CalumJEadie
Omxplayer support for console YouTube client - yt
Mon Oct 29, 2012 6:07 pm
yt - a command line YouTube client, now has Omxplayer support.
yt allows you to browse YouTube videos quickly through a command line client and can now take advantage of Omxplayer for hardware accelerated YouTube playback.
Check out the project at https://github.com/rjw57/yt and get it up and running with:
sudo apt-get install youtube-dl # Installs dependancies.
sudo youtube-dl -U # Makes sure latest version is used.
sudo apt-get install python-setuptools
sudo easy_install whitey # Install yt - different name used to avoid conflict with existing project.
yt --player omxplayer # Specify Omxplayer rather than default MPlayer.
Thanks to:
jimb137
Re: Omxplayer support for console YouTube client - yt
Thu Dec 20, 2012 1:35 am
I tried these simple steps with the 12/16 release, and all I got was a couple of screens of errors. Anyone interested in them? Any ideas how to proceed?
CalumJEadie
Thu Dec 20, 2012 4:49 pm
jimb137 wrote:I tried these simple steps with the 12/16 release, and all I got was a couple of screens of errors. Anyone interested in them? Any ideas how to proceed?
Hey jimb137,
May be able to help you out! Let me know the errors and I'll have a look (if there's a lot probaby best we http://pastebin.com/).
Cheers,
Calum
jimb137
Thu Dec 20, 2012 8:36 pm
OK, Here 'tis
[email protected] ~ $ yt --player omxplayer
File "/usr/local/bin/yt", line 9, in <module>
load_entry_point('whitey==0.2', 'console_scripts', 'yt')()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.2-py2.7.egg/yt/__init__.py", line 28, in main
ui.run()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.2-py2.7.egg/yt/__init__.py", line 71, in run
curses.wrapper(self._curses_main)
File "/usr/lib/python2.7/curses/wrapper.py", line 43, in wrapper
return func(stdscr, *args, **kwds)
File "/usr/local/lib/python2.7/dist-packages/whitey-0.2-py2.7.egg/yt/__init__.py", line 114, in _curses_main
self._update_screen()
File "/usr/local/lib/python2.7/dist-packages/whitey-0.2-py2.7.egg/yt/__init__.py", line 172, in _update_screen
self._add_table_row(self._help, 0, 0, w-1, self._bar_attr, max_width=16, win=self._help_bar)
File "/usr/local/lib/python2.7/dist-packages/whitey-0.2-py2.7.egg/yt/__init__.py", line 349, in _add_table_row
win.addstr(y, x, truncate('%s:%s' % (k,v), min(w-x, cell_w)).encode(self._code), attr)
UnicodeEncodeError: 'latin-1' codec can't encode character u'\u2026' in position 12: ordinal not in range(256)
have fun with this... I'll be back from holiday in January
pesch
Sun Jan 13, 2013 4:46 pm
jimb137 wrote:OK, Here 'tis
ui.run()
I posted a solution in this previous post http://www.raspberrypi.org/phpBB3/viewt ... 57&p=98096 Check your locale and make sure it supports Unicode.
