DirkS
Re: Multiple Frame buffer beta testers wanted
Wed Sep 19, 2018 8:45 am
aBUGSworstnightmare wrote:
Tue Sep 18, 2018 8:53 pm
jamesh wrote:Any X logs?
an you point me to where to find them?
/var/log/Xorg.0.log ?
aBUGSworstnightmare
Wed Sep 19, 2018 9:04 am
That's where I've checked, but there is no Xorg.0.log data
Wed Sep 19, 2018 10:48 am
Might be some logs elsewhere,
try `find / -name Xorg.*` and see if it pops up elsewhere.
DirkS
Wed Sep 19, 2018 10:55 am
~/.local/share/xorg
Odd location. But hey... this is X :roll:
aBUGSworstnightmare
Wed Sep 19, 2018 1:01 pm
Thanks Dirks! Found them.
I've deleted what was there and sterted testing. To let it happen for the first time took several connects/disconnects of mouse and Keyboard.
Later it happend faster :oops: But now confirmed that any USB device can cause this to happen (USB stick too).
1st test
[    19.086]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[    19.108] X Protocol Version 11, Revision 0
[    19.116] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[    19.124] Current Operating System: Linux raspberrypi 4.14.61-v7+ #315 SMP Fri Aug 10 10:20:01 BST 2018 armv7l
[    19.124] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e8348bf7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    19.141] Build Date: 18 October 2017  04:55:30PM
[    19.146] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[    19.151] Current version of pixman: 0.34.0
[    19.161] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    19.161] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    19.180] (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sat Sep 15 10:40:06 2018
[    19.186] (==) Using config file: "/etc/X11/xorg.conf"
[    19.191] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    19.201] (**) Option "defaultserverlayout" "Singlehead0"
[    19.202] (++) ServerLayout "Multihead"
[    19.202] (**) |-->Screen "ScreenTurbo0" (0)
[    19.202] (**) |   |-->Monitor "Monitor0"
[    19.202] (**) |   |-->Device "fbturbo0"
[    19.202] (**) |-->Screen "ScreenTurbo1" (1)
[    19.202] (**) |   |-->Monitor "Monitor1"
[    19.203] (**) |   |-->Device "fbturbo1"
[    19.203] (**) Option "StandbyTime" "0"
[    19.203] (**) Option "SuspendTime" "0"
[    19.203] (**) Option "OffTime" "0"
[    19.203] (**) Option "Xinerama" "true"
[    19.203] (==) Automatically adding devices
[    19.203] (==) Automatically enabling devices
[    19.203] (==) Automatically adding GPU devices
[    19.209] (**) Xinerama: enabled
[    19.209] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    19.210] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[    19.210] 	Entry deleted from font path.
[    19.210] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    19.210] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    19.210] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    19.210] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[    19.210] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    19.211] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    19.211] 	Entry deleted from font path.
[    19.211] (==) FontPath set to:
	built-ins
[    19.211] (==) ModulePath set to "/usr/lib/xorg/modules"
[    19.211] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    19.213] (II) Loader magic: 0x1fbf40
[    19.213] (II) Module ABI versions:
[    19.213] 	X.Org ANSI C Emulation: 0.4
[    19.213] 	X.Org Video Driver: 23.0
[    19.213] 	X.Org XInput driver : 24.1
[    19.213] 	X.Org Server Extension : 10.0
[    19.217] (++) using VT number 1
[    19.222] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[    19.223] (II) no primary bus or device found
[    19.224] (II) LoadModule: "glx"
[    19.242] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    19.307] (II) Module glx: vendor="X.Org Foundation"
[    19.307] 	compiled for 1.19.2, module version = 1.0.0
[    19.307] 	ABI class: X.Org Server Extension, version 10.0
[    19.307] (II) LoadModule: "fbturbo"
[    19.307] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[    19.312] (II) Module fbturbo: vendor="X.Org Foundation"
[    19.312] 	compiled for 1.19.2, module version = 0.5.1
[    19.312] 	Module class: X.Org Video Driver
[    19.312] 	ABI class: X.Org Video Driver, version 23.0
[    19.312] (II) FBTURBO: driver for framebuffer: fbturbo
[    19.313] (WW) Falling back to old probe method for fbturbo
[    19.313] (II) Loading sub module "fbdevhw"
[    19.313] (II) LoadModule: "fbdevhw"
[    19.313] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    19.316] (II) Module fbdevhw: vendor="X.Org Foundation"
[    19.316] 	compiled for 1.19.2, module version = 0.0.2
[    19.316] 	ABI class: X.Org Video Driver, version 23.0
[    19.317] (II) FBTURBO(0): using /dev/fb0
[    19.317] (II) FBTURBO(1): using /dev/fb1
[    19.317] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    19.317] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[    19.317] (==) FBTURBO(0): RGB weight 888
[    19.317] (==) FBTURBO(0): Default visual is TrueColor
[    19.317] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[    19.317] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 8100kB)
[    19.317] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[    19.317] (**) FBTURBO(0): Option "debug" "true"
[    19.317] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[    19.318] (II) FBTURBO(0): processor: Unknown
[    19.318] (II) FBTURBO(0): checking modes against framebuffer device...
[    19.318] (II) FBTURBO(0): checking modes against monitor...
[    19.318] (--) FBTURBO(0): Virtual size is 1920x1080 (pitch 1920)
[    19.318] (**) FBTURBO(0):  Built-in mode "current"
[    19.318] (==) FBTURBO(0): DPI set to (96, 96)
[    19.318] (II) Loading sub module "fb"
[    19.318] (II) LoadModule: "fb"
[    19.318] (II) Loading /usr/lib/xorg/modules/libfb.so
[    19.325] (II) Module fb: vendor="X.Org Foundation"
[    19.325] 	compiled for 1.19.2, module version = 1.0.0
[    19.325] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    19.325] fbturbo: PreInit done
[    19.325] fbturbo: PreInit 1
[    19.325] (==) FBTURBO(1): Depth 24, (==) framebuffer bpp 32
[    19.325] (==) FBTURBO(1): RGB weight 888
[    19.325] (==) FBTURBO(1): Default visual is TrueColor
[    19.325] (==) FBTURBO(1): Using gamma correction (1.0, 1.0, 1.0)
[    19.325] (II) FBTURBO(1): hardware: BCM2708 FB (video memory: 1500kB)
[    19.325] (**) FBTURBO(1): Option "fbdev" "/dev/fb1"
[    19.325] (**) FBTURBO(1): Option "debug" "true"
[    19.325] (**) FBTURBO(1): Option "SwapbuffersWait" "true"
[    19.326] (II) FBTURBO(1): processor: Unknown
[    19.326] (II) FBTURBO(1): checking modes against framebuffer device...
