gregeric
Re: New Raspberry Pi model 3B+ 1.4 GHz, 330Mbit Ethernet, 802.11ac, PoE
Thu Mar 15, 2018 10:15 am
gtechn wrote:
Wed Mar 14, 2018 9:50 pm
An odd request, but I haven't seen any images of the backside of the Raspberry Pi 3 B+... Probably not notable because it doesn't have the (previously shiniest part of the Pi) wireless chip there anymore.
There's such an image on Pimoroni's Pibow 3B+ page: https://shop.pimoroni.com/products/pibo ... i-3-b-plus
kaiomatico
Thu Mar 15, 2018 10:30 am
So what exactly is meant by saying "improved usb boot support"? Also: is running raspbian off a fast usb 3.0 thumb drive still faster than running off an fast microSD card on the Pi 3 B+? Thanks
gkreidl
Thu Mar 15, 2018 10:50 am
tkaiser wrote:
Thu Mar 15, 2018 10:11 am
gkreidl wrote:
Thu Mar 15, 2018 10:07 am
fred44nl wrote:
Thu Mar 15, 2018 9:32 am
does it have to be Stretch, or will good old Jessie still work as well ??
mind you, I don't need 5 GHz wifi, as I have an ethernet cable.
I've asked the same question on the blog page and both Eben Upton and Simon Long answered. They don't plan to make the new firmware available for Jessie via apt-get upgrade.
That's what apt pinning is for -- see my post above ;)
Yeah, I've seen our post and agree that it is a better solution.
Minimal Kiosk Browser (kweb)
texy
Thu Mar 15, 2018 11:59 am
tkaiser wrote:
Thu Mar 15, 2018 9:50 am
If the assumption is correct that all the magic happens in kernel and firmware packages on Jessie you need a file /etc/apt/sources.list.d/stretch.list with these contents and a file called e.g. /etc/apt/preferences.d/99kernelandfirmware with those contents
Package: firmware-brcm80211 raspberrypi-bootloader raspberrypi-kernel
Pin: release n=stretch, origin archive.raspberrypi.org
Pin-Priority: 1000
Package: *
Pin-Priority: 490
Package: *
Pin: release n=jessie, origin archive.raspberrypi.org
Pin-Priority: 500
[MOD EDIT - NOT REQUIRED]
I deleted the reference to config.txt file, which is not necessary, to avoid confusion.
Texy
Thu Mar 15, 2018 12:12 pm
supra wrote:
Thu Mar 15, 2018 11:13 am
Imperf3kt wrote:
Wed Mar 14, 2018 8:06 pm
supra wrote:
Wed Mar 14, 2018 1:38 pm
I already orderd today. Can I ask you question, please. Can I used my 32gb microcard from my older rpi-3 to newest rpi-3B+?
Why would there be any reason you cannot? Its almost the same system.
All Pi models can interchange SD cards (provided the right adaptors are present if required.)
I tell you why.
(1)The older model will overheated and crashed during installed OpenCV 3.4.1
(2) It will overheated when using OpenCV 3.4.1.
The model 3B+ is very cheaper from the pihut :D :D :D
So the actual question is not whether you SD card will work in the new Pi, but whether the software on your SD card will work on your new PI?
I' m confused. What are you trying to do?
hansotten
Thu Mar 15, 2018 12:46 pm
Texy
Leaves the question, what does the reference do in config.txt.
It was mentioned several times now, Dougie e.g.
I do not know where the safe_mode_gpio settings are documented? safe_mode_gpio=4 had to do with giving more power coming from the USB ports, but also, not afaik official documentated?
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with 8 bit CPU's
mikerr
Thu Mar 15, 2018 1:00 pm
Lots of fixes to support a larger variety of USB devices - Eben talks about it here:
https://youtu.be/tncUe8QYLoQ?t=7m4s
6by9
Thu Mar 15, 2018 1:12 pm
Texy
It's related to pre-release boards and firmware only - I guess Dougie was one of the lucky few.
It's not required on any production boards.
pi-man-uk1
Thu Mar 15, 2018 1:17 pm
hi all,
so I've got the latest and greatest pi 3b+ and i was planning to simply swap out the SD card from the old Pi3.
I updated via apt beforehand... upgrade and dist-upgrade.
