steve041264
Config Raspberry by Debian
Wed Jan 03, 2018 8:48 am
Good morning, I've installed, by NOOBS, Raspbian and all features of Raspberry doesn't work, neither shutdown, reboot or logout commands. So I've downloaded Raspbian and played with VMware and all commands work properly. Someone can help me to understand why, or has some solution?
Re: Config Raspberry by Debian
Wed Jan 03, 2018 10:58 am
Sorry, it's not clear what your actual problem is.
You say "I've downloaded Raspbian .... all commands work properly."
So what is the problem?
It's not clear to me why you are mentioning Debian and vmware here.
I would never use NOOBS. It seems to cause more problems than it solves, judging by the questions that turn up here all the time.
Just download and install Raspbian to your Pi and all will be fine.
If not, come back and state the problem exactly.
Wed Jan 03, 2018 11:22 am
Raspbian does not run in VM as Raspbian requires ARMHF architecture.
Regards Raspbian Stretch with Desktop just download the .zip
https://www.raspberrypi.org/downloads/raspbian/
Then use Etcher to create from the .zip a bootable SD Card:
https://etcher.io/
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
Who is online
Users browsing this forum: lewmur, mahjongg, W. H. Heydt and 65 guests