[    19.326] (II) FBTURBO(1): checking modes against monitor...
[    19.326] (--) FBTURBO(1): Virtual size is 800x480 (pitch 800)
[    19.326] (**) FBTURBO(1):  Built-in mode "current"
[    19.326] (==) FBTURBO(1): DPI set to (96, 96)
[    19.326] (II) Loading sub module "fb"
[    19.326] (II) LoadModule: "fb"
[    19.326] (II) Loading /usr/lib/xorg/modules/libfb.so
[    19.326] (II) Module fb: vendor="X.Org Foundation"
[    19.326] 	compiled for 1.19.2, module version = 1.0.0
[    19.326] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    19.326] fbturbo: PreInit done
[    19.326] (==) Depth 24 pixmap format is 32 bpp
[    19.326] fbturbo: FBDevScreenInit 0
[    19.339] (II) FBTURBO(0): using backing store heuristics
[    19.342] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[    19.346] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[    19.347] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[    19.347] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[    19.347] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[    19.347] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[    19.347] (==) FBTURBO(0): Backing store enabled
[    19.355] (==) FBTURBO(0): DPMS enabled
[    19.355] (II) FBTURBO(0): failed to enable hardware cursor
[    19.355] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[    19.355] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[    19.356] fbturbo: FBDevScreenInit done
[    19.356] (==) RandR enabled
[    19.356] fbturbo: FBDevScreenInit 1
[    19.356] (II) FBTURBO(1): using backing store heuristics
[    19.358] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[    19.362] (II) FBTURBO(1): can't load 'g2d_23' kernel module
[    19.362] (II) FBTURBO(1): failed to enable the use of sunxi display controller
[    19.362] (II) FBTURBO(1): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[    19.362] (II) FBTURBO(1): G2D hardware acceleration can't be enabled
[    19.362] (II) FBTURBO(1): enabled fbdev copyarea acceleration
[    19.362] (==) FBTURBO(1): Backing store enabled
[    19.363] (==) FBTURBO(1): DPMS enabled
[    19.363] (II) FBTURBO(1): failed to enable hardware cursor
[    19.363] (II) FBTURBO(1): no 3D acceleration because the driver has been compiled without libUMP
[    19.363] (II) FBTURBO(1): if this is wrong and needs to be fixed, please check ./configure log
[    19.363] fbturbo: FBDevScreenInit done
[    19.363] (==) RandR enabled
[    19.386] (II) SELinux: Disabled on system
[    19.390] (II) AIGLX: Screen 0 is not DRI2 capable
[    19.390] (EE) AIGLX: reverting to software rendering
[    20.762] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[    20.767] (II) IGLX: Loaded and initialized swrast
[    20.767] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    20.767] (II) AIGLX: Screen 1 is not DRI2 capable
[    20.768] (EE) AIGLX: reverting to software rendering
[    20.774] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[    20.778] (II) IGLX: Loaded and initialized swrast
[    20.779] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[    21.011] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event0)
[    21.011] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    21.011] (II) LoadModule: "libinput"
[    21.011] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    21.040] (II) Module libinput: vendor="X.Org Foundation"
[    21.040] 	compiled for 1.19.0, module version = 0.23.0
[    21.040] 	Module class: X.Org XInput Driver
[    21.041] 	ABI class: X.Org XInput driver, version 24.1
[    21.041] (II) Using input driver 'libinput' for '  USB Keyboard'
[    21.043] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 21 paused 0
[    21.043] (**)   USB Keyboard: always reports core events
[    21.043] (**) Option "Device" "/dev/input/event0"
[    21.044] (**) Option "_source" "server/udev"
[    21.046] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[    21.046] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[    21.046] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:04D9:1603.0001/input/input0/event0"
[    21.046] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 6)
[    21.046] (**) Option "xkb_model" "pc105"
[    21.046] (**) Option "xkb_layout" "de"
[    21.141] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[    21.141] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[    21.144] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event1)
[    21.144] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    21.144] (II) Using input driver 'libinput' for '  USB Keyboard'
[    21.147] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 24 paused 0
[    21.147] (**)   USB Keyboard: always reports core events
[    21.147] (**) Option "Device" "/dev/input/event1"
[    21.147] (**) Option "_source" "server/udev"
[    21.149] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[    21.149] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[    21.149] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:04D9:1603.0002/input/input1/event1"
[    21.149] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 7)
[    21.149] (**) Option "xkb_model" "pc105"
[    21.149] (**) Option "xkb_layout" "de"
[    21.152] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[    21.152] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[    21.153] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/event2)
[    21.153] (**) FT5406 memory based driver: Applying InputClass "libinput touchscreen catchall"
[    21.153] (**) FT5406 memory based driver: Applying InputClass "calibration"
[    21.153] (II) LoadModule: "evdev"
[    21.154] (WW) Warning, couldn't open module evdev
[    21.154] (II) UnloadModule: "evdev"
[    21.154] (II) Unloading evdev
[    21.154] (EE) Failed to load module "evdev" (module does not exist, 0)
[    21.154] (EE) No input driver matching `evdev'
[    21.154] (II) Falling back to input driver `libinput'
[    21.154] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[    21.156] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 25 paused 0
[    21.156] (**) FT5406 memory based driver: always reports core events
[    21.156] (**) Option "Device" "/dev/input/event2"
[    21.156] (**) Option "_source" "server/udev"
[    21.158] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[    21.158] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[    21.158] (**) Option "config_info" "udev:/sys/devices/virtual/input/input2/event2"
[    21.158] (II) XINPUT: Adding extended input device "FT5406 memory based driver" (type: TOUCHSCREEN, id 8)
[    21.159] (**) Option "AccelerationScheme" "none"
[    21.159] (**) FT5406 memory based driver: (accel) selected scheme none/0
[    21.159] (**) FT5406 memory based driver: (accel) acceleration factor: 2.000
[    21.159] (**) FT5406 memory based driver: (accel) acceleration threshold: 4
[    21.160] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[    21.160] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[    21.161] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/mouse0)
[    21.161] (**) FT5406 memory based driver: Applying InputClass "calibration"
[    21.161] (II) LoadModule: "evdev"
[    21.162] (WW) Warning, couldn't open module evdev
[    21.162] (II) UnloadModule: "evdev"
[    21.162] (II) Unloading evdev
[    21.162] (EE) Failed to load module "evdev" (module does not exist, 0)
[    21.162] (EE) No input driver matching `evdev'
[    21.162] (II) Falling back to input driver `libinput'
[    21.162] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[    21.162] (**) FT5406 memory based driver: always reports core events
[    21.162] (**) Option "Device" "/dev/input/mouse0"
[    21.162] (**) Option "_source" "server/udev"
[    21.270] (II) failed to create input device '/dev/input/mouse0'.
