Boot delay
Posted: Fri Mar 23, 2018 3:45 pm
by MrBool
I use the latest image of Raspbian on the Compute Module. I noticed that after power on the first message on UART
"Booting Linux on physical CPU 0x0"
is after 5-6 seconds.
Is possible make this delay shorter?
I don't need HDMI and in the previous images I used in config:
ignore_lcd=1
force_eeprom_read=0
ignore_hdmi_edid=1
hdmi_edid_file=1
ignore_hdmi_edid is probably deprecated and I try:
hdmi_ignore_edid=0xa5000080
But I still get a few seconds delay.
Re: Boot delay
Posted: Fri Mar 23, 2018 7:12 pm
by MaxK1
What does your /boot/cmdline.txt file look like?
Re: Boot delay
Posted: Sat Mar 24, 2018 12:26 pm
by MrBool
In config.txt I have only:
ignore_lcd=1
force_eeprom_read=0
Re: Boot delay
Posted: Sat Mar 24, 2018 12:44 pm
by MaxK1
I asked about /boot/cmdline.txt not /boot/config.txt
Re: Boot delay
Posted: Sat Mar 24, 2018 12:53 pm
by MrBool
I'm sorry, here is my cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=7009e660-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Re: Boot delay
Posted: Sat Mar 24, 2018 1:36 pm
by MaxK1
If you have a way of editting the SD card in case this fails, try removing the "rootwait" from cmdline.txt. You aren't using NOOBS are you?
