zeitstau
Trouble with Darkice on Raspberry Pi 3
Thu Apr 12, 2018 5:15 pm
I'm pretty new to the whole Raspberry thing and trying to get an Icecast server running from my Pi. I want to use my soundcard as a sound source. So far I got the server up and running but I can't start up Icecast. Whenever I try running it with the "icecast" command or the "sudo icecast" command I get the following message:
DarkIce: DarkIce.ccpp:1187: can't open connector [0]
I spent many hours searching for a possible solution online but couldn't find anything. Hopefully there's some experts on this forum.
Here is my icecast.xml file:
<icecast>
    <!-- location and admin are two arbitrary strings that are e.g. visible
         on the server info page of the icecast web interface
         (server_version.xsl). -->
    <location>Earth</location>
    <admin>[email protected]</admin>
    <!-- IMPORTANT!
         Especially for inexperienced users:
         Start out by ONLY changing all passwords and restarting Icecast.
         For detailed setup instructions please refer to the documentation.
         It's also available here: http://icecast.org/docs/
    <limits>
        <clients>100</clients>
        <sources>2</sources>
        <queue-size>524288</queue-size>
        <client-timeout>30</client-timeout>
        <header-timeout>15</header-timeout>
        <source-timeout>10</source-timeout>
        <!-- If enabled, this will provide a burst of data when a client
             first connects, thereby significantly reducing the startup
             time for listeners that do substantial buffering. However,
             it also significantly increases latency between the source
             client and listening client.  For low-latency setups, you
             might want to disable this. -->
        <burst-on-connect>1</burst-on-connect>
        <!-- same as burst-on-connect, but this allows for being more
             specific on how much to burst. Most people won't need to
             change from the default 64k. Applies to all mountpoints  -->
        <burst-size>65535</burst-size>
    </limits>
    <authentication>
        <!-- Sources log in with username 'source' -->
        <source-password>****</source-password>
        <!-- Relays log in with username 'relay' -->
        <relay-password>****</relay-password>
        <!-- Admin logs in with the username given below -->
        <admin-user>admin</admin-user>
        <admin-password>****</admin-password>
    </authentication>
    <!-- set the mountpoint for a shoutcast source to use, the default if not
         specified is /stream but you can change it here if an alternative is
         wanted or an extension is required
    <shoutcast-mount>/live.nsv</shoutcast-mount>
    <!-- Uncomment this if you want directory listings -->
    <directory>
        <yp-url-timeout>15</yp-url-timeout>
        <yp-url>http://dir.xiph.org/cgi-bin/yp-cgi</yp-url>
    </directory>
    <!-- This is the hostname other people will use to connect to your server.
         It affects mainly the urls generated by Icecast for playlists and yp
         listings. You MUST configure it properly for YP listings to work!
    <hostname>raspberrypi</hostname>
    <!-- You may have multiple <listener> elements -->
    <listen-socket>
        <port>8001</port>
        <!-- <bind-address>127.0.0.1</bind-address> -->
        <!-- <shoutcast-mount>/stream</shoutcast-mount> -->
    </listen-socket>
    <listen-socket>
        <port>8080</port>
    </listen-socket>
    <listen-socket>
        <port>8443</port>
        <ssl>1</ssl>
    </listen-socket>
    <!-- Global header settings
         Headers defined here will be returned for every HTTP request to Icecast.
         The ACAO header makes Icecast public content/API by default
         This will make streams easier embeddable (some HTML5 functionality needs it).
         Also it allows direct access to e.g. /status-json.xsl from other sites.
         If you don't want this, comment out the following line or read up on CORS.
    <http-headers>
        <header name="Access-Control-Allow-Origin" value="*" />
    </http-headers>
    <!-- Relaying
         You don't need this if you only have one server.
         Please refer to the config for a detailed explanation.
    <!--<master-server>127.0.0.1</master-server>-->
    <!--<master-server-port>8001</master-server-port>-->
    <!--<master-update-interval>120</master-update-interval>-->
    <!--<master-password>hackme</master-password>-->
    <!-- setting this makes all relays on-demand unless overridden, this is
         useful for master relays which do not have <relay> definitions here.
         The default is 0 -->
    <!--<relays-on-demand>1</relays-on-demand>-->
    <relay>
        <server>127.0.0.1</server>
        <port>8080</port>
        <mount>/example.ogg</mount>
        <local-mount>/different.ogg</local-mount>
        <on-demand>0</on-demand>
        <relay-shoutcast-metadata>0</relay-shoutcast-metadata>
    </relay>
    <!-- Mountpoints
         Only define <mount> sections if you want to use advanced options,
         like alternative usernames or passwords
    <!-- Default settings for all mounts that don't have a specific <mount type="normal">.
