vk4tec
Sending a display from SSH
Tue Mar 06, 2018 6:05 pm
Does anyone know how to start up a program and send it to display 0 ?
I can SSH into the pi
I have a HDMI screen connected
I want to start say a browser but have it come up in display 0
Andrew
Andrew Rich
email: [email protected]
http://www.tech-software.net/ ( hobby website )
http://59.167.159.165/ ( Raspberry Pi ADS-B server ) RTL SDR
FTrevorGowen
Re: Sending a display from SSH
Tue Mar 06, 2018 6:41 pm
Andrew
I'm not quite sure what you mean by "send it to display 0". What you can do, if using something like PuTTY to login to a Pi via SSH from another (Linux) computer that supports X-Windows is enable X-Forwarding in PuTTY**. In that situation any GUI-based program can/will display on the remotely logged in m/c. (I do this quite regularly from my Debian 8 PC**** w/o using full VNC methods). Of course you could use full VNC methods:
http://www.cpmspectrepi.uk/raspberry_pi ... Pixel.html (see the blog archive for more up to date info: https://www.raspberrypi.org/blog/archive/ )
Trev.
** FWIW some (old) notes here: http://www.cpmspectrepi.uk/raspberry_pi ... aspPi.html
**** Some PuTTY screenshots for three Pi's on said PC here: http://www.cpmspectrepi.uk/raspberry_pi ... iPiTV.html
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
vk4tec
Tue Mar 06, 2018 6:44 pm
In LINUX or UNIX you can specify a destination such as display :0
Andrew
Andrew Rich
klricks
Tue Mar 06, 2018 7:12 pm
Andrew
DISPLAY=:0 chromium-browser
fbe
Tue Mar 06, 2018 7:20 pm
It works if you ssh into the Pi as user pi and your Pi boots into desktop with automatic login as user pi (which is the default).
n67
Tue Mar 06, 2018 7:28 pm
True, but it kinda begs the question of why we are doing this.
Some people interpreted the problem as being "How do I forward X connections back to my main computer?" (using something like PuTTY or similar). That may be closer to the mark even though the above answers well the question as posted literally.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
FTrevorGowen
Tue Mar 06, 2018 7:47 pm
Andrew
True, but IIRC that's the main display (and therefore doesn't/shouldn't need to be specified) but does assume that a desktop is "up and running". Hence, my question as to what you meant by it. Historically, and again IIRC, the only reason for specifying (or setting the equivalent environment variable) a "display" was if "x-forwarding" or its equivalent was being/had been set up manually to enable (GUI-)programs running on one m/c to display (and be controlled from) another. Sometimes that manual process wasn't performed correctly leading to unwanted windows "popping up" on the "wrong" m/c. So, to clarify the situation for us, what, exactly were you wanting to do or expecting to happen?
Trev.
vk4tec
Tue Mar 06, 2018 8:11 pm
Trying to make a browser come up on boot
Andrew Rich
FTrevorGowen
Tue Mar 06, 2018 8:19 pm
O.K. But that requires booting to desktop to have completed (and be enabled) and knowing where and when to start up said browser (I haven't needed to do anything like that so can't "fill in any details"). I wonder if you really need something like a "Kiosk Browser" system (Kweb suite).
Trev.
vk4tec
Tue Mar 06, 2018 8:28 pm
This all stems from not being able to get kiosk working
Tried the auto start file
No luck
Trying to make a car display
Andrew
Andrew Rich
klricks
Tue Mar 06, 2018 8:40 pm
No luck
Andrew
Edit autostart:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
The command to add to autostart should look something like this:
@chromium-browser -kiosk http://www.raspberrypi.org
Use [Alt] [F4] to exit
vk4tec
Wed Mar 07, 2018 2:54 am
[email protected]:~$ chromium-browser -kiosk http://www.raspberrypi.org
[1344:1344:0307/025418.852772:ERROR:browser_main_loop.cc(582)] Failed to put Xlib into threaded mode.
(chromium-browser:1344): Gtk-WARNING **: cannot open display:
Andrew Rich
klricks
Wed Mar 07, 2018 3:32 am
Not clear what you are doing or wanting?????
To start Chromium or any other GUI from a SSH session and have it open on the local console (HDMI monitor) then:
DISPLAY=:0 chromium-browser -kiosk http://www.raspberrypi.org
If you want to have Chromium autostart on each boot then see my previous reply. No SSH login needed.
To start from a LXterminal prompt:
As has been mentioned in all cases above, Raspbian must be set to boot to desktop with either an HDMI monitor attached or force hotplug setting enabled in config.txt
vk4tec
Wed Mar 07, 2018 3:37 am
I did the autostart
Nothing happened
Rebooted
Andrew
Andrew Rich
klricks
Wed Mar 07, 2018 4:02 am
Did you do exactly as I wrote? Same CaSe and no extra spaces.....
Note that there is more than one autostart file. If you edit the wrong one then it won't work. Many tutorials on the web show the wrong one.
FYI - For testing you can logout and back in..... Much faster than rebooting.
