9acca9
Released button.
Tue Jun 12, 2018 7:52 pm
Hi.Could someone pass me a code to print "Button released" ???
The truth is that I was testing several codes and I can not find the correct one.
In other words, the message "Button released" appears when a button that is always closed is released.
Greetings and many thanks
this is my button.
B.Goode
Re: Released button.
Tue Jun 12, 2018 7:58 pm
The gpiozero python library module has a basic 'recipe' that demonstrates this: https://gpiozero.readthedocs.io/en/stab ... tml#button
(Scroll down to after the blue 'Note', where it says "Similarly, functions can be attached to button releases:")
Z80 Refugee
Wed Jun 13, 2018 9:34 am
Your button will not be reliable unless it is wired correctly. See the link below, and scroll down to "Hardware Interfacing".
viewtopic.php?f=34&t=207597
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
texy
Wed Jun 13, 2018 11:12 am
this is my button.
you need to confirm which language you are using, the assumption is python, in which case, B.Goode has shown a good link to help.
Also with any Input you need to be aware of 'floating' pins, so if pull-ups are not utilised, either internal or external, then you may not be getting the results you expect.
Texy
hippy
Wed Jun 13, 2018 11:15 am
In pseudo code ...
Do
  Do : Loop until Input == 0
  Print "Button pushed"
  Do : Loop until Input != 0
  Print "Button released"
Loop
Change the 0's to 1's if it's working the wrong way round, showing "release" when pushed.
