bjrobert
mirrors.opencas.cn mirror can not be reached
Mon May 07, 2018 2:05 am
I am newer on rasp and I live in Beijing.
I want to program on ubuntu pc host for my raspberry pi 3+. According to the web: https://wiki.qt.io/RaspberryPi2EGLFS, I step by step for setting the cross compile env. Using the latest Lite image on raspberry, in step 5 [on RPi] Install a bunch of development files. When I run the command on raspberry: "sudo apt-get build-dep qt4-x11", I got the error messages as following. The main reason is that the mirrors.opencas.cn is not reached. And I checked this host, it is not connected, but I do not know how to change the address in the system. Please give me advise.
Thanks in advance!
Robert
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxcomposite/libxcomposite-dev_0.4.4-2_armhf.deb  Cannot initiate t
he connection to mirrors.opencas.cn:80 (2001:cc0:2020:4075::211). - connect (101: Network is unreachable) [IP: 2001:cc0:2020:4075::211 80]
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/l/lcms2/liblcms2-dev_2.8-4_armhf.deb  Cannot initiate the connection to m
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libt/libtool/libltdl7_2.4.6-2_armhf.deb  Cannot initiate the connection t
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libt/libtool/libltdl-dev_2.4.6-2_armhf.deb  Cannot initiate the connectio
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/u/unixodbc/libodbc1_2.3.4-1_armhf.deb  Cannot initiate the connection to
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/r/readline/libreadline-dev_7.0-3_armhf.deb  Cannot initiate the connectio
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/s/sqlite/libsqlite0_2.8.17-14_armhf.deb  Cannot initiate the connection t
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/s/sqlite/libsqlite0-dev_2.8.17-14_armhf.deb  Cannot initiate the connecti
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxt/libxt-dev_1.1.5-1_armhf.deb  Cannot initiate the connection to
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxmu/libxmu6_1.1.2-2_armhf.deb  Cannot initiate the connection to
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxmu/libxmu-headers_1.1.2-2_all.deb  Cannot initiate the connectio
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxmu/libxmu-dev_1.1.2-2_armhf.deb  Cannot initiate the connection
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxslt/libxslt1.1_1.1.29-2.1_armhf.deb  Cannot initiate the connect
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxslt/libxslt1-dev_1.1.29-2.1_armhf.deb  Cannot initiate the conne
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxtst/libxtst6_1.2.3-1_armhf.deb  Cannot initiate the connection t
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/x/x11proto-record/x11proto-record-dev_1.14.2-1_all.deb  Cannot initiate t
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxtst/libxtst-dev_1.2.3-1_armhf.deb  Cannot initiate the connectio
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libx/libxv/libxv1_1.0.11-1_armhf.deb  Cannot initiate the connection to m
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/x/x11proto-video/x11proto-video-dev_2.3.3-1_all.deb  Cannot initiate the
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/u/unixodbc/odbcinst1debian2_2.3.4-1_armhf.deb  Cannot initiate the connec
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/u/unixodbc/odbcinst_2.3.4-1_armhf.deb  Cannot initiate the connection to
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/p/pkg-kde-tools/pkg-kde-tools_0.15.24_all.deb  Cannot initiate the connec
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/u/unixodbc/unixodbc-dev_2.3.4-1_armhf.deb  Cannot initiate the connection
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
E: Failed to process build dependencies
[email protected]:~ $
bjrobert
Re: mirrors.opencas.cn mirror can not be reached
Thu May 10, 2018 6:52 am
any response?
6by9
Thu May 10, 2018 10:21 am
That host is accessible from the UK, and I can see at least the first of those files is there.
At a guess something in your network isn't capable of routing IPv6, but it has looked up the address as an IPv6 address (IP: 2001:cc0:2020:4075::211).
