badx
Set up your WordPress Database
Sat May 19, 2018 4:21 pm
When I "sudo mysql_secure_installation"
I get: sudo: mysql_secure_installation: command not found
What should I do?
Everything else went fine
ghellquist
Re: Set up your WordPress Database
Sun May 20, 2018 8:10 am
It helps if you include a link to the instructions your are following, or even better, copy them in you question. The databas mysql is used to store information used by the wordpress code. There is nothing special about that installation, but there are a number of steps you need to follow. It might be that some of these steps are in the mysql_secure_installation which you referr to, and I have never heard of before ( which might say more about my ignorance than anything else ).
fbe
Sun May 20, 2018 7:12 pm
What should I do?
If everything else went fine, there's nothing to do.
If you use Raspbian Stretch and
gives you the error message
then you still didn't install mariadb-server. Otherwise you would find it in /usr/bin.
To install WordPress, you could follow this tutorial https://projects.raspberrypi.org/en/pro ... -wordpress up to "Install PHP".
Page "Install MySQL" should now be titled "Install MariaDB".
sudo apt-get install mariadb-server php-mysql -y
mysql-server is still accepted but mariadb-server is installed anyway. Then restart Apache.
The page "Download WordPress" is working as described.
The "Set up your WordPress Database" page is outdated and misleading. Don't run mysql_secure_installation! The Debian installation of MariaDB doesn't create anonymous or remote root users or test databases, so there's nothing to remove, and the created database root users password is ignored.
Simply type
sudo mysql
to login as root to your local MariaDB server.
Then create your wordpress database and an user with all privileges for this database (replace secret with a strong password).
create database wordpress;
GRANT ALL PRIVILEGES ON wordpress.* TO [email protected] IDENTIFIED BY  'secret';
exit;
It is not needed to grant privileges on wordpress to the database root user. He is Chuck Norris. He already has all of them.
It is not needed to flush privileges, if you used SQL GRANT statements.
On the next page "WordPress configuration" use wpadmin (and your password for wpadmin) instead of root.
