My 3B+ came from PiHut and was in an anti-static bag.
These things are designed for children in classrooms, so they must be robust, electrically and mechanically I would think.
All my Pi0, Pi0W and Pi0WH have come in anti-static plastic bags. The most recent being 3 Pi0WH boards that arrived less than a week ago.pi-anazazi wrote: ↑Sun Mar 18, 2018 4:46 pmHere about 15 pi 1, 2, 3 and 1 zero. All came in antistatic plastic (although I cannot 100% guarantee for the zero, but for the rest I still have the bags here.....)
The CPC/Element 14 box is NOT marked as anti-static packaging. The logo to the right of the dustbin means that the contents are sensitive to static and handling precautions should be observed. Look at the top two illustrations at https://en.wikipedia.org/wiki/Electrost ... ive_device to see the completely different meanings of the logo on your box and the logo on the paper bag pictured earlier in this thread.Pithagoros wrote: ↑Sat Mar 17, 2018 12:47 pmMine just arrived this morning from CPC, in a cardboard box, no bag but the box itself clearly marked on the outside as anti-static packaging.
It's an anti-static box instead of bag.
The antistatic bag, as seen here: viewtopic.php?f=63&t=208147#p1287144 clearly has the logo that says it has antistatic protection (the semicircle around the antistatic hand symbol, denotes its an EPA). it IS an antistatic bag.drgeoff wrote: ↑Sun Mar 18, 2018 5:46 pmThe CPC/Element 14 box is NOT marked as anti-static packaging. The logo to the right of the dustbin means that the contents are sensitive to static and handling precautions should be observed. Look at the top two illustrations at https://en.wikipedia.org/wiki/Electrost ... ive_device to see the completely different meanings of the logo on your box and the logo on the paper bag pictured earlier in this thread.Pithagoros wrote: ↑Sat Mar 17, 2018 12:47 pmMine just arrived this morning from CPC, in a cardboard box, no bag but the box itself clearly marked on the outside as anti-static packaging.
eupton wrote: ↑Sat Mar 17, 2018 4:23 pmThe boxes that we pack Raspberry Pi 3B+ (and recent units of earlier models) into at Sony contain conductive card which have the same effect as an anti-static bag. In practice I suspect it's overkill: I remember back in the day (2010) testing BCM2763 (BCM2835 but in a 9x9mm 0.4mm-pitch package with 128MB of RAM) units with the static gun and not being able to kill them until we turned the PCB itself black through repeated discharges.
@mahjonggmahjongg wrote: ↑Sun Mar 18, 2018 6:46 pmThe antistatic bag, as seen here: viewtopic.php?f=63&t=208147#p1287144 clearly has the logo that says it has antistatic protection (the semicircle around the antistatic hand symbol, denotes its an EPA). it IS an antistatic bag.drgeoff wrote: ↑Sun Mar 18, 2018 5:46 pmThe CPC/Element 14 box is NOT marked as anti-static packaging. The logo to the right of the dustbin means that the contents are sensitive to static and handling precautions should be observed. Look at the top two illustrations at https://en.wikipedia.org/wiki/Electrost ... ive_device to see the completely different meanings of the logo on your box and the logo on the paper bag pictured earlier in this thread.Pithagoros wrote: ↑Sat Mar 17, 2018 12:47 pmMine just arrived this morning from CPC, in a cardboard box, no bag but the box itself clearly marked on the outside as anti-static packaging.
I did have a little moan when I received my pi (from modmypi) bare in a box supposedly "without any static protection"
You clearly haven't been reading the forums lately.
Yeah...it all boils down to "Why isn't the Pi3B+ the Pi4B with the features *I* want?" Frankly, I am amazed that the RPF managed to pull this particular rabbit out of their collective hats. It's a truly impressive upgrade for something that didn't look to have any room for meaningful upgrades.HawaiianPi wrote: ↑Sun Mar 18, 2018 9:41 pmNot to mention all the moaning about the not-quite gigabit Ethernet, wired Ethernet still being part of the USB 2.0 hub chip, no USB 3.0, no 64-bit OS, still only 1GB of RAM, etc...
The improved heat management was certainly something that was needed. Sure, people that don't run their Pi3B hard could live without it, but the whole point of a more powerful computer is to use that power, and the Pi3B didn't manage heat well out of the box. The faster Ethernet, dual-band wireless AC and 200MHz speed increase were icing on the cake.W. H. Heydt wrote: ↑Sun Mar 18, 2018 9:52 pmFrankly, I am amazed that the RPF managed to pull this particular rabbit out of their collective hats. It's a truly impressive upgrade for something that didn't look to have any room for meaningful upgrades.
And the better antenna.HawaiianPi wrote: ↑Sun Mar 18, 2018 10:05 pmThe improved heat management was certainly something that was needed. Sure, people that don't run their Pi3B hard could live without it, but the whole point of a more powerful computer is to use that power, and the Pi3B didn't manage heat well out of the box. The faster Ethernet, dual-band wireless AC and 200MHz speed increase were icing on the cake.W. H. Heydt wrote: ↑Sun Mar 18, 2018 9:52 pmFrankly, I am amazed that the RPF managed to pull this particular rabbit out of their collective hats. It's a truly impressive upgrade for something that didn't look to have any room for meaningful upgrades.![]()
Hi DRGeoffdrgeoff wrote: ↑Sun Mar 18, 2018 5:46 pmThe CPC/Element 14 box is NOT marked as anti-static packaging. The logo to the right of the dustbin means that the contents are sensitive to static and handling precautions should be observed. Look at the top two illustrations at https://en.wikipedia.org/wiki/Electrost ... ive_device to see the completely different meanings of the logo on your box and the logo on the paper bag pictured earlier in this thread.Pithagoros wrote: ↑Sat Mar 17, 2018 12:47 pmMine just arrived this morning from CPC, in a cardboard box, no bag but the box itself clearly marked on the outside as anti-static packaging.
Mine arrived from CPC on 16th - the day before yours. Can you post a picture of yours?Pithagoros wrote: ↑Mon Mar 19, 2018 8:16 amHi DRGeoffdrgeoff wrote: ↑Sun Mar 18, 2018 5:46 pmThe CPC/Element 14 box is NOT marked as anti-static packaging. The logo to the right of the dustbin means that the contents are sensitive to static and handling precautions should be observed. Look at the top two illustrations at https://en.wikipedia.org/wiki/Electrost ... ive_device to see the completely different meanings of the logo on your box and the logo on the paper bag pictured earlier in this thread.Pithagoros wrote: ↑Sat Mar 17, 2018 12:47 pmMine just arrived this morning from CPC, in a cardboard box, no bag but the box itself clearly marked on the outside as anti-static packaging.
You have a different box from the one I have, with different markings.
mine came today and its from element14 and it was not in side any bag at all just in the box itself which is very odd ive yet to try it
Take another look. There should be what appears to be a piece of cardboard in there as well.marklola82 wrote: ↑Sat Jun 23, 2018 3:09 pmmine came today and its from element14 and it was not in side any bag at all just in the box itself which is very odd ive yet to try it
