VladyslavVolskyi
PC<->eth1(usb adapter)<->eth0<->internet
Sat Jan 20, 2018 7:57 pm
Hello Everyone, who is reading this topic :D
Could You help me to make suck kind of work.
I want to connect my PC with ethernet cable to usb adapter(USB-Ethernet)-> eth1 on raspberry pi(raspbian) routing trafic from eth1 to eth0, and eth0 will be connected to router with Internet. What and how should i do it, that at the result my PC will have Internet conection.
I use Raspbian stretch lite.
The main problems i have:
1) which ip address should be gived on each device and how, as i used a lot of different utilities.
2) How to route trafic from eth0<->eth1. Tried different programs and itables too, but it is very difficult for me.
At the end i want to achieve - filter packages from my PC on rpi. I am a new user of rpi and raspian. :shock: :shock:
vladnt
Re: PC<->eth1(usb adapter)<->eth0<->internet
Sun Jan 21, 2018 8:06 am
You must configure NAT
something similar..... ))))
1. Add or fix string net.ipv4.ip_forward=1 in /etc/sysctl.conf
2. iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
Google search iptables NAT )
thagrol
Sun Jan 21, 2018 5:20 pm
You could use bridging rather than NAT. With bridging, you PC would get it's IP address etc from your router.
Take a look at https://wiki.debian.org/BridgeNetworkConnections it's for debain but that's what raspbian is based on.
Arguing with strangers on the internet since 1993.
pi-anazazi
Sun Jan 21, 2018 6:30 pm
...I use some raspis with 2 (two) USB-ethernet adapters in bridged mode running Wireshark (monitoring internet traffic of the "PC" in your example, which is coupled to one of the USB-RJ45), using the built-in RJ45 to access the (headless) raspi.
Bridging the two USB-devices (as sudo):
ifconfig eth1 -arp promisc 0.0.0.0 up
ifconfig eth2 -arp promisc 0.0.0.0 up
brctl addbr br0
brctl addif br0 eth1
brctl addif br0 eth2
ifconfig br0 -arp promisc 0.0.0.0 up
Kind regards
anazazi
