ashish_r
auto execution jar file after raspberry start up using cron job
Thu Mar 22, 2018 6:39 pm
i want to auto execution GUI based jar file after raspberry start up using cron job , i got exception such like
Exception in thread "main" java.awt.HeadlessException at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:204) at java.awt.Window.(Window.java:536) at java.awt.Frame.(Frame.java:420) at java.awt.Frame.(Frame.java:385) at javax.swing.JFrame.(JFrame.java:189) at com.mycompany.gui.FirstSwingExample.main(FirstSwingExample.java:43)
my crontab command is @reboot /usr/bin/java -jar /home/pi/Desktop/GUI-1.0-SNAPSHOT.jar > /home/pi/Desktop/log.txt 2>&1
i also passed JVM argument -Djava.awt.headless=true
please help me
knute
Re: auto execution jar file after raspberry start up using cron job
Thu Mar 22, 2018 9:57 pm
You do know that headless and GUI are mutually exclusive?
knute
Thu Mar 22, 2018 10:28 pm
The @reboot scheme isn't going to work either because the X11 desktop isn't running when cron tries to start the program, hence the headless errors.
Probably the simplest method to run a program like this is to use a Desktop file in your autostart directory. In the /home/pi/.config/autostart directory create a file test.desktop:
[Desktop Entry]
Name=test
Type=Application
Exec=java -jar test.jar
Terminal=true
Hidden=false
Here is a simple Java Swing test program:
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
public class test extends JFrame {
    public test() {
        super("test");
        setDefaultCloseOperation(JFrame.DISPOSE_ON_CLOSE);
        add(new JLabel("test",JLabel.CENTER),BorderLayout.CENTER);
        setSize(200,150);
        setVisible(true);
        setLocationRelativeTo(null);
    public static void main(String... args) {
        EventQueue.invokeLater(() -> new test());
Copy and paste the test program to ~
Compile test.java: javac test.java
Jar it: jar cvfe test.jar test *.class
Delete the .class files rm *.class
It should run after the desktop is up. Now you should be able to get your program running.
ashish_r
Fri Mar 23, 2018 4:00 pm
:lol: :lol: :o its working knute sir ,,, thanks a lot
