JeanLeGrand
Difference Running program from Python Shell or Terminal
Thu Feb 01, 2018 1:00 pm
I have a program that perfectly runs under Terminal but when I run it from Python 3 Shell it gives errors. Anybody an idea how to solve it
File "/home/pi/.local/lib/python3.5/site-packages/numpy/core/__init__.py", line 16, in <module>
from . import multiarray
ImportError: libf77blas.so.3: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/home/pi/grove_led_blink.py", line 37, in <module>
from grovepi import *
File "/home/pi/Desktop/GrovePi/Software/Python/grovepi.py", line 50, in <module>
import numpy
File "/home/pi/.local/lib/python3.5/site-packages/numpy/__init__.py", line 142, in <module>
from . import add_newdocs
File "/home/pi/.local/lib/python3.5/site-packages/numpy/add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "/home/pi/.local/lib/python3.5/site-packages/numpy/lib/__init__.py", line 8, in <module>
from .type_check import *
File "/home/pi/.local/lib/python3.5/site-packages/numpy/lib/type_check.py", line 11, in <module>
import numpy.core.numeric as _nx
File "/home/pi/.local/lib/python3.5/site-packages/numpy/core/__init__.py", line 26, in <module>
raise ImportError(msg)
ImportError:
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control). Otherwise reinstall numpy.
Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
[/color]
klricks
Re: Difference Running program from Python Shell or Terminal
Thu Feb 01, 2018 2:05 pm
Does it work from Python 2 shell?
Note that terminal defaults to Python 2 unless you specifically use python3.
JeanLeGrand
Thu Feb 01, 2018 4:55 pm
Yes it does,
Any manner to change it defaulting Python 3 as main Shell ??
penguintutor
Fri Feb 02, 2018 1:34 pm
Is that really what you want to do, as that will break it when you run from the shell as well as from the python shell?
If so then the version of python that runs is based on a link in /usr/bin - so that when you run /usr/bin/python it calls /usr/bin/python2.7
You can remove that link and replace it with a link to /usr/bin/python3.5 - however there is a risk that could break something else that can only run under Python 2, so I'd only do that if you know what you are doing.
A better alternative is just to type python3 whenever you want to run the python shell.
This won't fix your problem though.
It sounds like the real problem is due to a NumPy not being installed correctly for Python 3. Did you try installing NumPy manually?
It is available in apt so you could
sudo apt-get install python3-numpy
or if it has been installed previously but isn't working then
sudo apt-get install --reinstall python3-numpy
