janob
MPG2 acceleration doesn't work
Thu Jan 11, 2018 11:41 am
Hi all,
I have RPi3, MPG2 licence, modified config.txt.
pi@raspberrypi:~ $ vcgencmd codec_enabled MPG2
MPG2=enabled
pi@raspberrypi:~ $ vcgencmd get_mem gpu
gpu=128M
But output from "glxgears" is approx. 10 - 11 fps in both cases (doesn't matter if MPG2 enabled / disabled), CPU is working on 100% on that time.. When I try to display movie file with omxplayer, it lags, or is frozen (vlcplayer as well).
I checked serial number with my order and everything seems to be OK.
What should I do?
Re: MPG2 acceleration doesn't work
Thu Jan 11, 2018 11:52 am
I would not expect a coded, for decoding some video format, to make any difference to 3D rendering performance.
Can't account for the video player lock ups.
Do you have 3D rendering disabled? I think you should.
Thu Jan 11, 2018 12:43 pm
As above, glxgear is not affected by a codec.
What specific video format is the file you are trying to play? Use omxplayer btw, that is the HW accelerated player.
janob
Thu Jan 11, 2018 1:13 pm
As I wrote already - I used omxplayer (tried vlcplayer as well). The file was mpeg2 format. OS raspbian.
What was surprising me - the CPU load 100% in both cases (acceleration on / off) ...
6by9
Thu Jan 11, 2018 2:50 pm
The standard VLC doesn't use the hardware acceleration.
Omxplayer ONLY uses the hardware acceleration, so if you get anything then it is using it.
NB MPEG2 is a video codec, unless your talking of an MPEG2 transport stream. A file will typically be a container with multiple encoded streams in it.
What resolution and frame rate is your video clip? And what audio codec (audio is decoded on the ARM). "avprobe filename.mp4" ("sudo apt-get install libav-tools" if you haven't already installed it).
janob
Fri Jan 12, 2018 9:16 am
I'm not at my RPi right now - I will try today evening (CET).
