Z80 Refugee wrote: ↑Mon May 28, 2018 6:41 pm
This won't be easy. At the input side, you need to accommodate potential accidental reverse polarity (somebody connects a battery the wrong way around), voltage dips and spikes, and "load dump" (the alternator output suddenly losing regulation and reaching 60V or more). You need to ensure the unit cannot drain the battery when the ignition is off.
I have a plan for power-on/power-off according to ignition status. I am planning to watch linbus+ignition+key_in cables to decide power on and off. This will be done by a micro-controller.
However voltage dips, spikes and load dumps I dont know how to create a power supply accordingly. I couldnt find schematics for them. Also I couldnt find good resource too. My problem is the basic electronics for buck converters I just started to learn their characteristics. I ordered some buck converters from china to use in my project but I dont think they are reliable to use with car. I will use them only at home to make experiments.
Please if you know any resource about how to design proper power supply share with me.
Internally, you will need to ensure the unit complies with automotive standards for Electromagnetic Compatibility - that a certain level of external conducted or radiated interference over a specific frequency range doesn't adversely affect operation (or if it does that it fails safe), and that it does not emit interference by conduction or radiation. Compliance to the appropriate standards will need to be independently tested and certified.
I dont plan it to make a final product which will sold to people seriously. I am doing it for myself, but I may sell few to people. In anyway I will share all the codes and hardware schematics. So nothing that serious.
That's what "automotive grade" means (and more), so if this is a commercial project that's what you will need to tackle. If this is a home brew project, you can do what you like - but don't claim it is automotive grade.
I meant automotive grade because I want a power supply which can work with car battery, sorry if it means further than I tried to tell.
So what would be your suggestion which way I should start? Try to make seperate converters for 3.3, 1.8 and 5V or first regulate 12V as safe 12 then convert to other voltages?