But here's the wierd thing, the new pi won't boot with the old updated sd card. I even plugged into a TV to see if I could see more and yes, I only get to the lightening bolt - so a power problem? V odd though as my PSUs are high amp rated and I've tried more than one. I've now burned a fresh sd card from the latest raspbian raspbian Stretch Litem, Minimal image based on Debian Stretch, Version: March 2018, Release date: 2018-03-13 - and it boots fine - so not power after all ?!
So any ideas what I can do to my old card to get it to boot in the new Pi 3b+? (i've got lots of softwre etc on it, pihole/ home assistant etc, so don't really want to start again).
do i need to try rpi-update (tried earlier but took ages and thn hung), so rebooted and reverted? Something else to try?
Some details below...
thanks...
pi@custard-pi:~$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@custard-pi:~$
pi@custard-pi:~$ sudo apt update
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://repo.mosquitto.org/debian wheezy InRelease
Hit:3 http://archive.raspberrypi.org/debian jessie InRelease
Hit:4 http://dl.ubnt.com/unifi/debian unifi5 InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
pi@custard-pi:~$ sudo apt dist-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@custard-pi:~$
pi@custard-pi:~$ ls -alh /boot
total 21M
drwxr-xr-x  5 root root  16K Jan  1  1970 .
drwxr-xr-x 23 root root 4.0K Aug 29  2017 ..
-rwxr-xr-x  1 root root  16K Mar 15 12:02 bcm2708-rpi-0-w.dtb
-rwxr-xr-x  1 root root  15K Mar 15 12:02 bcm2708-rpi-b.dtb
-rwxr-xr-x  1 root root  16K Mar 15 12:02 bcm2708-rpi-b-plus.dtb
-rwxr-xr-x  1 root root  15K Mar 15 12:02 bcm2708-rpi-cm.dtb
-rwxr-xr-x  1 root root  17K Mar 15 12:02 bcm2709-rpi-2-b.dtb
-rwxr-xr-x  1 root root  18K Mar 15 12:02 bcm2710-rpi-3-b.dtb
-rwxr-xr-x  1 root root  16K Mar 15 12:02 bcm2710-rpi-cm3.dtb
-rwxr-xr-x  1 root root  50K Mar 15 12:02 bootcode.bin
-rwxr-xr-x  1 root root  136 Jan  1  1980 cmdline.txt
-rwxr-xr-x  1 root root 1.6K Mar 20  2017 config.txt
-rwxr-xr-x  1 root root  19K Mar 15 12:03 COPYING.linux
-rwxr-xr-x  1 root root   41 Aug 29  2017 .firmware_revision
-rwxr-xr-x  1 root root 2.6K Mar 15 12:02 fixup_cd.dat
-rwxr-xr-x  1 root root 6.6K Mar 15 12:02 fixup.dat
-rwxr-xr-x  1 root root 9.6K Mar 15 12:02 fixup_db.dat
-rwxr-xr-x  1 root root 9.6K Mar 15 12:02 fixup_x.dat
drwxr-xr-x  2 root root 8.0K Jun 13  2016 .fseventsd
-rwxr-xr-x  1 root root  145 May 27  2016 issue.txt
-rwxr-xr-x  1 root root 4.4M Mar 15 12:03 kernel7.img
-rwxr-xr-x  1 root root 4.2M Mar 15 12:02 kernel.img
-rwxr-xr-x  1 root root 1.5K Mar 15 12:02 LICENCE.broadcom
-rwxr-xr-x  1 root root  19K May 27  2016 LICENSE.oracle
drwxr-xr-x  2 root root  16K Mar 15 12:03 overlays
-rwxr-xr-x  1 root root 645K Mar 15 12:02 start_cd.elf
-rwxr-xr-x  1 root root 4.8M Mar 15 12:02 start_db.elf
-rwxr-xr-x  1 root root 2.8M Mar 15 12:02 start.elf
-rwxr-xr-x  1 root root 3.8M Mar 15 12:02 start_x.elf
drwxr-xr-x  2 root root 8.0K Jun 13  2016 .Trashes
-rwxr-xr-x  1 root root 4.0K Jun 13  2016 ._.Trashes
pi@custard-pi:~$
tkaiser
Thu Mar 15, 2018 1:22 pm
a power problem?
