PhilS
Re: Model A/B SD cross compatibility
Fri Jan 06, 2012 11:54 am
Hi all,
Just a thought, will an SD card that has been used in a model B run in a model A and vice versa? I've had issues with kernels being compiled for specific memory sizes and locations, so I thought I'd check!
(Sorry if it"s been asked before)
Cheers
Fri Jan 06, 2012 1:10 pm
PhilS said:
Hi all,
Cheers
An interesting question. I don't know! The Linux kernel side should be fine, but I am not sure what happens on GPU boot, where it decides the memory allocations for Linux.
I'll try and find out.
PhilS
Fri Jan 06, 2012 4:20 pm
Thanks, if nothing else, I'm sure we'll find out pretty soon!
mobeyduck
Fri Jan 06, 2012 4:31 pm
I think from A to B shouldn't be a problem you might be unable to use the Ethernet but that can be fixed. Adding memory should never be a problem.
(excluding some (old)dedicated stuff)
B to A can get a memory problem
patrickhwood
Fri Jan 06, 2012 7:15 pm
My guess is that the same kernel will run on both boards.  This has certainly been the case with other ARM-based boards with multiple memory configurations.
If that's not the case, then you can wait for a uboot port, then use that to chain load the kernel, passing appropriate arguments for memory and driver configuration.
Fri Jan 06, 2012 8:28 pm
That is the case - the reason I wasn't sure earlier was I think the memory partition is done at boot and I am not sure how it decides on this.