You could try temporarily disabling IPv6 ("sudo sh -c 'echo 1 > /proc/sys/net/ipv6/conf/eth0/disable_ipv6'" according to http://ask.xmodulo.com/disable-ipv6-linux.html) to see if it will drop back to IPv4.
bjrobert
Fri May 11, 2018 6:02 am
Thanks for your response. I have checked in my raspberry pi3 , checked with ifconfig:
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.16.1.71  netmask 255.255.255.0  broadcast 172.16.1.255
        inet6 fe80::d5f7:b956:8ced:943a  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:13:ac:98  txqueuelen 1000  (Ethernet)
        RX packets 7519  bytes 5298961 (5.0 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5540  bytes 511162 (499.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
and disable ipv6 with sudo sh -c 'echo 1 > /proc/sys/net/ipv6/conf/all/disable_ipv6'
        RX packets 20944  bytes 22701763 (21.6 MiB)
        TX packets 13180  bytes 1263882 (1.2 MiB)
But, in my new SD with latest raspbian on raspberry pi3 (whenever disabled ipv6 or not), I has the same problem to install git (a week ago, I can install git with the same env):
[email protected]:~ $ sudo apt-get install git
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  git-man liberror-perl
Suggested packages:
  git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
  gitweb git-arch git-cvs git-mediawiki git-svn
The following NEW packages will be installed:
  git git-man liberror-perl
0 upgraded, 3 newly installed, 0 to remove and 2 not upgraded.
Need to get 4839 kB of archives.
After this operation, 26.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:2 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf git-man all 1:2.11.0-3+deb9u2 [1432 kB]
Get:3 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf git armhf 1:2.11.0-3+deb9u2 [3380 kB]
93% [Connecting to mirrors.opencas.cn (124.16.75.211)]^C
How do I do to disable to visit mirrors.opencas.cn?
bjrobert
Fri May 11, 2018 6:21 am
Here is the total list to install git:
Suggested packages:
Err:1 http://mirrors.opencas.cn/raspbian/raspbian stretch/main armhf liberror-perl all 0.17024-1
  Could not connect to mirrors.opencas.cn:80 (124.16.75.211), connection timed out
Fetched 4812 kB in 2min 1s (39.8 kB/s)
E: Failed to fetch http://mirrors.opencas.cn/raspbian/raspbian/pool/main/libe/liberror-perl/liberror-perl_0.17024-1_all.deb  Could not connect to mirrors.opencas.cn:80 (124.16.75.211), connection timed out
bjrobert
Sun May 13, 2018 8:39 am
I am still fail to install git, which need mirrors.opencas.cn, but it is not reachable.
Sun May 13, 2018 8:42 am
Try updating your /etc/apt/sources.list file to use mirrors.zju.edu.cn or mirrors.cqu.edu.cn or mirrors.shu.edu.cn
bjrobert
Thu May 17, 2018 8:08 am
My /etc/apt/sources.list file is original one, I do not modified it. Here is the content as following. There is not any address about mirrors.opencas.cn. I do not know how to remove it, maybe I am in China, the raspbian.raspberrypi.org/raspbian/ will forward to mirrors.opencas.cn, but it is unreachable in China.
I took many days to solve this problem, but it has existed. I plan to give up to use raspberry pi.
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Thu May 17, 2018 8:31 am
Change the url from
to
deb http://mirrors.zju.edu.cn/raspbian/ stretch main contrib non-free rpi
then run sudo apt-get update; sudo apt-get -y dist-upgrade; sudo apt-get update
Then you should be able to change it back to the original.
bjrobert
Tue May 22, 2018 1:07 am
Changed to http://mirrors.zju.edu.cn/raspbian , but when I run sudo apt-get update I got the following error info:
it does not solve the problem. Anyway, thanks for you advise!
