simon1974
Usb soundcard
Fri Apr 13, 2018 8:05 am
As most of us know that the audio output on the pi is only about 775 millivolts which is right for using headphones but what if you needed a higher voltage output possibly around 1.5 volts or higher which is the spec of most CD players etc use
So on that note is there a recommended usb soundcard for output not input for the raspberry pi
bask185
Re: Usb soundcard
Fri Apr 13, 2018 9:45 am
I believe you can buy any usb audio card, pick the cheapest from ebay. These cost a buck and a bit. The quality of the Pi's audio output is not that great from what I've heared, so a usb audio card is a good idea.
If you want to drive speakers, you still need to use an amplifier
beo_6
Re: Usb soundcard
Fri Apr 13, 2018 10:10 am
I would give it a try fist.
I was very impressed with the audio output of the 3b+. Very low noise, its good enough for my stereo.
Make sure to raise the volume in the pi to max. Default ist 50%
simon1974
Re: Usb soundcard
Fri Apr 13, 2018 10:27 am
I have a 3b and the volume is set to 100 in the audio settings
RaTTuS
Contact: Twitter YouTube
Re: Usb soundcard
Fri Apr 13, 2018 10:30 am
use hdmi audio
Covfefe
bask185
Re: Usb soundcard
Fri Apr 13, 2018 10:43 am
use hdmi audio
The OP has not said that he is using any form of a display. As far as I can tell he is simply making a headless audio player. And to get an hdmi audio extractor is like 20x more expensive than a usb soundcard.... especially if no no hdmi display is used
RaTTuS
Re: Usb soundcard
Fri Apr 13, 2018 10:58 am
use hdmi audio
true, though you can get hdmi audio extractors for £7ish
spi audio for £2
usb for £1 ish
quality / size / etc....
Covfefe
BlackKnight_UK
Re: Usb soundcard
Fri Apr 13, 2018 11:01 am
I made a Pi Musicbox player using a Zero and a WD Labs Node Zero hard drive. It has a USB sound card with phono out put which connects to my home cinema amplifier. It works well, the sound card is Ugreen and came from Amazon.
Now I'm wondering if I could have used the HDMI socket to get audio. The player is headless, controlled either from my laptop or tablet so I'm not using the HDMI socket.
RaTTuS
Re: Usb soundcard
Fri Apr 13, 2018 11:06 am
you need an audio extractor to get the audio out of the hdmi stream
Covfefe
simon1974
Re: Usb soundcard
Fri Apr 13, 2018 11:17 am
To answer one question about the HDMI out
Well that is being used on a computer monitor at the moment