[    21.270] (EE) libinput: FT5406 memory based driver: Failed to create a device for /dev/input/mouse0
[    21.270] (EE) PreInit returned 2 for "FT5406 memory based driver"
[    21.270] (II) UnloadModule: "libinput"
[    35.975] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/mouse1)
[    35.975] (II) No input driver specified, ignoring this device.
[    35.975] (II) This device may have been added with another device file.
[    36.216] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/event3)
[    36.216] (**) Microsoft Microsoft IntelliMouse® Optical: Applying InputClass "libinput pointer catchall"
[    36.217] (II) Using input driver 'libinput' for 'Microsoft Microsoft IntelliMouse® Optical'
[    36.291] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 34 paused 0
[    36.291] (**) Microsoft Microsoft IntelliMouse® Optical: always reports core events
[    36.291] (**) Option "Device" "/dev/input/event3"
[    36.291] (**) Option "_source" "server/udev"
[    36.295] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[    36.296] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[    36.296] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0029.0003/input/input3/event3"
[    36.296] (II) XINPUT: Adding extended input device "Microsoft Microsoft IntelliMouse® Optical" (type: MOUSE, id 9)
[    36.298] (**) Option "AccelerationScheme" "none"
[    36.299] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) selected scheme none/0
[    36.300] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration factor: 2.000
[    36.300] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration threshold: 4
[    36.304] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[    36.304] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[   231.421] (II) config/udev: removing device   USB Keyboard
[   231.422] (**) Option "fd" "21"
[   231.426] (II) UnloadModule: "libinput"
[   231.426] (II) systemd-logind: releasing fd for 13:64
[   231.570] (II) config/udev: removing device   USB Keyboard
[   231.571] (**) Option "fd" "24"
[   231.575] (II) UnloadModule: "libinput"
[   231.575] (II) systemd-logind: releasing fd for 13:65
[   234.679] (II) config/udev: removing device Microsoft Microsoft IntelliMouse® Optical
[   234.681] (**) Option "fd" "34"
[   234.689] (EE)
[   234.689] (EE) Backtrace:
[   234.690] (EE)
[   234.690] (EE) Segmentation fault at address 0x44
[   234.690] (EE)
Fatal server error:
[   234.690] (EE) Caught signal 11 (Segmentation fault). Server aborting
[   234.690] (EE)
[   234.690] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   234.691] (EE) Please also check the log file at "/home/pi/.local/share/xorg/Xorg.0.log" for additional information.
[   234.691] (EE)
[   234.844] (EE) Server terminated with error (1). Closing log file.
2nd test
[   253.452]
[   253.500] X Protocol Version 11, Revision 0
[   253.520] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[   253.530] Current Operating System: Linux raspberrypi 4.14.61-v7+ #315 SMP Fri Aug 10 10:20:01 BST 2018 armv7l
[   253.530] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e8348bf7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[   253.575] Build Date: 18 October 2017  04:55:30PM
[   253.588] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[   253.601] Current version of pixman: 0.34.0
[   253.628] 	Before reporting problems, check http://wiki.x.org
[   253.628] Markers: (--) probed, (**) from config file, (==) default setting,
[   253.688] (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sat Sep 15 10:44:00 2018
[   253.704] (==) Using config file: "/etc/X11/xorg.conf"
[   253.720] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   253.721] (**) Option "defaultserverlayout" "Singlehead0"
[   253.721] (++) ServerLayout "Multihead"
[   253.721] (**) |-->Screen "ScreenTurbo0" (0)
[   253.721] (**) |   |-->Monitor "Monitor0"
[   253.722] (**) |   |-->Device "fbturbo0"
[   253.722] (**) |-->Screen "ScreenTurbo1" (1)
[   253.722] (**) |   |-->Monitor "Monitor1"
[   253.722] (**) |   |-->Device "fbturbo1"
[   253.722] (**) Option "StandbyTime" "0"
[   253.722] (**) Option "SuspendTime" "0"
[   253.722] (**) Option "OffTime" "0"
[   253.722] (**) Option "Xinerama" "true"
[   253.723] (==) Automatically adding devices
[   253.723] (==) Automatically enabling devices
[   253.723] (==) Automatically adding GPU devices
[   253.723] (**) Xinerama: enabled
[   253.723] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   253.723] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[   253.723] 	Entry deleted from font path.
[   253.723] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   253.723] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   253.723] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   253.723] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   253.723] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   253.723] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   253.723] (==) FontPath set to:
	built-ins
[   253.723] (==) ModulePath set to "/usr/lib/xorg/modules"
[   253.723] (II) The server relies on udev to provide the list of input devices.
[   253.723] (II) Loader magic: 0x1fbf40
[   253.723] (II) Module ABI versions:
[   253.723] 	X.Org ANSI C Emulation: 0.4
[   253.723] 	X.Org Video Driver: 23.0
[   253.723] 	X.Org XInput driver : 24.1
[   253.723] 	X.Org Server Extension : 10.0
[   253.725] (++) using VT number 1
[   253.731] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[   253.732] (II) no primary bus or device found
[   253.732] (II) LoadModule: "glx"
[   253.733] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   253.738] (II) Module glx: vendor="X.Org Foundation"
[   253.738] 	compiled for 1.19.2, module version = 1.0.0
[   253.738] 	ABI class: X.Org Server Extension, version 10.0
[   253.738] (II) LoadModule: "fbturbo"
[   253.739] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[   253.739] (II) Module fbturbo: vendor="X.Org Foundation"
[   253.739] 	compiled for 1.19.2, module version = 0.5.1
[   253.739] 	Module class: X.Org Video Driver
[   253.739] 	ABI class: X.Org Video Driver, version 23.0
[   253.739] (II) FBTURBO: driver for framebuffer: fbturbo
[   253.739] (WW) Falling back to old probe method for fbturbo
[   253.740] (II) Loading sub module "fbdevhw"
[   253.740] (II) LoadModule: "fbdevhw"
[   253.740] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   253.740] (II) Module fbdevhw: vendor="X.Org Foundation"
[   253.740] 	compiled for 1.19.2, module version = 0.0.2
[   253.740] 	ABI class: X.Org Video Driver, version 23.0
[   253.741] (II) FBTURBO(0): using /dev/fb0
[   253.741] (II) FBTURBO(1): using /dev/fb1
[   253.741] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   253.741] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[   253.741] (==) FBTURBO(0): RGB weight 888
[   253.741] (==) FBTURBO(0): Default visual is TrueColor
[   253.741] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[   253.741] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 8100kB)
[   253.741] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[   253.741] (**) FBTURBO(0): Option "debug" "true"
[   253.741] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[   253.742] (II) FBTURBO(0): processor: Unknown
[   253.742] (II) FBTURBO(0): checking modes against framebuffer device...
