HawaiianPi
Re: Wireless firmware testers wanted
Thu Mar 15, 2018 11:29 am
I just did a dist-upgrade on my Pi3B which has 2017-11-29 Stretch, and when I rebooted it connected to my router just fine. But I really wasn't having any trouble before, so... ¯\_(ツ)_/¯
Is this the correct, expected result?
~ $ dmesg | grep brcmfmac
[    6.571066] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    6.576610] usbcore: registered new interface driver brcmfmac
[    6.777050] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[    6.777826] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[    8.476910] brcmfmac: power management disabled
Thu Mar 15, 2018 12:15 pm
MrEngman wrote:
Thu Mar 15, 2018 11:26 am
jamesh wrote:
Thu Mar 15, 2018 11:09 am
MrEngman wrote:
Thu Mar 15, 2018 10:57 am
Just created a new SD card using the latest kernel image 2018-03-13-raspbian-stretch-lite and the wifi is now working.
Updated to kernel 4.14.26 using rpi-update and it is still working.
I suspect a issue in the update for the Pi3.
To double check the wireless version is what I hope it is, can you
And get the firmware version and date?
Ran dmesg | grep brcmfmac when it failed and it is in my post 3 posts back.
Now it is working dmesg | grep brcmfmac now shows
[email protected]:~ $ dmesg | grep brcmfmac
[    3.681700] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    3.695297] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[    3.695557] usbcore: registered new interface driver brcmfmac
[    3.918345] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[    3.919257] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[    5.233058] brcmfmac: power management disabled
Shows a difference in the firmware version. I'm sure at some point I loaded the firmware you suggested to revert to a working version using
wget http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpi2_all.deb
sudo dpkg -i firmware-brcm80211_20161130-3+rpi2_all.deb
but seems it may have changed again.
Yes, we rolled back the new firmware because of a couple of issues with 4.9, we have now backported the commit that was missing, and have now rolled forward to the new firmware. So everything should now be up to date - and appears to be so from your dmesg.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
macmpi
Thu Mar 15, 2018 1:00 pm
Can you please be specific about the actual packages and files versions to be expected then?
Would really be helpful to see this information stated into one single post, rather than making guesses out of logs and discussions.
macmpi
Fri Mar 16, 2018 10:59 am
Self-answering as per this:
firmware-nonfree (or firmware-brcm80211) 1:20161130-3+rpt3 in stretch (so Jessie installs won't get it)
* Add brcmfmac43455-sdio version 7.45.154 (new for Pi3+)
* Update brcmfmac43430-sdio to 7.45.98.38
Tfontoura
Sat Mar 17, 2018 9:59 pm
I tested the firmware, wifi worked fine, however there were issues with bluetooth. I was able to make BT work only in one session somehow, the signal was very good, but it stopped working and nothing would make it work again. Went back to the old firmware and everything works fine - BUT bluetooth signal is very "weak", speaker plays only until about 12-15 inches, no farther then that. RSSI shows 0 what should be a good signal. But farther than 15 inches, stutters and stream stops/locks.
Raspberry PI Zero W
Raspian Stretch
[   14.203427] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[   14.243953] usbcore: registered new interface driver brcmfmac
[   14.944407] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[   14.945671] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[   35.556700] brcmfmac: brcmf_cfg80211_stop_ap: setting AP mode failed -26
[  100.686217] brcmfmac: power management disabled
Fri Jul 13, 2018 9:45 am
Hello again,
For those peoiple using the Official Dongle, we have updated firmware that needs testing.
Please see here for more details . viewtopic.php?f=63&t=187256&start=25#p1340347
heatina
Mon Aug 27, 2018 11:52 pm
I'm running jessie on rpi zero w headless so used wget on the previous link...
https://github.com/RPi-Distro/firmware- ... 0-sdio.bin
Now looking at this thread more, I'm worried if this is actually the lastest correct one.
Dmesg shows,
Brcmfmac version Oct23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Thanks in advance.