    <mount type="default">
        <public>0</public>
        <intro>/server-wide-intro.ogg</intro>
        <max-listener-duration>3600</max-listener-duration>
        <authentication type="url">
                <option name="mount_add" value="http://auth.example.org/stream_start.php"/>
        </authentication>
        <http-headers>
                <header name="foo" value="bar" />
        </http-headers>
    </mount>
    <!-- Normal mounts -->
        <mount-name>/example-complex.ogg</mount-name>
        <username>othersource</username>
        <password>hackmemore</password>
        <max-listeners>1</max-listeners>
        <dump-file>/tmp/dump-example1.ogg</dump-file>
        <burst-size>65536</burst-size>
        <fallback-mount>/example2.ogg</fallback-mount>
        <fallback-override>1</fallback-override>
        <fallback-when-full>1</fallback-when-full>
        <intro>/example_intro.ogg</intro>
        <hidden>1</hidden>
        <public>1</public>
        <authentication type="htpasswd">
                <option name="filename" value="myauth"/>
                <option name="allow_duplicate_users" value="0"/>
        </authentication>
        <http-headers>
                <header name="Access-Control-Allow-Origin" value="http://webplayer.example.org" />
                <header name="baz" value="quux" />
        </http-headers>
        <on-connect>/home/icecast/bin/stream-start</on-connect>
        <on-disconnect>/home/icecast/bin/stream-stop</on-disconnect>
    </mount>
        <mount-name>/auth_example.ogg</mount-name>
            <option name="mount_add"       value="http://myauthserver.net/notify_mount.php"/>
            <option name="mount_remove"    value="http://myauthserver.net/notify_mount.php"/>
            <option name="listener_add"    value="http://myauthserver.net/notify_listener.php"/>
            <option name="listener_remove" value="http://myauthserver.net/notify_listener.php"/>
            <option name="headers"         value="x-pragma,x-token"/>
            <option name="header_prefix"   value="ClientHeader."/>
        </authentication>
    </mount>
    <fileserve>1</fileserve>
    <paths>
        <!-- basedir is only used if chroot is enabled -->
        <basedir>/usr/share/icecast2</basedir>
        <!-- Note that if <chroot> is turned on below, these paths must both
             be relative to the new root, not the original root -->
        <logdir>/var/log/icecast2</logdir>
        <webroot>/usr/share/icecast2/web</webroot>
        <adminroot>/usr/share/icecast2/admin</adminroot>
        <!-- <pidfile>/usr/share/icecast2/icecast.pid</pidfile> -->
        <!-- Aliases: treat requests for 'source' path as being for 'dest' path
             May be made specific to a port or bound address using the "port"
             and "bind-address" attributes.
        <alias source="/foo" destination="/bar"/>
        <!-- Aliases: can also be used for simple redirections as well,
             this example will redirect all requests for http://server:port/ to
             the status page
        <alias source="/" destination="/status.xsl"/>
        <!-- The certificate file needs to contain both public and private part.
             Both should be PEM encoded.
        <ssl-certificate>/usr/share/icecast2/icecast.pem</ssl-certificate>
    </paths>
    <logging>
        <accesslog>access.log</accesslog>
        <errorlog>error.log</errorlog>
        <!-- <playlistlog>playlist.log</playlistlog> -->
        <loglevel>3</loglevel> <!-- 4 Debug, 3 Info, 2 Warn, 1 Error -->
        <logsize>10000</logsize> <!-- Max size of a logfile -->
        <!-- If logarchive is enabled (1), then when logsize is reached
             the logfile will be moved to [error|access|playlist].log.DATESTAMP,
             otherwise it will be moved to [error|access|playlist].log.old.
             Default is non-archive mode (i.e. overwrite)
        <!-- <logarchive>1</logarchive> -->
    </logging>
    <security>
        <chroot>0</chroot>
        <changeowner>
            <user>nobody</user>
            <group>nogroup</group>
        </changeowner>
    </security>
</icecast>
And here's the darkice.cfg:
[general]
duration        = 0      # duration in s, 0 forever
bufferSecs      = 1      # buffer, in seconds
reconnect       = yes    # reconnect if disconnected
[input]
device          = hw:0,0 # or `pulse' for Pulseaudio
sampleRate      = 11025   # sample rate 11025, 22050 or 44100
bitsPerSample   = 16      # bits
channel         = 2       # 2 = stereo
[icecast2-0]
bitrateMode     = vbr       # variable bit rate (`cbr' constant, `abr' average)
quality         = 1.0       # 1.0 is best quality
format          = mp3       # format. Choose `vorbis' for OGG Vorbis
bitrate         = 256       # bitrate
server          = http://localhost # or IP
port            = 8001      # port for IceCast2 access
password        = ****    # source password to the IceCast2 server
mountPoint	= mystream.mp3
name            = mystream
Does anybody know where the problem might be? Maybe with the soundcard? "aplay -l" gives the following results:
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 7/7
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
  Subdevices: 1/1
I appreciate any help!
madscot
Re: Trouble with Darkice on Raspberry Pi 3
Tue Sep 18, 2018 8:11 pm
What does
arecord -l
show ?
Andrew
Who is online
Users browsing this forum: andrum99, humbug, procount and 50 guests
