables could log traffic, like this:
# iptables -nv --list
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 0
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 3
44 1856 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 8
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 11
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 12
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 13
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 14
0 0 RETURN icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 40
This is my log based on ICMP type. I also used MAC address, port number before.
If you could describe what kind of log are you looking for, I might could give the exact iptables rule to log it.
mfa298
Sat Jun 23, 2018 3:11 pm
That depends on what sort of thing you want to monitor.
For any detailed inspection the pi would need to see the traffic which would normally mean the traffic passing through the Pi. This might limit the throughput on your internet link. There are various tools to inspect traffic depending on what it is you want to look at.
On some switches/routers there's an option to get basic data (packets/bytes/errors on each interface) via a protocol called SNMP. This just uses an agent that could run on your Pi which runs on a regular basis to gather the data. This doesn't need all the traffic going via the Pi (so means it's not a bottleneck) but does require any the network equipment to support SNMP (some home routers do, other don't).
geffers
Mon Jun 25, 2018 7:00 am
Thanks for suggestions folks.
All I am curious about is the automatic uploads and synchronisation that occur from mobile phones and keypads.
I did three videos recently on my netpad, Google was synching them to photos and/or drive and as I don't have fibre it took around 3 hours.
I do transfer videos to a friend via my Pi and am able to monitor progress and rate but just curious what the mobile devices are up to.
Geffers
bob_binz
Mon Jun 25, 2018 7:37 am
If you're running X rather than CLI, you could try wireshark which seems to be in the Raspbian repo. I've only ever used it on Windows though and only for short term sessions. Not sure if it will give you the info you're wanting
BBz
