kainaat
How to monitor a /var/log file
Wed Mar 21, 2018 10:13 am
I have a .csv log file which I would like to monitor for error codes and print a message when an error code is found.
PHP script:
<?php
 $command = "ssh -p 97 -i /var/www/html/test.rsa pi@192.168.xx.xx
 tail -1 /var/log/playlog.csv";
 $output = shell_exec($command);
 echo "Test PI <p></p>Status: <p></p><pre>Currently Playing: $output</pre> ";
Webpage outputs:
Test PI
Status:
Currently Playing:
2018-03-20 10:30:13,NM_Test.h264,-0
So the code 0 means there are no errors and everything is working smoothly. But if the error code is something like -2 than I want status to print 'Missing file':
Test PI
Status: Missing file
Currently Playing:
2018-03-20 10:30:13,NM_Test.h264,-2
And a different message depending on a different error code.
How can I achieve this?
evilkitty
Re: How to monitor a /var/log file
Wed Mar 21, 2018 11:02 am
php has 2 way to run shell commands shell exec and exec, one has no output text
i believe a exit state of >0 is a error
if you use ''cat /var/log/filename > /dev/null;echo $?' shell will only return the exit status number
you also should use this function
http://php.net/manual/en/function.escapeshellcmd.php
iirc it does not handle line beaks, you may want to handle those yourself
str_replace("\\n","\n",shell_exec('cat /dev/urandom'));// do not cat that file its length is infinite
I would have the client run a script to send post/get data to the pi instead of using sell_exec
You could use ssh to call a script on the client to check of the file exist 1st and return appropriate data
#!/bin/sh
file='/var/log/playlog.csv'
if [ -f $file  ];then
  tail -1 $file
else
  echo 404 error
fi
My Pi Server: http://imgur.com/a/6xIUI | Thermostat: http://imgur.com/a/4LVnT
kainaat
Wed Mar 21, 2018 12:37 pm
Your bash script is a far better way to achieve what I attempted to do using PHP. So I will use your script instead.
However, I'm still a stuck on a solution to my original question. To clarify, I have a player.bin file which writes to playlog.csv file of every video the omx player plays.
So for me a 0 indicates there are no errors present, but a -2 would indicate my player is expecting to see a .h264 file inside /var/lib/surround/.
I was thinking of running the command:
And then somehow running a grep/awk/sed command to retrieve a match after the second comma:
E.g.
if it sees -2 -> 2018-03-21 11:17:29,NM_Test.h264,-2
echo "Missing file"
or
if it sees -3 -> 2018-03-21 11:17:29,NM_Test.h264,-3
echo "different message"
else
if it sees 0 -> 2018-03-21 11:17:29,NM_Test.h264,0
echo "no errors reported"
This is the bit I am stuck at :(
#!/bin/sh
  tail -1 $file
else
  echo 404 error
fi
PingoBags
Wed Mar 21, 2018 1:45 pm
What if you create a function to output the custom errors for you?
<?php
function ReturnError($res)
  switch ($res)
    case "0":
    return " no errors reported";
    case "1":
    return " some error";
    case "2":
    return " Missing file";
    case "3":
echo "Test PI <p></p>Status: <p></p><pre>Currently Playing: ".substr($output, 0, -2).ReturnError(substr($output, -1));
If there is no error, it should output
Test PI
Status:
Currently Playing:
2018-03-20 10:30:13,NM_Test.h264, no errors reported
If error 2
Test PI
Status:
Currently Playing:
2018-03-20 10:30:13,NM_Test.h264, Missing file
kainaat
Wed Mar 21, 2018 3:57 pm
This is exactly what I need!!! Thank you!
But I can't get seem to get the corresponding case message to display:
Currently playing: 2018-03-21 15:21:13,NM_Test.h264,
Where am I going wrong?
<?php
  switch ($res)
    case "0":
    case "1":
    case "2":
    case "3":
Test PI
Status:
Currently Playing:
If error 2
Test PI
Status:
Currently Playing:
PingoBags
Wed Mar 21, 2018 5:12 pm
What exactly does $output print out, not from the code I posted, but the original code you have.
I assumed it printed
2018-03-21 15:21:13,NM_Test.h264,-0
or whatever the code is at the end.
Add an extra line to ReturnError function so it looks like this.
See if it prints out anything. It might give you a better idea.
  switch ($res)
    case "0":
    case "1":
    case "2":
    case "3":
    //if the error code is not blank, return the value else return (Error code blank)
    default:
    return empty($res) ? " Error code blank" : "-".$res;
kainaat
Thu Mar 22, 2018 12:54 pm
Sorry if I haven't been clear, but if the error code is 0, my log file outputs:
2018-03-22 12:28:34,NM_Test.h264,0
For any other code, it'll be a minus number:
2018-03-22 12:28:34,NM_Test.h264,-2
When I added the default case I got:
Currently Playing: 2018-03-22 12:34:53,NM_Test.h264,--
I assumed the function can't see the switch cases so I parsed the $res variable (at the end):
echo "Test PI <p></p>Status: <p></p><pre>Currently Playing: ".substr($res, 0, -2).ReturnError(substr($res, -1));
Output:
Currently Playing: 2018-03-22 12:42:24,NM_Test.h264,- Error code blank
My current set up:
Currently my log file is outputting:
2018-03-22 12:43:21,NM_Test.h264,-2
So I've set my cases up like:
  switch ($res)
    case "0":
    case "1":
    case "2":
    case "3":
   //all the way to case 15
I'll keep playing around with it, but is there anything you can see different that might explain where I'm going wrong?
PingoBags
Thu Mar 22, 2018 5:40 pm
I can't see a problem off hand but I am wondering why you used $res as your variable when calling ReturnError.
You should be using $output.
Also I though the code returned from your output was -0, with the minus. It should have still output something but I changed it anyway to reflect the true error code values.
Your new ReturnError would be written like this.
Use the minus for all the error codes besides the 0
  switch ($res)
    case "0":
    case "-1":
    case "-2":
    case "-3":
I broke the code down for easier reading and debugging
if($idx = strripos($output,','))//Get the last index of ',' in your output string
  $ErrorCode = substr($output,$idx + 1,(strlen($output) - $idx) - 1);//using the found index, get the error code using substring
  $Playlist = substr($output, 0, $idx + 1);//Get the rest of the output string, minus the error code
  echo "Currently Playing: ".$Playlist.ReturnError($ErrorCode);//The ReturnError function just replaces the error code with a custom error
Since I don't have your output file, I used my own for testing
$output = "2018-03-22 12:43:21,NM_Test.h264,0";
Currently Playing: 2018-03-22 12:43:21,NM_Test.h264, no errors reported
With error
$output = "2018-03-22 12:43:21,NM_Test.h264,-2";
Currently Playing: 2018-03-22 12:43:21,NM_Test.h264, Missing file
kainaat
Fri Mar 23, 2018 12:27 pm
It works.. hurray!!
Using your code and changing:
To just using exec:
$output = exec($command);
And now I can see the error messages!
Many thanks for your support!
PingoBags
Fri Mar 23, 2018 4:27 pm
Glad to help