[email protected]:~ $ sudo apt-get update
Ign:1 http://mirrors.zju.edu.cn/raspbian stretch InRelease
Ign:2 http://mirrors.zju.edu.cn/raspbian stretch Release
Ign:3 http://mirrors.zju.edu.cn/raspbian stretch/main armhf Packages
Ign:4 http://mirrors.zju.edu.cn/raspbian stretch/main all Packages
Ign:5 http://mirrors.zju.edu.cn/raspbian stretch/main Translation-en_GB
Ign:6 http://mirrors.zju.edu.cn/raspbian stretch/main Translation-en
Ign:7 http://mirrors.zju.edu.cn/raspbian stretch/contrib armhf Packages
Ign:8 http://mirrors.zju.edu.cn/raspbian stretch/contrib all Packages
Ign:9 http://mirrors.zju.edu.cn/raspbian stretch/contrib Translation-en_GB
Ign:10 http://mirrors.zju.edu.cn/raspbian stretch/contrib Translation-en
Ign:11 http://mirrors.zju.edu.cn/raspbian stretch/non-free armhf Packages
Ign:12 http://mirrors.zju.edu.cn/raspbian stretch/non-free all Packages
Ign:13 http://mirrors.zju.edu.cn/raspbian stretch/non-free Translation-en
Ign:14 http://mirrors.zju.edu.cn/raspbian stretch/non-free Translation-en_GB
Ign:15 http://mirrors.zju.edu.cn/raspbian stretch/rpi armhf Packages
Ign:16 http://mirrors.zju.edu.cn/raspbian stretch/rpi all Packages
Ign:17 http://mirrors.zju.edu.cn/raspbian stretch/rpi Translation-en_GB
Ign:18 http://mirrors.zju.edu.cn/raspbian stretch/rpi Translation-en
Err:3 http://mirrors.zju.edu.cn/raspbian stretch/main armhf Packages
  404  Not Found [IP: 210.32.158.231 80]
Get:19 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:20 http://archive.raspberrypi.org/debian stretch/main armhf Packages [159 kB]
Get:21 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [31.4 kB]
Fetched 216 kB in 8s (24.0 kB/s)
W: The repository 'http://mirrors.zju.edu.cn/raspbian stretch Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://mirrors.zju.edu.cn/raspbian/dists/stretch/main/binary-armhf/Packages  404  Not Found [IP: 210.32.158.231 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
bjrobert
Tue May 22, 2018 1:21 am
And I change back to http://raspbian.raspberrypi.org/raspbian , then sudo apt-get update; sudo apt-get -y dist-upgrade; sudo apt-get update;
Then sudo apt-get install git, it do not use mirrors.opencas.cn and it works to finish. Thanks a lot.
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Fetched 11.7 MB in 1min 50s (106 kB/s)
[email protected]:~ $ sudo apt-get -y dist-upgrade
Calculating upgrade... Done
The following packages will be upgraded:
  raspi-config
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 20.1 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian stretch/ui armhf raspi-config all 20180518 [20.1 kB]
Fetched 20.1 kB in 0s (27.8 kB/s)
apt-listchanges: Reading changelogs...
(Reading database ... 34361 files and directories currently installed.)
Preparing to unpack .../raspi-config_20180518_all.deb ...
Unpacking raspi-config (20180518) over (20180406+1) ...
Setting up raspi-config (20180518) ...
Processing triggers for systemd (232-25+deb9u2) ...
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Suggested packages:
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 26.9 kB/4,839 kB of archives.
Get:1 http://mirrors.zju.edu.cn/raspbian/raspbian stretch/main armhf liberror-perl all 0.17024-1 [26.9 kB]
Fetched 26.9 kB in 2s (9,758 B/s)
Selecting previously unselected package liberror-perl.
Preparing to unpack .../liberror-perl_0.17024-1_all.deb ...
Unpacking liberror-perl (0.17024-1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../git-man_1%3a2.11.0-3+deb9u2_all.deb ...
Unpacking git-man (1:2.11.0-3+deb9u2) ...
Selecting previously unselected package git.
Preparing to unpack .../git_1%3a2.11.0-3+deb9u2_armhf.deb ...
Unpacking git (1:2.11.0-3+deb9u2) ...
Setting up git-man (1:2.11.0-3+deb9u2) ...
Setting up liberror-perl (0.17024-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up git (1:2.11.0-3+deb9u2) ...
cpo
Tue May 22, 2018 9:12 am
https://www.raspbian.org/RaspbianMirrors contains a list of alternate servers.
Choose one from the list that is in China, but not opencas.cn and update sources.list.
Step-By-Step
1) edit the sources.list by typing
sudo nano /etc/apt/sources.list
2) Change
to
#deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
3) add the line
deb http://mirrors.shu.edu.cn/raspbian/raspbian/ stretch main contrib non-free rpi to the bottom of the file. (No it doesn't matter where you add it.)
4) Save and exit nano (Ctrl-O, then Ctrl-X). If you cannot save the file, it probably means you did not put "sudo" in front the nano command
5) Run the following
sudo apt-get update && sudo apt-get -y dist-upgrade && sudo apt-get update
bjrobert
Wed May 23, 2018 9:25 am
Hi cpo,
I tried a lot of the mirrors on the list, but they forward mirrors.opencas.cn, I think that the raspberry.org has the config for it. In the last two days ago. It worked well, and do not go to the mirrors.opencas.cn, which is in my last comments. Thanks.