[   253.742] (II) FBTURBO(0): checking modes against monitor...
[   253.742] (--) FBTURBO(0): Virtual size is 1920x1080 (pitch 1920)
[   253.742] (**) FBTURBO(0):  Built-in mode "current"
[   253.742] (==) FBTURBO(0): DPI set to (96, 96)
[   253.742] (II) Loading sub module "fb"
[   253.742] (II) LoadModule: "fb"
[   253.742] (II) Loading /usr/lib/xorg/modules/libfb.so
[   253.743] (II) Module fb: vendor="X.Org Foundation"
[   253.743] 	compiled for 1.19.2, module version = 1.0.0
[   253.743] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   253.743] fbturbo: PreInit done
[   253.743] fbturbo: PreInit 1
[   253.743] (==) FBTURBO(1): Depth 24, (==) framebuffer bpp 32
[   253.743] (==) FBTURBO(1): RGB weight 888
[   253.743] (==) FBTURBO(1): Default visual is TrueColor
[   253.743] (==) FBTURBO(1): Using gamma correction (1.0, 1.0, 1.0)
[   253.743] (II) FBTURBO(1): hardware: BCM2708 FB (video memory: 1500kB)
[   253.743] (**) FBTURBO(1): Option "fbdev" "/dev/fb1"
[   253.743] (**) FBTURBO(1): Option "debug" "true"
[   253.743] (**) FBTURBO(1): Option "SwapbuffersWait" "true"
[   253.743] (II) FBTURBO(1): processor: Unknown
[   253.744] (II) FBTURBO(1): checking modes against framebuffer device...
[   253.744] (II) FBTURBO(1): checking modes against monitor...
[   253.744] (--) FBTURBO(1): Virtual size is 800x480 (pitch 800)
[   253.744] (**) FBTURBO(1):  Built-in mode "current"
[   253.744] (==) FBTURBO(1): DPI set to (96, 96)
[   253.744] (II) Loading sub module "fb"
[   253.744] (II) LoadModule: "fb"
[   253.744] (II) Loading /usr/lib/xorg/modules/libfb.so
[   253.744] (II) Module fb: vendor="X.Org Foundation"
[   253.744] 	compiled for 1.19.2, module version = 1.0.0
[   253.744] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   253.744] fbturbo: PreInit done
[   253.744] (==) Depth 24 pixmap format is 32 bpp
[   253.744] fbturbo: FBDevScreenInit 0
[   253.746] (II) FBTURBO(0): using backing store heuristics
[   253.748] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[   253.752] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[   253.753] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[   253.753] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[   253.753] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[   253.753] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[   253.753] (==) FBTURBO(0): Backing store enabled
[   253.754] (==) FBTURBO(0): DPMS enabled
[   253.754] (II) FBTURBO(0): failed to enable hardware cursor
[   253.754] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[   253.754] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[   253.754] fbturbo: FBDevScreenInit done
[   253.754] (==) RandR enabled
[   253.754] fbturbo: FBDevScreenInit 1
[   253.755] (II) FBTURBO(1): using backing store heuristics
[   253.757] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[   253.761] (II) FBTURBO(1): can't load 'g2d_23' kernel module
[   253.761] (II) FBTURBO(1): failed to enable the use of sunxi display controller
[   253.761] (II) FBTURBO(1): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[   253.761] (II) FBTURBO(1): G2D hardware acceleration can't be enabled
[   253.761] (II) FBTURBO(1): enabled fbdev copyarea acceleration
[   253.761] (==) FBTURBO(1): Backing store enabled
[   253.762] (==) FBTURBO(1): DPMS enabled
[   253.762] (II) FBTURBO(1): failed to enable hardware cursor
[   253.762] (II) FBTURBO(1): no 3D acceleration because the driver has been compiled without libUMP
[   253.762] (II) FBTURBO(1): if this is wrong and needs to be fixed, please check ./configure log
[   253.762] fbturbo: FBDevScreenInit done
[   253.762] (==) RandR enabled
[   253.782] (II) SELinux: Disabled on system
[   253.784] (II) AIGLX: Screen 0 is not DRI2 capable
[   253.784] (EE) AIGLX: reverting to software rendering
[   253.896] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[   253.898] (II) IGLX: Loaded and initialized swrast
[   253.898] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[   253.898] (II) AIGLX: Screen 1 is not DRI2 capable
[   253.898] (EE) AIGLX: reverting to software rendering
[   253.901] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[   253.904] (II) IGLX: Loaded and initialized swrast
[   253.904] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[   254.028] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/event3)
[   254.028] (**) Microsoft Microsoft IntelliMouse® Optical: Applying InputClass "libinput pointer catchall"
[   254.028] (II) LoadModule: "libinput"
[   254.029] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   254.034] (II) Module libinput: vendor="X.Org Foundation"
[   254.034] 	compiled for 1.19.0, module version = 0.23.0
[   254.035] 	Module class: X.Org XInput Driver
[   254.035] 	ABI class: X.Org XInput driver, version 24.1
[   254.035] (II) Using input driver 'libinput' for 'Microsoft Microsoft IntelliMouse® Optical'
[   254.100] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 21 paused 0
[   254.100] (**) Microsoft Microsoft IntelliMouse® Optical: always reports core events
[   254.100] (**) Option "Device" "/dev/input/event3"
[   254.101] (**) Option "_source" "server/udev"
[   254.103] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[   254.103] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[   254.103] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:0029.0006/input/input6/event3"
[   254.103] (II) XINPUT: Adding extended input device "Microsoft Microsoft IntelliMouse® Optical" (type: MOUSE, id 6)
[   254.104] (**) Option "AccelerationScheme" "none"
[   254.104] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) selected scheme none/0
[   254.104] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration factor: 2.000
[   254.104] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration threshold: 4
[   254.106] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[   254.106] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[   254.108] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/mouse1)
[   254.109] (II) No input driver specified, ignoring this device.
