soydepr
Fail2ban fails after upgrading to stretch
Sat Mar 10, 2018 3:45 pm
Getting this error when starting fail2ban
Docs: man:fail2ban(1)
Process: 11060 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
Mar 10 10:44:15 coqui systemd[1]: fail2ban.service: Control process exited, code=exited status=255
Mar 10 10:44:15 coqui systemd[1]: Failed to start Fail2Ban Service.
Re: Fail2ban fails after upgrading to stretch
Sat Mar 10, 2018 3:52 pm
Open a LXTerminal and run sudo /usr/bin/fail2ban-client -v -v -v start that should tell you what's wrong with your configuration files.
This is a doctor free zone.
soydepr
Sat Mar 10, 2018 4:54 pm
Thanks Idouglas.
ERROR Failed during configuration: While reading from '/etc/fail2ban/jail.conf' [line 155]: option 'port' in section 'pam-generic' already exists
Not sure how to fix this ?
Sat Mar 10, 2018 4:57 pm
Edit your /etc/fail2ban/jail.conf and/or /etc/fail2ban/jail.d/defaults-debian.conf to ensure nothing is defined twice.
soydepr
Sat Mar 10, 2018 5:04 pm
My guess i need to remove line 155. Port-any port ?
# port actually must be irrelevant but lets leave it all for some possible uses
port = all
banaction = iptables-allports
port = anyport
logpath = /var/log/auth.log
maxretry = 6
nope that didn't work
Sat Mar 10, 2018 6:09 pm
You should be looking for [pam-generic] being duplicated between the two files.
soydepr
Sat Mar 10, 2018 6:25 pm
This is what i have
# Generic filter for pam. Has to be used with action which bans all ports
# such as iptables-allports, shorewall
[pam-generic]
enabled = false
# pam-generic filter can be customized to monitor specific subset of 'tty's
filter = pam-generic
Iptables shows
target prot opt source destination
fail2ban-ssh tcp -- anywhere anywhere multiport dports ssh
Sat Mar 10, 2018 8:16 pm
Run this
cd /etc/fail2ban
sudo grep -R -i 'pam-generic' *
On my system I've got that piece commented out.
[email protected]:/etc/fail2ban # grep -R -i 'pam-generic' *
filter.d/dovecot.conf:# * the first regex is essentially a copy of pam-generic.conf
jail.conf:#[pam-generic]
jail.conf:# pam-generic filter can be customized to monitor specific subset of 'tty's
soydepr
Sat Mar 10, 2018 9:28 pm
[email protected]:/etc/fail2ban# grep -R -i 'pam-generic'*
jail.conf:[pam-generic]
jail.conf:filter = pam-generic
jail.conf.dpkg-dist:[pam-generic]
jail.conf.dpkg-dist:# pam-generic filter can be customized to monitor specific subset of 'tty's
thanks for your help. .... eventually I remove fail2ban. rm -rf /etc/fail2ban. and then install it and it works but now I am missing jail.conf
many thanks for your input
soydepr
Sat Mar 10, 2018 9:53 pm
someone share jail.conf as it missing now
soydepr
Wed Mar 14, 2018 8:48 am
Since this still not working i decided to try downloading from github now i get this error
fail2ban.service: Cannot add dependency job, ignoring: Unit fail2ban.service
Wed Mar 14, 2018 9:09 am
Try this:
sudo -s
apt purge fail2ban
apt install fail2ban
exit
It gives you ssh protection out of the box with no modifications. You can then save copies of files you're going to change and change one thing at a time and test your modifications.
soydepr
Wed Mar 14, 2018 1:05 pm
That work thanks
