jromang
Re: Printable paper case project
Fri Jan 06, 2012 12:09 pm
Hello, I tried to search in the forum but didn't find a simple printable paper case for raspberry pi. Here is my first attempt with inkscape, of course holes and closing system a still needed, but the dimensions should be fine. I'll post updates if someone is interested, here is the link to the SVG file if someone wants to contibute : http://dl.dropbox.com/u/3042900/raspber ... ercase.svg
Jongoleur
Location: O'erlooking the sea, and all those effin windfarms...
Fri Jan 06, 2012 1:24 pm
Looks good, I've an Arduino Uno that was supplied in a card box that was similar and had dotted areas to cut out for the USB and power sockets.  A tab and slot arrangement on the lid should keep the top closed adequately.
I'm just a bouncer, splatterers do it with more force.....
mobeyduck
Fri Jan 06, 2012 2:34 pm
Maeur1 posted a nice paper case in "cases for the raspberry pi"
He posted the design a page later http://www.raspberrypi.org/for.....age-14#268
---edit---
On page 23 some one else mentioned making a paper case
Davespice
Contact: Twitter
Fri Jan 06, 2012 3:48 pm
Hi guys;
I have an idea to do something like this for the Marks and Spencer mint tin installation (Altoid tin if you"re American).  I plan to make a PDF you can download and print out – cut parts of it out and wrap it around your tin.  You then just use your dremel set to cut out the hatched areas – file/smooth down the edges and the Pi should slot straight in.
That's the theory anyway!
Robert_M
Sat Jan 07, 2012 12:50 am
I thought the Altoids tin was too short? (20mm or 3/4 inch high) I'm hoping that I'm wrong on this, though, because that was also my first choice of a case.
I sometimes ride my Pi to the Forum.
tzj
Sun Feb 19, 2012 12:40 am
http://pdfcast.org/pdf/raspber.....e-line-out
thought i'd post it on here too.
(damn duplicate threads : / )
http://www.themagpi.com <---- Checkout the MagPi
(The MagPi - Co-Founder)
itsonlyme
Sun Feb 19, 2012 2:00 pm
Just made a quick card mock-up of this case.
Sitting here looking at it, and the packet of fags next to it, and suddenly realise that a superkings fag packet is exactly the right size in all dimesnsions except length which is a little long.
Good starting point if you want a card case.
Malcolm
Goggles2114
Sun Feb 19, 2012 5:23 pm
For those that don't know/aren't aware.
Fags = Cigarettes in the above post.
Anyway that actually sounds like a nifty idea. Granted i wouldn't want to buy a pack of smokes just for a case, but maybe model a cardstock case after one since it even has a convenient flip-out hatch so you can extract the board.
8 + 7 = 15
tzj
Sun Feb 19, 2012 6:44 pm
glad to have helped
I may fix the USB section and line colour in the future.
Goggles2114
Sun Feb 19, 2012 7:19 pm
Yes having an actual production board to handle will improve this greatly.
While i feel printer paper will be too insubstantial, there anything you could have this printed on at, say, fedex/kinkos/staples/wherever that would be more substantial?
3 + 3 = 6
riggsre
Sun Feb 19, 2012 7:34 pm
3 + 3 = 6
You may want to just use the printout to use as a pattern to mark and cut more substantial material then glue it on if you want the graphic.
?? 9 = 3  ;-)
tzj
Mon Feb 20, 2012 7:44 pm
