cicciopizza
irrecord problem
Wed Apr 25, 2018 4:30 pm
I have a strange problem with lirc and irrecord
- irrecord 0.9.4c version on 2 raspberry pi3 Raspbian GNU/Linux 9 (stretch)
Target: clone samsung BN59-00865A remote control.
after configuring lirc etc. (I'm 99% sure the lirc software configuration is correct)
I did these steps:
Step 1
irrecord -d /dev/lirc0 ~/lircd.conf
I follow all the instructions...
and finally I get the lircd.conf file (the file is samsung.lircd.conf) and its contents is:
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <[email protected]>
# This config file was automatically generated
# using lirc-0.9.4c(default) on Sat Apr 21 17:47:12 2018
# Command line used: -d /dev/lirc0 /home/pi/lircd.conf
# Kernel version (uname -r): 4.9.59-v7+
# Remote name (as of config file): samsung
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
#     usb dongle? :
# For bundled USB devices: usb vendor id, product id
#     and device string (use dmesg or lsusb):
# Type of device controlled
#     (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
  name  samsung
  bits           16
  flags SPACE_ENC|CONST_LENGTH
  eps            30
  aeps          100
  header       4514  4470
  one           557  1678
  zero          557   560
  ptrail        557
  pre_data_bits   16
  pre_data       0xE0E0
  gap          107919
  toggle_bit_mask 0x0
  frequency    38000
      begin codes
          key_1                    0x20DF
          key_2                    0xA05F
          key_3                    0x609F
          key_4                    0x40BF
      end codes
end remote
I have only decoded 4 keys and the key_4 corresponds to the power on / off
Step 2
I replace the file samsung.lircd.conf in /etc/lirc/lircd.conf
Step 3
restart lircd process to read the new configuration
sudo service lircd restart
Step 4
I start irw process and with the remote control I press the keys KEY_1 .. KEY_4
it works correctly, irw read the signals from the remote control
Step 5
On a second raspberry nr. 2 identical rasbian configuration, lirc etc. and the same file lirc.conf,
I try to simulate with irsend the push KEY_1 .. KEY_4:
irsend SEND_ONCE samsung KEY_1
(samsung is the name inside the lircd.conf name tag)
irw on the other raspberry nr. 1 DOES NOT HAVE ANYTHING !!!
Step 6
trying to send irsend:
to the TV does not work
Step 7
I found the lirc.conf file on the internet for the remote control samsung BN59-00865A
I uploaded this file on both raspberry
on a raspebrry nr. 1 I run command
and on the other raspberry with active irw
i have READ the signal
Step 8
If I push KEY_1 on remote control, irw on raspberry nr. 2 NON READ SIGNAL !!!
but if I send with irsend command:
to the TV THIS WORK FINE !!!!
seeing the differences between the lirc.conf file downloaded from the internet and what
I have generated, the differences that I have seen concern
lirc.conf downloaded from internet GOOD
begin remote
  name samsung
  bits           16
  eps            30
  aeps          100
  header       4633  4321
  one           712  1520
  zero          712   398
  ptrail        704
  pre_data_bits   16
  pre_data       0xE0E0
  gap          108193
  toggle_bit      0
      begin codes
          KEY_TV                   0xD827                    #  Was: TV
          TOOLS                    0xD22D
          KEY_FAVORITES            0x22DD                    #  Was: FAV_CH
          KEY_ENTER                0x1AE5                    #  Was: RETURN
          CH_LIST                  0xD629
          KEY_POWER                0x40BF                    #  Was: POWER
          KEY_CYCLEWINDOWS         0x807F                    #  Was: SOURCE
          KEY_1                    0x20DF                    #  Was: 1
          KEY_2                    0xA05F                    #  Was: 2
          KEY_3                    0x609F                    #  Was: 3
          KEY_4                    0x10EF                    #  Was: 4
          KEY_5                    0x906F                    #  Was: 5
          KEY_6                    0x50AF                    #  Was: 6
          KEY_7                    0x30CF                    #  Was: 7
          KEY_8                    0xB04F                    #  Was: 8
          KEY_9                    0x708F                    #  Was: 9
          KEY_0                    0x8877                    #  Was: 0
          PRE-CH                   0xC837
          KEY_VOLUMEUP             0xE01F                    #  Was: VOL+
          KEY_CHANNELUP            0x48B7                    #  Was: P+
          KEY_MUTE                 0xF00F                    #  Was: MUTE
          KEY_VOLUMEDOWN           0xD02F                    #  Was: VOL-
          KEY_CHANNELDOWN          0x08F7                    #  Was: P-
          KEY_MENU                 0x58A7                    #  Was: MENU
          KEY_EXIT                 0xB44B                    #  Was: EXIT
          KEY_UP                   0x06F9                    #  Was: UP
          KEY_LEFT                 0xA659                    #  Was: LEFT
          ENTER-OK                 0x16E9
          KEY_RIGHT                0x46B9                    #  Was: RIGHT
          KEY_DOWN                 0x8679                    #  Was: DOWN
          KEY_INFO                 0xF20D                    #  Was: GUIDE
          KEY_INFO                 0xF807                    #  Was: INFO
          TEXT-MIX                 0x34CB
          KEY_RED                  0x36C9                    #  Was: RED
          KEY_GREEN                0x28D7                    #  Was: GREEN
          KEY_YELLOW               0xA857                    #  Was: YELLOW
          KEY_BLUE                 0x6897                    #  Was: BLUE
          KEY_SUBTITLE             0xA45B                    #  Was: SUBTITLE
      end codes
end remote
lirc.conf generated with irreconr WRONG !!!
begin remote
  name  samsung
  bits           16
  eps            30
  aeps          100
  header       4514  4470
  one           557  1678
  zero          557   560
  ptrail        557
  pre_data_bits   16
  pre_data       0xE0E0
  gap          107919
  toggle_bit_mask 0x0
  frequency    38000
      begin codes
          key_1                    0x20DF
          key_2                    0xA05F
          key_3                    0x609F
          key_4                    0x40BF
      end codes
end remote
because I can not generate a good lirc.conf file with irrecord ???
Nortol
Re: irrecord problem
Wed Sep 12, 2018 4:20 pm
Have you found a solution for this problem?
Cheers
jadro
Thu Sep 13, 2018 6:32 am
One question,
I see that everyone use lirc for TV remote.
Does lirc works for AirConditioner?
Thanx,
Jadro
Oracle backend database developer
SmartHome IoT & Microprocessor enthusiast and hobbyist
