PSTN integration?
Posted: Mon Apr 02, 2018 5:02 pm
by SethGandy
Good day everyone,
Figured I'd ask here to catch the attention of anyone that has knowledge on this type of thing before I got charging headlong into this myself.
I'm working with an intercom system, and we want to implement a raspberry pi into the system for pre-made messages.
I need to find a solution that works with the pi that will allow me to send a dial code, then play a message over the phone line.
Has anyone seen anything remotely like this they could point me in the direction of?
Thanks!
Re: PSTN integration?
Posted: Mon Apr 02, 2018 5:06 pm
by W. H. Heydt
You might br able to do that using a USB connected dial-up modem. That's at least a chunk of the tech you're looking for. Bear in mind that PSTN uses voltages that will fry a Pi in an instant (for instance, IIRC, ringing voltage is 90v) so you need to isolate the Pi from what you'll find on the lines.