Easy to check for BTW:
perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)"
This outputs a bunch of 0 and 1 that have to be interpreted this way:
1010000000000000000
|||             |||_ under-voltage
|||             ||_ currently throttled
|||             |_ arm frequency capped
|||_ under-voltage has occurred since last reboot
||_ throttling has occurred since last reboot
|_ arm frequency capped has occurred since last reboot
tkaiser
Thu Mar 15, 2018 1:27 pm
Can you provide output from
dpkg -l | grep 'raspberrypi-bootloader'
md5sum /boot/start_db.elf
fanoush
Thu Mar 15, 2018 1:29 pm
total 21M
I would expect bcm2710-rpi-3-b-plus.dtb there
texy
Thu Mar 15, 2018 1:30 pm
Texy
What 6By9 stated - so to stop any confusion, I've been removing the safe_mode comments from posts.
Texy
EdwinJ85
Thu Mar 15, 2018 1:31 pm
awesome news! Any word on the mesa/opengl driver status yet? Last I heard Eric Anholt was still working on it but that was a few years ago...
Hello!
pi-man-uk1
Thu Mar 15, 2018 1:38 pm
hi all,
more output as requested... if it's not obvious this is in the old model 3 (as new one doesn't boot)... I think it's obv. :-)
pi@custard-pi:~$ dpkg -l | grep 'raspberrypi-bootloader'
ii  raspberrypi-bootloader               1.20170703-1                 armhf        Raspberry Pi bootloader
pi@custard-pi:~$ md5sum /boot/start_db.elf
24fb5ffb1ef3041798de5f5472bf9295  /boot/start_db.elf
pi@custard-pi:~$
pi@custard-pi:~$ ls /boot/bcm2710-rpi-3-b-plus.dtb
ls: cannot access '/boot/bcm2710-rpi-3-b-plus.dtb': No such file or directory
pi@custard-pi:~$
tkaiser
Thu Mar 15, 2018 1:56 pm
As @fanoush already spotted: you're missing both firmware and kernel (.dtb) support on your SD card. So new board can't boot with this installation. Still curious about the output of (even when running on your old board):
rainer.brito
Great news!
I would like to ask if anyone already made some heat dissipation tests. Does heatsink still recommended for hot and dry countries (northeast brasil, in my case)? Is there any advice about using heatsinks on the new model?
Thanks;
pi-man-uk1
Thu Mar 15, 2018 2:02 pm
thanks,.
ok got it, need the files... ... do you know how i pull those missing files in correctly, I thought apt dist-upgrade was all I needed!? Do i need rpi-update
that perl command doesn't work for me ...
pi@custard-pi:~$ perl -e "printf \"%19b\n\", $(vcgencmd get_throttled |  -f2 -d=)"
-bash: -f2: command not found
                  0
pi@custard-pi:~$
tkaiser
Thu Mar 15, 2018 2:10 pm
That's what I understood too. Sorry for the wrong command, should read instead
pi-man-uk1
Thu Mar 15, 2018 2:12 pm
i'll try suo rpi-update
get a zero...
pi@custard-pi:~$ perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)"
                  0
pi@custard-pi:~$
Gergmchairy
Thu Mar 15, 2018 2:18 pm
Hi All,
My first 3B+ just arrived (to go with countless others) and I was suprised to get the power (lightning bolt) and failing to boot - even though its plugged into a Genuine Pi PSU ? Granted its rated 5v 2A - not 2.5A, but suprised none the less...
Greg
pi-man-uk1
Thu Mar 15, 2018 2:20 pm
Greg... see my stuff above - going through this stuff right now... Lightening bolt.
Not power though as I tried a fresh SD card from the latest image and it works.
I'm trying to get my original build to work in the new machine.
fanoush
Thu Mar 15, 2018 2:23 pm
for some reason you have old bootloader
it is unlikely that version from 2017/07/03 is recent enough
try sudo apt-get dist-upgrade
EDIT:
hmm when also seeing
you have quite interesting mix of stretch wheezy and jessie repositories can you remove the jessie and wheezy one?
Gergmchairy
Thu Mar 15, 2018 2:27 pm
Apologies chaps, i whizzed through the pages (s) must have skipped the relevant posts !
I'm re-downloading stretch lite and will try again...
Greg
pi-man-uk1
Thu Mar 15, 2018 2:36 pm
thanks - got rid of wheezy and jessie but still no dice... hmmm
anything else I can try to update ?
pi@custard-pi:~$ sudo apt-get update && sudo apt-get upgrade && sudo apt-get dist-upgrade
Hit:2 http://dl.ubnt.com/unifi/debian unifi5 InRelease
pi@custard-pi:~$
