Page 1 of 2
stopping for a rest
Posted: Thu Mar 22, 2018 8:20 pm
by billybangleballs
I bought a pi3b+
I eventually got it to run after messing with rpi-update
But I was told that being ancient was bad, and that I might have problems.
The only problem I had was my network would suddenly freeze for 30 seconds or so and then carry on as if nothing had happened. The connections are not dropped, it's just as though it's stopping for a rest.
So I assumed that the sage advice I'd been given about being ancient was probably true.
Consequently I procured a new sdcard and 2018-03-13-raspbian-stretch
Two days later after spending an eternity setting up this and fiddling with that, I finally got it all working just as I like it, only the stopping for a rest is still happening. I tried both my sdcards in my original pi3 and the problem isn't there, but it is there on the pi3b+ and it's very annoying.
What makes me think it is network related is that I use rdesktop on the pi to drive a computer with a noisy fan in another part of the house, and when this stopping for a rest happens, I still have a responsive mouse and keyboard and can type into lxterminal and the like and get results, even while my remote desktop is seemingly frozen.
Any ideas?
[email protected]:~ $ cat /proc/net/dev
Inter-|   Receive                                                |  Transmit
 face |bytes    packets errs drop fifo frame compressed multicast|bytes    packets errs drop fifo colls carrier compressed
    lo:    8044      53    0    0    0     0          0         0     8044      53    0    0    0     0       0          0
 wlan0: 33711235   30001    0    2    0     0          0      3191  1839879   17626    0    0    0     0       0          0
  eth0: 570075437  583683    0    3    0     0          0         0 71256366  319224    0    0    0     0       0          0
Re: stopping for a rest
Posted: Thu Mar 22, 2018 8:42 pm
by HawaiianPi
It isn't ancient, it's testing firmware that could have bugs and stability issues. You should not run rpi-update unless told to do so by someone from the Raspberry Pi support team.
Posted: Thu Mar 22, 2018 8:45 pm
by billybangleballs
I was referring to my operating system being wheezy, not the new kernel and boot code.
Posted: Thu Mar 22, 2018 8:49 pm
by HawaiianPi
Wheezy! :o :shock:
Posted: Thu Mar 22, 2018 8:57 pm
by Heater
Why do that?
Get yourself a new Stretch image.
Posted: Thu Mar 22, 2018 9:05 pm
by billybangleballs
Why do that?
Which piece of "Consequently I procured a new sdcard and 2018-03-13-raspbian-stretch", are you finding confusing?
Or are you suggesting there has been a new release since Tuesday?
Posted: Thu Mar 22, 2018 9:32 pm
by Heater
I found the whole story confusing.
At first I thought you meant that you were ancient and needed to stop for a rest occasionally :)
And what has that noisy fan got to do with anything?
Posted: Thu Mar 22, 2018 9:49 pm
by billybangleballs
Not wanting to appear rude, but if your entire 8786 posts are as helpful as your last two, can you please go help someone else.
Posted: Fri Mar 23, 2018 12:03 am
by jbudd
How often does it stop?
Linux might well swap your processes in and out as it keeps on top of it's mysterious housekeeping jobs. 30 seconds seems like a long rest though.
You could run "top" to try and spot what's using system resources instead.
It's (probably - never done it with Raspbian) possible to tweek how strongly a process holds on to it's memory and processor time slots with the "nice" command.
Posted: Fri Mar 23, 2018 12:27 am
by billybangleballs
It is random, I can't make it do it, or say when it will happen.
It does it irrespective of the cpu load or temperature.
I will try that top tomorrow, I have had to go back to using the pi3b because the the pi3b+ is really unusable.
It is definitely something in the hardware, because I'm using the same sdcard / os with no issues on this pi3b
I was transcoding a video earlier with avconv and I had a sustained 99% cpu meter and the temperature kept hitting 80.6° and the little red thermometer was flashing on the screen and then it stopped for a rest and the cpu dropped to 1%. The src and dst of the transcoding was on an nfs mount. 30 seconds later it started communicating again, but it was too late, it had already screwed up :-
[h264 @ 0x1056240] Invalid nal size 39092B time=00:03:23.84 bitrate=5306.9kbits/s dup=3 drop=0 speed=0.114x
[h264 @ 0x1056240] Error splitting the input into NAL units.
VID_20180322_203228.3gp: Host is down078kB time=00:03:23.84 bitrate=5307.8kbits/s dup=3 drop=0 speed=0.114x
Error while decoding stream #0:0: Invalid data found when processing inputkbits/s dup=3 drop=0 speed=0.11x
frame= 6103 fps=3.2 q=-1.0 Lsize=  133948kB time=00:04:26.44 bitrate=4118.2kbits/s dup=3 drop=0 speed=0.14x
video:131628kB audio:2093kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.169446%
I'm pretty sure it's the nic or related hw. I just don't know how to fix it.