Alectro
Sun May 27, 2018 3:42 pm
thanks a lot, this works.
plugwash
Thu Jun 28, 2018 2:17 pm
The problem is the mirror is IPv6 only but the mirror redirection system wasn't aware of that fact. So it was sending ipv4 clients to it.
I have updated the settings in the mirror redirection system so ipv4 clients should no longer be sent to that mirror.
auberonx
Sat Jul 07, 2018 6:15 pm
Hi all,
It's really good to see this topic is being discussed. I followed the solutions suggested above but to no avail.
1) I commented out
# deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
2) left this line untouched
3) and added this line
deb http://mirrors.shu.edu.cn/raspbian/ stretch main contrib non-free rpi
Then I ran the following two commands with the following output:
~ $ sudo apt-get update; sudo apt-get -y dist-upgrade; sudo apt-get update
Ign:17 http://mirrors.shu.edu.cn/raspbian stretch/non-free Translation-en_US
W: The repository 'http://mirrors.shu.edu.cn/raspbian stretch Release' does not have a Release file.
E: Failed to fetch http://mirrors.shu.edu.cn/raspbian/dist ... f/Packages 404 Not Found
~ $ sudo apt-get install ufw
Package ufw is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ufw' has no installation candidate
auberonx
Sun Jul 08, 2018 6:16 am
Hi! I'd like to address my own post from just now.
I did come across https://www.raspbian.org/RaspbianMirrors
and many of those sources work great! http://mirrors.neusoft.edu.cn/raspbian/raspbian worked like a charm.
Hope this will be helpful to some other noobs out there!
plugwash
Thu Jul 12, 2018 6:41 pm
The url for using that mirror in an apt source is http://mirrors.shu.edu.cn/raspbian/raspbian/ not http://mirrors.shu.edu.cn/raspbian/
bjrobert
Tue Nov 13, 2018 8:17 am
today, I used PI0 with new lite image. And when I used dist-upgrade, and I got the same issue as following
[email protected]:~ $ sudo apt-get dist-upgrade
curl gnupg gnupg-agent gpgv libcurl3 libcurl3-gnutls libgnutls30 libpam-systemd libseccomp2 libsystemd0 libtirpc1 libudev1
libx11-6 libx11-data libxapian30 systemd systemd-sysv tzdata udev wpasupplicant
20 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 10.5 MB of archives.
After this operation, 8192 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf systemd-sysv armhf 232-25+deb9u6 [81.4 kB]
Get:2 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libpam-systemd armhf 232-25+deb9u6 [174 kB]
Get:3 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libsystemd0 armhf 232-25+deb9u6 [257 kB]
Get:4 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf systemd armhf 232-25+deb9u6 [2220 kB]
Get:5 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf udev armhf 232-25+deb9u6 [1071 kB]
Get:6 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libudev1 armhf 232-25+deb9u6 [120 kB]
Get:7 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libseccomp2 armhf 2.3.1-2.1+deb9u1 [32.3 kB]
Err:8 http://mirrors.opencas.cn/raspbian/raspbian stretch/main armhf gpgv armhf 2.1.18-8~deb9u3
Cannot initiate the connection to mirrors.opencas.cn:80 (2001:cc0:2020:4075::211). - connect (101: Network is unreachable)
Err:9 http://mirrors.opencas.cn/raspbian/raspbian stretch/main armhf gnupg-agent armhf 2.1.18-8~deb9u3
Err:10 http://mirrors.opencas.cn/raspbian/raspbian stretch/main armhf gnupg armhf 2.1.18-8~deb9u3
Get:11 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf tzdata all 2018g-0+deb9u1 [270 kB]
Get:12 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libxapian30 armhf 1.4.3-2+deb9u2 [953 kB]
Get:13 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libgnutls30 armhf 3.5.8-5+deb9u4 [824 kB]
Get:14 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libtirpc1 armhf 0.2.5-1.2+deb9u1 [68.8 kB]
Get:15 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf curl armhf 7.52.1-5+deb9u8 [220 kB]
