Eliter
Cheap Networking
Thu Jun 14, 2018 3:52 am
Hello, I wanted to know what the cheapest networking stategy is between Raspberry Pi's. Now, the Raspberry Pi zero (NOT W) is super cheap, but has no networking capabilities.
I wanted to know if it were possible to hook up a CAT5 cable to a Raspberry Pi's GPIO pins and be able to accomplish networking. If not, what is the absolute, rock-bottom, light-weight (physically), wired, cheap way to network two Raspberry Pi's together?
Thanks!
EDIT: More specifically what I am thinking of doing is to strip the end of a CAT5 cable so the wires are exposed, and solder the wires directly to the board. I don't need to unplug the cable or have a fancy port.
ejolson
Re: Cheap Networking
Thu Jun 14, 2018 4:14 am
Thanks!
The cheapest way to network a Pi Zero to another Pi is with a standard USB cable and the Ethernet gadget driver. An example where this is done is my super-cheap cluster of Raspberry Pi Zero computers.
klricks
Thu Jun 14, 2018 4:15 am
Thanks!
What is it that you want to accomplish by networking 2 RPis together?
Also depends on what you mean by 'networking'?
The GPIO can not be used to connect Ethernet networking directly. The GPIO can be used to send data back and forth by serial and several other means but you would have to write programs to send and get data.
The RJ45 connector has components inside the shell that must be present. You cannot direct wire the Ethernet from board to board. A proper CAT5/6 cable must be used.
Eliter
Thu Jun 14, 2018 4:39 am
I planned on using CAT5/6, but no RJ45 port.
I also was talking on ##networking from @freenode.net and they are saying that I should use pins 8 and 10 (https://pinout.xyz/pinout/serial_pi_plus# ) which are serial pins. On top of that, there was somthing about PPP, RS232, and Ethernet standards I could use. From my understanding, there are electrical protocols that I would use, and the internet protocol would sit on top of the electrical protocol that I choose. Not finished talking to these people, so I'm still gathering more info.
W. H. Heydt
Thu Jun 14, 2018 5:52 am
PPP is a software protocol, Point to Point Protocol, most often used as PPPoE, Point to Point Protocol Over Ethernet. RS-232 is a serial communication signalling standard. Ethernet comes in a variety of forms. The original form used a network backbone of 1" coaxial "cable". (I put the scare quotes on cable because the outer conductor of that is a solid Aluminum tube.) What you now think of Ethernet cabling is a point to point cabling system using unshielded twisted pair (UTP) with various "category" standards. Most common current ones in use are Cat-5, Cat-5e, and Cat-6. RJ-45 is the standard connector. (And for those not fully conversant with this stuff, the RJ-45 is an 8-pin connector that looks like the "big brother" of a 4-pin RJ-11 connector used for modular telephone cabling.) As already noted, the terminating connection for Ethernet over UTP is *not* just a simple. soldered connection.
So...what you have to decide is: What sort of physical connection do you want, and what sort of software stack do you want to run over it? As already mentioned, one of the simpler ones to set up is using TCP/IP over USB.
Probably the least expensive would be to use Pi0W boards instead of Pi0 and use the built-in wireless capability. That requires no extra hardware, and would be a cheaper solution than anything other than USB....and without the 5m cable limit.
Thu Jun 14, 2018 6:44 am
The Point To Point Protocol (PPP) is often used to make an IP connection over serial links. It can be used over other circuits but let's think about serial.
As such it enables two machines to make a network connection between themselves (point to point), that network connection can then be used like any other over ethernet, wifi, whatever.
The Serial Line Internet Protocol (SLIP) is an older, simpler, way of making a network connection over a serial link. Unless you are working with a small, speed and memory constrained microcontroller PPP is to be prefered.
So, one can link two Pi by joining their serial port connections (On the GPIO header) and configuring PPP to create network interfaces that use those ports.
I'd like to point you at some nice simple instructions on setting up such a PPP connection between Pi. But most of what I can find with google is very old articles and howtos or overly long and complicated or cluttered with info about modems or whatever the device is they are talking about.
Thu Jun 14, 2018 7:04 am
BINGO! Here is a nice simple article describing how to make a network connection between a Pi and PC running Linux using PPP.
http://www.instructables.com/id/Connect ... sing-UART/
The article uses a USB to serial converter to make the serial connection to the GPIO pins of the Pi but it should be easy enough to adapt those instructions for a GPIO to GPIO serial connection between Pi.
Remember this is a point to point link, not a network as such, so if you want to connect multiple Pi together you will need to find more serial ports...
RaTTuS
Contact: Twitter YouTube
Thu Jun 14, 2018 8:19 am
viewtopic.php?f=44&t=51633&start=25#p828064
will connect raspberrys via serial lines and make them appear on the network
should work for Stretch
Covfefe
hippy
Thu Jun 14, 2018 9:14 am
The 'no additional hardware except wire or cable' options for a Pi Zero are PPP/SLIP or USB Ethernet Gadget Mode.
MagPi had an article on connecting two Pi computers together using serial but I am afraid I don't recall which issue off-hand.
The better choice IMO is to choose a Zero W over a Pi Zero and go wireless.
Gavinmc42
Thu Jun 14, 2018 11:08 am
You could used a RS485 chip attached to the UART and still use the CAT5 cable.
Full duplex needs 2 pairs.
I'm dancing on Rainbows.
Ernst
Thu Jun 14, 2018 11:53 am
Magpi #41 "SHARE INTERNET TO THE RASPBERRY PI ZERO"
ghellquist
Wed Jun 20, 2018 5:38 am
Do consider the speed you want, Raw speed on Ethernet 10 MBits/sec meaning 10,000,000, raw speed on serial perhaps 115,200.
hippy
Thu Jun 21, 2018 11:16 am
Many on-chip UART's and USB-to-Serial chips can pump out 1 Mbps and often more. I recall it being said the Pi could theoretically handle up to 250 Mbps but not sure which UART and not sure that would actually be achievable.
The MagPi project linked to above for enabling UART PPP between Pi's appears to use 16MHz clocking. That's possibly 1 Mbps; not sure what the division ratio is.
The main limitation is wiring and distance, plus of course having software able to accumulate data coming in at that sustained rate.