Posted: Fri Mar 23, 2018 8:35 am
by PeterO
Try leaving a "ping" to your NFS server running in a terminal window. If that stops (drops packets) when it "takes a rest" then it points to the PI's networking/nic. If it carries on , then it could be the NFS server end having a problem.
PeterO
Posted: Fri Mar 23, 2018 9:43 am
by jamesh
Actually, that's the wrong takeaway. This is almost certainly a driver problem, which is software. The ethernet and wireless chips have both changed on the Pi3B+, and both have different drivers to the Pi3B.
We are looking in to various things, I believe there is at least one bug fix for the lan78xx driver in progress (ethernet). Worth remembering that there have been bug fixes for both ethernet and wireless over the lifetime of the Pi3B as well. This is a new device with new chips, there are often issues that come out of the woodwork once a large number of people use the device, that didn't happen during the beta test stage.
Posted: Fri Mar 23, 2018 10:48 am
by PeterO
PeterO
When I wrote " it could be the NFS server end having a problem." I was thinking that it could be an NFS problem rather than a networking problem.
Also, try running a ping to another device on your network , that will help prove if it is or isn't a problem at the PI end.
PeterO
Posted: Fri Mar 23, 2018 10:57 am
by royhenderson
Does the 3B+ temperature throttle? You mentioned hitting 80 ... just wondering if some form of cooling might be a solution? I have noticed the my 3B+ boards do seem to run warm even when idling ...
Posted: Fri Mar 23, 2018 11:10 am
by billybangleballs
PeterO
I can try that , although why the windows box, the nfs server and the internet would all be having problems while the plucky pi3b+ is blameless, kind of defies logic.
There is nothing wrong with the sdcard/os as it works as it should in a pi3b
The nfs server has worked perfectly for 3 years or so and only has issues when I try to use the pi3b+
ditto for the windows box
The internet is full of trolls and Russian hackers, maybe we could blame them...
Posted: Fri Mar 23, 2018 11:24 am
by PeterO
You've missed the point. Just because your process that uses NFS is pausing doesn't mean the problem is with the networking.
Running a ping (to anywhere) will show if the PI's network stack and hardware are still functioning during the pause.
PeterO
Posted: Fri Mar 23, 2018 12:11 pm
by billybangleballs
Sorry James, I missed your reply.
Where do I get a patch for my lan78xx driver (and instructions on how to apply it), I don't mind testing any potential fixes. I have the bug, so I'm ideally placed to test the bugfix.
Posted: Fri Mar 23, 2018 12:21 pm
by billybangleballs
Yes Roy, it throttles nicely, and the temp never went above 80.6°C even during a sustained hammering. I think a heatsink would probably delay the throttling somewhat and keep your bogomips up there, but unless you're a bitcoin miner or are constantly transcoding video streams I don't know as it's really worth the effort.
Posted: Fri Mar 23, 2018 6:53 pm
by uilfut
Which power supply are you using - the official 2.5A one?
Posted: Fri Mar 23, 2018 7:16 pm
by billybangleballs
One that I built, good for 20amps or more.
If it was lack of volts, the yellow lightning icon would show on the desktop.
Posted: Fri Mar 23, 2018 7:48 pm
by billybangleballs
PeterO
I did as you suggested, I opened 3 lxterminals on the desktop, and and set each one to ping a different host on my network.
When it next decided to stop for a rest, I looked at the 3 lxterminals, and each one was saying
ping: sendmsg: Network is unreachable
not just to the nfs server, not just to the grandstream phone and not just to the windows box
The network had just stopped.
After eight 'ping: sendmsg: Network is unreachable's, the pings all started working again in unison. The sha256sum that was spooling a file from the nfs server took a good 30 seconds or more before it resumed.
I'm unsure whether the result is correct because of the outage, so I will do it again and compare.
Edit - The sha256sum returned was the same, so the 'rest' didn't break anything on this occasion.
Posted: Fri Mar 23, 2018 8:08 pm
by PeterO
PeterO
Well that's pretty conclusive :D Is there anything in /var/log/syslog that helps ? It might show why the interface is going down and comming back up
grep -a eth0 /var/log/syslog
Posted: Fri Mar 23, 2018 8:55 pm
by billybangleballs
PeterO
No, nothing about eth0 in any log
And it's not like the network goes down and things notice.
e.g. if I unplug the network cable, everything disconnects, rdesktop, putty sessions to remote shells, the whole lot just terminate their sessions. This doesn't bother anything, the sessions are still connected. It's damned annoying, and that in itself is enough, but it breaks things like transcoding from and to nfs. And just needs fixing.
Posted: Fri Mar 23, 2018 9:06 pm
by PeterO
That's not right... There should be lots of messages in there from dhcpcd
What does ifconfig say about the interface during the "pause" ?
PeterO
Posted: Fri Mar 23, 2018 9:23 pm
by billybangleballs
PeterO
You are assuming that I'm not running with a static ip and that dhcpcd is aware of this and doesn't bug me.
