shinTheOne
How to control a servo using PWM pulse(1100-1900) using RPi?
Wed Apr 25, 2018 2:48 am
How to control a servo using PWM pulse(1100-1900) using RPi? Where can I get started?
texy
Re: How to control a servo using PWM pulse(1100-1900) using RPi?
Wed Apr 25, 2018 8:54 am
Hi and welcome to the forum.
Lots of options, here is a good starting place :
viewtopic.php?t=43579
Texy
B.Goode
Wed Apr 25, 2018 9:02 am
In addition to the prompt reply from a Moderator -
It might be too obvious to say that you will need to install an Operating System on a microSD card and boot your RPi from it.
If you choose the Raspberry Pi Foundation recommended and supported Raspbian Operating System then you would have access to the gpiozero Python library module. This includes built-in support for common hobbyist 'Little Blue Servos' - it is implemented by calling on the pigpio library already mentioned.
http://gpiozero.readthedocs.io/en/stabl ... html#servo