[   254.109] (II) This device may have been added with another device file.
[   254.111] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event0)
[   254.112] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   254.112] (II) Using input driver 'libinput' for '  USB Keyboard'
[   254.114] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 24 paused 0
[   254.114] (**)   USB Keyboard: always reports core events
[   254.114] (**) Option "Device" "/dev/input/event0"
[   254.115] (**) Option "_source" "server/udev"
[   254.117] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[   254.117] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[   254.117] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1603.0004/input/input4/event0"
[   254.117] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 7)
[   254.117] (**) Option "xkb_model" "pc105"
[   254.117] (**) Option "xkb_layout" "de"
[   254.203] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[   254.204] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[   254.206] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event1)
[   254.206] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   254.206] (II) Using input driver 'libinput' for '  USB Keyboard'
[   254.209] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[   254.209] (**)   USB Keyboard: always reports core events
[   254.209] (**) Option "Device" "/dev/input/event1"
[   254.209] (**) Option "_source" "server/udev"
[   254.211] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[   254.211] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[   254.212] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1603.0005/input/input5/event1"
[   254.212] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[   254.212] (**) Option "xkb_model" "pc105"
[   254.212] (**) Option "xkb_layout" "de"
[   254.214] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[   254.215] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[   254.216] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/event2)
[   254.216] (**) FT5406 memory based driver: Applying InputClass "libinput touchscreen catchall"
[   254.216] (**) FT5406 memory based driver: Applying InputClass "calibration"
[   254.216] (II) LoadModule: "evdev"
[   254.217] (WW) Warning, couldn't open module evdev
[   254.217] (II) UnloadModule: "evdev"
[   254.217] (II) Unloading evdev
[   254.217] (EE) Failed to load module "evdev" (module does not exist, 0)
[   254.217] (EE) No input driver matching `evdev'
[   254.217] (II) Falling back to input driver `libinput'
[   254.217] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[   254.219] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[   254.219] (**) FT5406 memory based driver: always reports core events
[   254.219] (**) Option "Device" "/dev/input/event2"
[   254.219] (**) Option "_source" "server/udev"
[   254.221] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[   254.221] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[   254.221] (**) Option "config_info" "udev:/sys/devices/virtual/input/input2/event2"
[   254.221] (II) XINPUT: Adding extended input device "FT5406 memory based driver" (type: TOUCHSCREEN, id 9)
[   254.222] (**) Option "AccelerationScheme" "none"
[   254.222] (**) FT5406 memory based driver: (accel) selected scheme none/0
[   254.222] (**) FT5406 memory based driver: (accel) acceleration factor: 2.000
[   254.222] (**) FT5406 memory based driver: (accel) acceleration threshold: 4
[   254.223] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[   254.223] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[   254.224] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/mouse0)
[   254.224] (**) FT5406 memory based driver: Applying InputClass "calibration"
[   254.224] (II) LoadModule: "evdev"
[   254.225] (WW) Warning, couldn't open module evdev
[   254.225] (II) UnloadModule: "evdev"
[   254.225] (II) Unloading evdev
[   254.225] (EE) Failed to load module "evdev" (module does not exist, 0)
[   254.225] (EE) No input driver matching `evdev'
[   254.225] (II) Falling back to input driver `libinput'
[   254.225] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[   254.225] (**) FT5406 memory based driver: always reports core events
[   254.225] (**) Option "Device" "/dev/input/mouse0"
[   254.225] (**) Option "_source" "server/udev"
[   254.300] (II) failed to create input device '/dev/input/mouse0'.
[   254.300] (EE) libinput: FT5406 memory based driver: Failed to create a device for /dev/input/mouse0
[   254.300] (EE) PreInit returned 2 for "FT5406 memory based driver"
[   254.300] (II) UnloadModule: "libinput"
and 3rd test
[   337.752]
[   337.807] X Protocol Version 11, Revision 0
[   337.822] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[   337.839] Current Operating System: Linux raspberrypi 4.14.61-v7+ #315 SMP Fri Aug 10 10:20:01 BST 2018 armv7l
[   337.839] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=e8348bf7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[   337.894] Build Date: 18 October 2017  04:55:30PM
[   337.918] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[   337.934] Current version of pixman: 0.34.0
[   337.973] 	Before reporting problems, check http://wiki.x.org
[   337.973] Markers: (--) probed, (**) from config file, (==) default setting,
[   338.046] (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sat Sep 15 10:45:25 2018
[   338.059] (==) Using config file: "/etc/X11/xorg.conf"
[   338.080] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   338.081] (**) Option "defaultserverlayout" "Singlehead0"
[   338.081] (++) ServerLayout "Multihead"
[   338.081] (**) |-->Screen "ScreenTurbo0" (0)
[   338.081] (**) |   |-->Monitor "Monitor0"
[   338.081] (**) |   |-->Device "fbturbo0"
[   338.081] (**) |-->Screen "ScreenTurbo1" (1)
[   338.082] (**) |   |-->Monitor "Monitor1"
[   338.082] (**) |   |-->Device "fbturbo1"
[   338.082] (**) Option "StandbyTime" "0"
[   338.082] (**) Option "SuspendTime" "0"
[   338.082] (**) Option "OffTime" "0"
[   338.082] (**) Option "Xinerama" "true"
[   338.082] (==) Automatically adding devices
[   338.082] (==) Automatically enabling devices
[   338.082] (==) Automatically adding GPU devices
[   338.082] (**) Xinerama: enabled
[   338.082] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   338.082] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[   338.083] 	Entry deleted from font path.
[   338.083] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   338.083] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   338.083] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   338.083] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   338.083] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   338.083] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   338.083] (==) FontPath set to:
	built-ins
[   338.083] (==) ModulePath set to "/usr/lib/xorg/modules"
[   338.083] (II) The server relies on udev to provide the list of input devices.
