dupreejr
2.8 touch screen and Rpi ZW GPIO setup
Wed Feb 14, 2018 7:25 am
Good morning or good afternoon, does anyone know if its possible to reverse the pin assignments on the RPi zero. I got a 2.8 LCD touch screen the other day and I soldered the header on the top of the zero. Only to find out the manufacture expected the head to soldered on the bottom. it works I just have to use an old hard drive fourth pin cable to connect to it.
Thank you,
mlepage
Re: 2.8 touch screen and Rpi ZW GPIO setup
Thu Feb 15, 2018 4:15 am
Depends, you could perhaps in software change some GPIOs used, but some (e.g. power) will not be able to be changed.
You could watch some de-soldering videos on YouTube to see if it's feasible in your case to remove the header and re-install it (or a new one).
Or keep that Zero as is, and get a new one to do the way you want it.
