Taxicletter
Set side panel of PCmanFM to "Places"
Sun Mar 25, 2018 12:19 pm
I searched like crazy, but can't find out how to set the side-panel of PCmanFM to icons. It's mentioned you CAN do that, but I can't find it in the settings. I also tried the configuration files (there are two, not sure which is really in use), but I don't know the right code ("side_pane_mode=places" doesn't seem to work).
These are the configuration files I tried. Should I change both?
/home/pi/.config/pcmanfm/LXDE-pi/pcmanfm.conf
/home/pi/.config/pcmanfm/default/pcmanfm.conf
I found somewhere that before, the setting was set by 0 or 1. I also tried 0,1 and 2 as setting, but that didn't help either.
Any hints?
--::--::- 3 x Raspberry Pi 3 - Raspbian Lite 9 - RuneAudio - one broke (wifi) - not in use -::--::--
ShiftPlusOne
Re: Set side panel of PCmanFM to "Places"
Mon Mar 26, 2018 8:18 am
You also need to disable simple mode.
Taxicletter
Mon Mar 26, 2018 8:49 am
Fantastic! Thank you.
