acy
configuring multiple virtual hosts in apache2
Wed Apr 11, 2018 2:16 pm
I can create virtual hosts in apache2 on (Apple) OSX 10, but have yet to achieve the same in apache2 on the pi. I have followed the instructions (as they appear in the pi forum and from articles on the web) but with no success.
I appreciate that on the pi, the virtual host declarations are created in individual .conf file under /etc/apache1/sites-enabled. However although the privileges of the DocumentRoot are as that of /var/www/, when I try to access the the relevant web pages remotely , I always get the message that the requested url is not found.
A typical .conf file contains:
<VirtualHost blahblah.com>
DocumentRoot /mnt/data1/public/Sites/html/blahblah
Servername localhost
ServerAlias www.blahblah.com
<VirtualHost>
Any comments/suggestions/help would be greatly appreciated.
knute
Re: configuring multiple virtual hosts in apache2
Thu Apr 12, 2018 2:53 pm
<VirtualHost>
Try <VirtualHost *:80> and ServerName blahblah.com
MaxVMH
Thu Apr 12, 2018 3:17 pm
You should create them in /etc/apache2/sites-available (eg. /etc/apache2/sites-available/nameofthewebsite.conf) and enable them with (this will create an alias in /etc/apache2/sites-enabled/):
sudo a2ensite nameofthewebsite
I'm not sure if the changes go into effect immediately so you might want to restart apache afterwards (it will show you errors if something went wrong):
sudo service apache2 restart
This is an example of a virtualhost .conf file like I use them (@others feel free to say how I can improve them):
<VirtualHost *:80>
        ServerName www.example.com
        ServerAlias example.com
        DocumentRoot /home/myusername/websites/example.com/public_html
        <Directory "/home/myusername/websites/example.com/public_html">
                Options FollowSymLinks
                AllowOverride All
                Order allow,deny
                Allow from all
                Require all granted
        </Directory>
        ErrorLog ${APACHE_LOG_DIR}/example.com/error.log
        CustomLog ${APACHE_LOG_DIR}/example.com/access.log combined
</VirtualHost>
(Please use logs like in this example - it's useful to look for suspicious traffic, eg. on your phpmyadmin or WordPress admin login page, but best is to disable these from public access.)
Webserver stack: 2x Pi 3B | 1x Pi 3B+ ||| Pi Zero W for fooling around
Working on a soccer prediction web app:
https://github.com/MaxVMH/mijnscore
Attempt at writing up-to-date tutorials on making a Raspberry Pi webserver:
http://blog.mijnscore.be/
acy
Thu Apr 12, 2018 9:17 pm
I have reloaded apache via sudo system to reload apache2 with no errors reported and sudo acachectl configtest returns ‘ok’. Will add some logs as a further measure
acy
Fri Apr 13, 2018 4:28 pm
Problem resolved, somewhat embarrassing, but I forgot to update the hosts file on the remote computer to point the virtualhosts to the pi that was running the apache server.
In hosts file : raspberry pi's : IP address www.blahbah.com
raspberry pi's : IP address blahbah.com
Apologies for wasting all your time. But your comments did help by making me rethink through my problem!