[   338.083] (II) Loader magic: 0x1fbf40
[   338.083] (II) Module ABI versions:
[   338.083] 	X.Org ANSI C Emulation: 0.4
[   338.083] 	X.Org Video Driver: 23.0
[   338.083] 	X.Org XInput driver : 24.1
[   338.083] 	X.Org Server Extension : 10.0
[   338.085] (++) using VT number 1
[   338.090] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c1
[   338.091] (II) no primary bus or device found
[   338.091] (II) LoadModule: "glx"
[   338.091] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   338.096] (II) Module glx: vendor="X.Org Foundation"
[   338.096] 	compiled for 1.19.2, module version = 1.0.0
[   338.096] 	ABI class: X.Org Server Extension, version 10.0
[   338.096] (II) LoadModule: "fbturbo"
[   338.097] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[   338.097] (II) Module fbturbo: vendor="X.Org Foundation"
[   338.097] 	compiled for 1.19.2, module version = 0.5.1
[   338.097] 	Module class: X.Org Video Driver
[   338.097] 	ABI class: X.Org Video Driver, version 23.0
[   338.097] (II) FBTURBO: driver for framebuffer: fbturbo
[   338.098] (WW) Falling back to old probe method for fbturbo
[   338.098] (II) Loading sub module "fbdevhw"
[   338.098] (II) LoadModule: "fbdevhw"
[   338.098] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   338.098] (II) Module fbdevhw: vendor="X.Org Foundation"
[   338.098] 	compiled for 1.19.2, module version = 0.0.2
[   338.098] 	ABI class: X.Org Video Driver, version 23.0
[   338.099] (II) FBTURBO(0): using /dev/fb0
[   338.099] (II) FBTURBO(1): using /dev/fb1
[   338.099] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   338.099] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[   338.099] (==) FBTURBO(0): RGB weight 888
[   338.099] (==) FBTURBO(0): Default visual is TrueColor
[   338.099] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[   338.099] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 8100kB)
[   338.099] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[   338.099] (**) FBTURBO(0): Option "debug" "true"
[   338.099] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[   338.100] (II) FBTURBO(0): processor: Unknown
[   338.100] (II) FBTURBO(0): checking modes against framebuffer device...
[   338.100] (II) FBTURBO(0): checking modes against monitor...
[   338.100] (--) FBTURBO(0): Virtual size is 1920x1080 (pitch 1920)
[   338.100] (**) FBTURBO(0):  Built-in mode "current"
[   338.100] (==) FBTURBO(0): DPI set to (96, 96)
[   338.100] (II) Loading sub module "fb"
[   338.100] (II) LoadModule: "fb"
[   338.100] (II) Loading /usr/lib/xorg/modules/libfb.so
[   338.101] (II) Module fb: vendor="X.Org Foundation"
[   338.101] 	compiled for 1.19.2, module version = 1.0.0
[   338.101] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   338.101] fbturbo: PreInit done
[   338.101] fbturbo: PreInit 1
[   338.101] (==) FBTURBO(1): Depth 24, (==) framebuffer bpp 32
[   338.101] (==) FBTURBO(1): RGB weight 888
[   338.101] (==) FBTURBO(1): Default visual is TrueColor
[   338.101] (==) FBTURBO(1): Using gamma correction (1.0, 1.0, 1.0)
[   338.101] (II) FBTURBO(1): hardware: BCM2708 FB (video memory: 1500kB)
[   338.101] (**) FBTURBO(1): Option "fbdev" "/dev/fb1"
[   338.101] (**) FBTURBO(1): Option "debug" "true"
[   338.101] (**) FBTURBO(1): Option "SwapbuffersWait" "true"
[   338.102] (II) FBTURBO(1): processor: Unknown
[   338.102] (II) FBTURBO(1): checking modes against framebuffer device...
[   338.102] (II) FBTURBO(1): checking modes against monitor...
[   338.102] (--) FBTURBO(1): Virtual size is 800x480 (pitch 800)
[   338.102] (**) FBTURBO(1):  Built-in mode "current"
[   338.102] (==) FBTURBO(1): DPI set to (96, 96)
[   338.102] (II) Loading sub module "fb"
[   338.102] (II) LoadModule: "fb"
[   338.102] (II) Loading /usr/lib/xorg/modules/libfb.so
[   338.102] (II) Module fb: vendor="X.Org Foundation"
[   338.102] 	compiled for 1.19.2, module version = 1.0.0
[   338.102] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   338.102] fbturbo: PreInit done
[   338.102] (==) Depth 24 pixmap format is 32 bpp
[   338.102] fbturbo: FBDevScreenInit 0
[   338.112] (II) FBTURBO(0): using backing store heuristics
[   338.114] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[   338.118] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[   338.118] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[   338.118] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[   338.118] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[   338.118] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[   338.118] (==) FBTURBO(0): Backing store enabled
[   338.119] (==) FBTURBO(0): DPMS enabled
[   338.119] (II) FBTURBO(0): failed to enable hardware cursor
[   338.119] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[   338.119] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[   338.119] fbturbo: FBDevScreenInit done
[   338.119] (==) RandR enabled
[   338.119] fbturbo: FBDevScreenInit 1
[   338.120] (II) FBTURBO(1): using backing store heuristics
[   338.122] (WW) LoadKernelModule: Setting of real/effective user Id to 0/0 failed[   338.126] (II) FBTURBO(1): can't load 'g2d_23' kernel module
[   338.126] (II) FBTURBO(1): failed to enable the use of sunxi display controller
[   338.126] (II) FBTURBO(1): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[   338.126] (II) FBTURBO(1): G2D hardware acceleration can't be enabled
[   338.126] (II) FBTURBO(1): enabled fbdev copyarea acceleration
[   338.126] (==) FBTURBO(1): Backing store enabled
[   338.127] (==) FBTURBO(1): DPMS enabled
[   338.127] (II) FBTURBO(1): failed to enable hardware cursor
[   338.127] (II) FBTURBO(1): no 3D acceleration because the driver has been compiled without libUMP
[   338.127] (II) FBTURBO(1): if this is wrong and needs to be fixed, please check ./configure log
[   338.127] fbturbo: FBDevScreenInit done
[   338.127] (==) RandR enabled
[   338.146] (II) SELinux: Disabled on system
[   338.148] (II) AIGLX: Screen 0 is not DRI2 capable
[   338.148] (EE) AIGLX: reverting to software rendering
[   338.261] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[   338.264] (II) IGLX: Loaded and initialized swrast
[   338.264] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[   338.264] (II) AIGLX: Screen 1 is not DRI2 capable
[   338.264] (EE) AIGLX: reverting to software rendering
[   338.267] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[   338.269] (II) IGLX: Loaded and initialized swrast
[   338.269] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[   338.393] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/event3)
[   338.393] (**) Microsoft Microsoft IntelliMouse® Optical: Applying InputClass "libinput pointer catchall"
[   338.393] (II) LoadModule: "libinput"
[   338.394] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   338.399] (II) Module libinput: vendor="X.Org Foundation"
[   338.399] 	compiled for 1.19.0, module version = 0.23.0
[   338.399] 	Module class: X.Org XInput Driver
[   338.399] 	ABI class: X.Org XInput driver, version 24.1
[   338.399] (II) Using input driver 'libinput' for 'Microsoft Microsoft IntelliMouse® Optical'
[   338.470] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 21 paused 0
[   338.470] (**) Microsoft Microsoft IntelliMouse® Optical: always reports core events
[   338.470] (**) Option "Device" "/dev/input/event3"
[   338.470] (**) Option "_source" "server/udev"
[   338.473] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[   338.473] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[   338.473] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0029.0009/input/input9/event3"
[   338.473] (II) XINPUT: Adding extended input device "Microsoft Microsoft IntelliMouse® Optical" (type: MOUSE, id 6)
[   338.474] (**) Option "AccelerationScheme" "none"
[   338.474] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) selected scheme none/0
[   338.474] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration factor: 2.000
[   338.474] (**) Microsoft Microsoft IntelliMouse® Optical: (accel) acceleration threshold: 4
[   338.477] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is tagged by udev as: Mouse
[   338.477] (II) input device 'Microsoft Microsoft IntelliMouse® Optical', /dev/input/event3 is a pointer caps
[   338.479] (II) config/udev: Adding input device Microsoft Microsoft IntelliMouse® Optical (/dev/input/mouse1)
[   338.479] (II) No input driver specified, ignoring this device.
