Taxicletter
Is removing PCmanFM a good idea?
Tue Mar 13, 2018 10:37 am
I installed Thunar as filemanager because I like the side-panel and general appearance better. So I thought about removing pcmanfm, but I see that then lxde* lxde-core* pcmanfm* raspberrypi-ui-mods would also be removed. Besides, I think desktop-management and menu are also somehow connected to pcmanfm.
Will get in (big) trouble by removing pcmanfm?
Would I miss a desktop-manager and menu and all that?
Thanks for any input
--::--::- 3 x Raspberry Pi 3 - Raspbian Lite 9 - RuneAudio - one broke (wifi) - not in use -::--::--
ShiftPlusOne
Re: Is removing PCmanFM a good idea?
Tue Mar 13, 2018 10:40 am
No, it's not a good idea. The desktop icons are handled by pcmanfm as well. Removing ui-mods, will mess up themes and other settings.
If you want to try it, take a backup of the card first. Then you can see exactly what happens and whether the lost functionality affects and how you can work around it.
Taxicletter
Tue Mar 13, 2018 12:19 pm
I was afraid so. Thank you!
