newpipe wrote:
Now I'm wondering if the reason for the big number of incompatible SD-Cards (for the Raspi) is caused by the fact that many SD cards are still consuming too much power...
I think you have something here and am confused as to why this is not a standard part of the debugging regimen. (or why the max raspi SD max ma supply etc. is not as widely known as similar USB constraints.)
In fact, I have a Transcend 16gb class 6 card, raspi, and a card reader.
Using my pc and the card reader I can not copy 1gb to the card, because the card always unmounts in the middle of the transfer. Using my laptop w integrated card reader, I have no problem. Using the raspi, *** I get usb wifi problems and processes hung in syscalls w stack dumps in syslog.
Recently I moved the ext4 partition to a USB stick. Now, instead of dieing every 4ish hours, it dies every several days.
I just bought a class 4 sandisk 16gb and using the same card reader as above, i copied 1gb without issue.
The lesson? I think SD card power issues are huge contributors to stability issues and info surrounding this should take higher priority when buying/debugging a setup. (Is there even a point on the board to measure this w a multimeter?)
*** I think these issues are correlated but have not proved it absolutely. I will switch to the sandisk card this week and i expect that i will be much more stable.
Michael
