Page 16 of 16
Re: New Raspberry Pi model 3B+ 1.4 GHz, 330Mbit Ethernet, 802.11ac, PoE
Posted: Tue Apr 17, 2018 2:26 pm
by B.Goode
i486 wrote:
Tue Apr 17, 2018 2:12 pm
B.Goode wrote:
Tue Apr 17, 2018 10:30 am
Is there any reason to think the RPi3B+ might be more restricted in this respect?
64GB is SDXC, not SDHC. 32GB is the limit for SDHC.
Quite right.
So if you are applying precise definitions then the original spec for SD cards was for up to 2GB.
So it is unlikely, by that definition, that the RPi 3B+ - or any other system - will support a 64GB SD card, which was what you asked.
Practically, the new RPi3B+ should be able to handle any capacity of microSD card presently available. Unless you have some reason to think otherwise?
Posted: Tue Apr 17, 2018 2:48 pm
by bensimmo
I'll just slip this in here
https://www.raspberrypi.org/learning/ha ... e/storage/
and this here, with a note on 64GB cards (NOOBS installs)
https://www.raspberrypi.org/documentati ... d-cards.md