[   338.479] (II) This device may have been added with another device file.
[   338.482] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event0)
[   338.482] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   338.482] (II) Using input driver 'libinput' for '  USB Keyboard'
[   338.485] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 24 paused 0
[   338.485] (**)   USB Keyboard: always reports core events
[   338.485] (**) Option "Device" "/dev/input/event0"
[   338.485] (**) Option "_source" "server/udev"
[   338.487] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[   338.487] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[   338.488] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:04D9:1603.0007/input/input7/event0"
[   338.488] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 7)
[   338.488] (**) Option "xkb_model" "pc105"
[   338.488] (**) Option "xkb_layout" "de"
[   338.574] (II) input device '  USB Keyboard', /dev/input/event0 is tagged by udev as: Keyboard
[   338.574] (II) input device '  USB Keyboard', /dev/input/event0 is a keyboard
[   338.577] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event1)
[   338.577] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
[   338.577] (II) Using input driver 'libinput' for '  USB Keyboard'
[   338.579] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[   338.579] (**)   USB Keyboard: always reports core events
[   338.579] (**) Option "Device" "/dev/input/event1"
[   338.579] (**) Option "_source" "server/udev"
[   338.582] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[   338.582] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[   338.582] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:04D9:1603.0008/input/input8/event1"
[   338.582] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
[   338.582] (**) Option "xkb_model" "pc105"
[   338.582] (**) Option "xkb_layout" "de"
[   338.585] (II) input device '  USB Keyboard', /dev/input/event1 is tagged by udev as: Keyboard
[   338.585] (II) input device '  USB Keyboard', /dev/input/event1 is a keyboard
[   338.586] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/event2)
[   338.586] (**) FT5406 memory based driver: Applying InputClass "libinput touchscreen catchall"
[   338.586] (**) FT5406 memory based driver: Applying InputClass "calibration"
[   338.586] (II) LoadModule: "evdev"
[   338.587] (WW) Warning, couldn't open module evdev
[   338.587] (II) UnloadModule: "evdev"
[   338.587] (II) Unloading evdev
[   338.587] (EE) Failed to load module "evdev" (module does not exist, 0)
[   338.587] (EE) No input driver matching `evdev'
[   338.587] (II) Falling back to input driver `libinput'
[   338.587] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[   338.589] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[   338.589] (**) FT5406 memory based driver: always reports core events
[   338.589] (**) Option "Device" "/dev/input/event2"
[   338.589] (**) Option "_source" "server/udev"
[   338.591] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[   338.591] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[   338.591] (**) Option "config_info" "udev:/sys/devices/virtual/input/input2/event2"
[   338.591] (II) XINPUT: Adding extended input device "FT5406 memory based driver" (type: TOUCHSCREEN, id 9)
[   338.591] (**) Option "AccelerationScheme" "none"
[   338.591] (**) FT5406 memory based driver: (accel) selected scheme none/0
[   338.591] (**) FT5406 memory based driver: (accel) acceleration factor: 2.000
[   338.591] (**) FT5406 memory based driver: (accel) acceleration threshold: 4
[   338.592] (II) input device 'FT5406 memory based driver', /dev/input/event2 is tagged by udev as: Touchscreen
[   338.593] (II) input device 'FT5406 memory based driver', /dev/input/event2 is a touch device
[   338.593] (II) config/udev: Adding input device FT5406 memory based driver (/dev/input/mouse0)
[   338.593] (**) FT5406 memory based driver: Applying InputClass "calibration"
[   338.594] (II) LoadModule: "evdev"
[   338.594] (WW) Warning, couldn't open module evdev
[   338.594] (II) UnloadModule: "evdev"
[   338.594] (II) Unloading evdev
[   338.594] (EE) Failed to load module "evdev" (module does not exist, 0)
[   338.594] (EE) No input driver matching `evdev'
[   338.594] (II) Falling back to input driver `libinput'
[   338.594] (II) Using input driver 'libinput' for 'FT5406 memory based driver'
[   338.594] (**) FT5406 memory based driver: always reports core events
[   338.594] (**) Option "Device" "/dev/input/mouse0"
[   338.594] (**) Option "_source" "server/udev"
[   338.670] (II) failed to create input device '/dev/input/mouse0'.
[   338.670] (EE) libinput: FT5406 memory based driver: Failed to create a device for /dev/input/mouse0
[   338.670] (EE) PreInit returned 2 for "FT5406 memory based driver"
[   338.670] (II) UnloadModule: "libinput"
Wed Sep 19, 2018 1:26 pm
Weird.
aBUGSworstnightmare
Wed Sep 19, 2018 1:43 pm
jamesh wrote:Weird.
