TheWaterbug
(How) Can I copy a compiled binary from Pi 2B to Pi 3?
Sat Jan 27, 2018 10:30 pm
Linux n00b here.
I am following these instructions to compile the hw accelerated version of ffmpeg on my Pi 2B. It's taking a long time.
Once it's finished, can I copy the compiled binary over to my Pi 3? Is it as simple as copying the binary file "ffmpeg"? Or do I need to copy other stuff over as well?
Thanks!
ejolson
Re: (How) Can I copy a compiled binary from Pi 2B to Pi 3?
Sat Jan 27, 2018 10:51 pm
I think a build of ffmpeg includes libraries such as libavcodec and many other things, all of which need to be copied to the other system. Assuming you installed ffmpeg in /usr/local, type "find /usr/local -mmin -30 -print" immediately after "make install" to list all files which have been modified in the last 30 minutes. These are the files which need to be copied.
W. H. Heydt
Sun Jan 28, 2018 3:04 am
An executable compiled on a Pi2B should run on a Pi3B, but to be sure it would be best if the Pi2B it's compiled on is a Pi2Bv1.2. The Pi2Bv1.2 and Pi3B have the same model of ARM CPU cores.