Get:16 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libcurl3 armhf 7.52.1-5+deb9u8 [262 kB]
Get:17 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libcurl3-gnutls armhf 7.52.1-5+deb9u8 [259 kB]
Get:18 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libx11-data all 2:1.6.4-3+deb9u1 [287 kB]
Get:19 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf libx11-6 armhf 2:1.6.4-3+deb9u1 [682 kB]
Get:20 http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian stretch/main armhf wpasupplicant armhf 2:2.4-1+deb9u2 [793 kB]
Fetched 8574 kB in 12s (705 kB/s)
E: Failed to fetch http://mirrors.opencas.cn/raspbian/rasp ... _armhf.deb Cannot initiate the connection to mirrors.opencas.cn:80 (2001:cc0:2020:4075::211). - connect (101: Network is unreachable)
And using cpo & plugwash suggestion:
2) Change
to
3) add the line
udo apt-get update && sudo apt-get dist-upgrade and sudo apt-get install git as following:
Get:1 http://mirrors.shu.edu.cn/raspbian/raspbian stretch InRelease [15.0 kB]
Get:2 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf Packages [11.7 MB]
Hit:3 http://archive.raspberrypi.org/debian stretch InRelease
Get:4 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/contrib armhf Packages [56.9 kB]
Get:5 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/non-free armhf Packages [95.5 kB]
Get:6 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/rpi armhf Packages [1360 B]
Fetched 11.8 MB in 35s (335 kB/s)
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 1963 kB of archives.
After this operation, 5120 B of additional disk space will be used.
Get:1 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf gpgv armhf 2.1.18-8~deb9u3 [442 kB]
Get:2 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf gnupg-agent armhf 2.1.18-8~deb9u3 [499 kB]
Get:3 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf gnupg armhf 2.1.18-8~deb9u3 [1022 kB]
Fetched 1963 kB in 1s (1352 kB/s)
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
Reading changelogs... Done
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_TIME = "zh_CN.UTF-8",
LC_MONETARY = "zh_CN.UTF-8",
LC_ADDRESS = "zh_CN.UTF-8",
LC_TELEPHONE = "zh_CN.UTF-8",
LC_NAME = "zh_CN.UTF-8",
LC_MEASUREMENT = "zh_CN.UTF-8",
LC_IDENTIFICATION = "zh_CN.UTF-8",
LC_NUMERIC = "zh_CN.UTF-8",
LC_PAPER = "zh_CN.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
locale: Cannot set LC_ALL to default locale: No such file or directory
(Reading database ... 34598 files and directories currently installed.)
Preparing to unpack .../gpgv_2.1.18-8~deb9u3_armhf.deb ...
Unpacking gpgv (2.1.18-8~deb9u3) over (2.1.18-8~deb9u2) ...
Setting up gpgv (2.1.18-8~deb9u3) ...
Preparing to unpack .../gnupg-agent_2.1.18-8~deb9u3_armhf.deb ...
Unpacking gnupg-agent (2.1.18-8~deb9u3) over (2.1.18-8~deb9u2) ...
Setting up gnupg-agent (2.1.18-8~deb9u3) ...
Preparing to unpack .../gnupg_2.1.18-8~deb9u3_armhf.deb ...
Unpacking gnupg (2.1.18-8~deb9u3) over (2.1.18-8~deb9u2) ...
Setting up gnupg (2.1.18-8~deb9u3) ...
Processing triggers for install-info (6.3.0.dfsg.1-1+b1) ...
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn
Need to get 4849 kB of archives.
After this operation, 26.4 MB of additional disk space will be used.
Get:1 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf liberror-perl all 0.17024-1 [26.9 kB]
Get:2 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf git-man all 1:2.11.0-3+deb9u4 [1433 kB]
Get:3 http://mirrors.shu.edu.cn/raspbian/raspbian stretch/main armhf git armhf 1:2.11.0-3+deb9u4 [3390 kB]
Fetched 4849 kB in 2s (1768 kB/s)
LANGUAGE = (unset),
LC_ALL = (unset),
Preparing to unpack .../git-man_1%3a2.11.0-3+deb9u4_all.deb ...
Unpacking git-man (1:2.11.0-3+deb9u4) ...
Preparing to unpack .../git_1%3a2.11.0-3+deb9u4_armhf.deb ...
Unpacking git (1:2.11.0-3+deb9u4) ...
Setting up git-man (1:2.11.0-3+deb9u4) ...
Setting up git (1:2.11.0-3+deb9u4) ...