Are you able to replicate?
Maybe it just happens with the the one RPi3 I'm using here.
raffie78
Fri Sep 21, 2018 8:15 am
First of all many thanks to your alternate firmware/kernel. I try to use it with Gert VGA666 but I'm not able to use second screen as xdesktop.
what I've done:
Gert VGA666 is tested as primary display, so I'm sure hardware is working fine
after that setup correct kernel with your framebuffer-firmware
ls /dev/fb* shows two fb-devices
secondary screen (via VGA666) turns on and shows blank screen (wasn't so before setup your firmware)
with fbi I'm able to put an image on second screen, so framebuffer seems to work correctly
how can I run a second desktop / xinerama-desktop on secondary screen?
I've had (with Jessie) an USB2VGA-DisplayLink configured with xorg.conf to have a secondary desktop with own window-manager. After updating to Stretch the DisplayLink-driver is not longer supported, so i removed my xorg.conf.
raffie78
Fri Sep 21, 2018 8:49 am
I fixed it - I had to change ColorDepth from 16 to 24bit and now all is working fine now
other question: will this firmware became part of the distro?
Melticus
Sun Sep 23, 2018 7:37 pm
Hi Guys,
been a while since I checked in here. I am the one who is using fb0 to display an image carosel using fbi on my hdmi screen, while displaying my gui on fb1 (LCD) using normal raspbian application.
So my problem is. If I do not connect the HDMI monitor, FBI just over writes my primary interface. (i.e. when HDMI is not connected, both the primary application and the carosel apps try to display on the LCD.
So My Question, Is there a way to confirm that the fb1 and fb0 are connected? If I can then I will check this before atempting to display my carosel.
I am using Raspberry PI 3
With Raspi version version: 4.14.50
Any help would be appreciated!
Matthew
Sun Sep 23, 2018 7:52 pm
Just check to see if /dev/fb0 and /dev/fb1 exist. Most programming languages allow you to stat a file like that.
You will only get the fb1 if two screens are atached.
Sun Sep 23, 2018 7:53 pm
Indeed - for a contiguous desktop, all the FB's must be compatible.
Yes, this will, I hope, become part of the main distro.
Melticus
Sun Sep 23, 2018 8:25 pm
Hay @jamesh I thought that to but when I ls /dev with one screen, I see both fb1 and fb0 even though hdmi is disconnected.
stating the two results in:
[email protected]:/dev $ stat fb1
File: fb1
Size: 0 Blocks: 0 IO Block: 4096 character special file
Device: 6h/6d Inode: 1109 Links: 1 Device type: 1d,1
Access: (0660/crw-rw----) Uid: ( 0/ root) Gid: ( 44/ video)
Access: 2018-09-23 19:04:13.279999999 +0000
Modify: 2018-09-23 19:04:13.279999999 +0000
Change: 2018-09-23 19:04:13.279999999 +0000
Birth: -
[email protected]:/dev $ stat fb0
File: fb0
Device: 6h/6d Inode: 1108 Links: 1 Device type: 1d,0
Access: 2018-09-23 19:04:13.329999999 +0000
Modify: 2018-09-23 19:04:13.329999999 +0000
Change: 2018-09-23 19:04:13.329999999 +0000
Birth: -
aBUGSworstnightmare
Mon Sep 24, 2018 5:30 am
Which resolution has your HDMI monitor and is the framebuffer of it - when monitor is not connected to HDMi - of same size?
I would try with below settings added to your config.txt
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
config_hdmi_boost=4
hdmi_group=2
hdmi_mode=x
Check the value for x from the table here https://www.raspberrypi.org/documentati ... t/video.md. Save and reboot.
This should mimik the RPi your HDMI is always connected.
Mon Sep 24, 2018 8:00 am
File: fb1
Birth: -
File: fb0
Birth: -
Ah, if HDMI is not detected, it assumes composite is attached,. Hmm, will need to think about that.
Melticus
Mon Sep 24, 2018 8:41 am
Sounds plausable, however if composite were enabled shouldent any writes to "hdmi" go to composite and be "lost"? What I am seeing is that the image I was sending to hdmi is being over written on the lcd.
fyi: When hdmi is connected, fb0 appears to be hdmi. fb1 is lcd. I hard code this in my call to fbi. Any chance that when the hdmi is not connected, lcd goes to fb0? and composit goes to fb1? this might explain the overwrite.
Mon Sep 24, 2018 9:12 am
Composite is always the lowest priority (to retain backward compatibility), and FB's are allocated in a priority order. So composite will be going to FB1 if HDMI is not connected.
aBUGSworstnightmare
Mon Sep 24, 2018 9:32 am
You're using this https://www.raspberrypi.org/forums/view ... 5#p1363839 already?
Make sure desktop goes to the screen which is always connected.
aBUGSworstnightmare
Mon Oct 15, 2018 7:41 am
Hi jamesh,
did any of the multiple framebuffer code made it into latest Raspbian release (2018-10-09)? If not, can you prepare files to test with latest version?
Mon Oct 15, 2018 7:46 am
Hi jamesh,
None of the code has been merged yet, I'll need to rebuild everything on the latest tree. Might be able to do in a few days.
aBUGSworstnightmare
Mon Oct 15, 2018 8:44 am
jamesh wrote: None of the code has been merged yet, I'll need to rebuild everything on the latest tree. Might be able to do in a few days.
Big thanks in advance!
JPB-HK
Tue Oct 16, 2018 3:40 am
Thanks, would be a great help!
Trying to develop a program that will display a GUI for user on 7" touch screen that will display an image on HDMI. Getting real close.
John
NCR 310 - ZX81 - Apple II+ - Dell/Intel - Mac mini... Raspberry Pi!
unbannable
Tue Oct 16, 2018 10:11 am
Does this work with the Gert VGA 666 adaptor?
aBUGSworstnightmare
Tue Oct 16, 2018 1:25 pm
this adapter is using the DPI interface so: yes, it works (although I never tested the VGA666).
Keep in mind that it will work togehter with HDMI only; DPI and DSI can't be used togehter!
Wed Oct 17, 2018 2:15 pm
Hi jamesh,
OK, have the images built, and put them here
https://drive.google.com/open?id=1Q5TQ1 ... 4UMavmTh7H
I think they work OK, haven't done a lot of testing, just merged to latest masters and rebuilt, with a very quick test to make sure framebuffer actually appeared.
This is 4.14.76, so slightly newer than the current release, so might be a modules mismatch.
