Xenoshell
vainfo returns error. What driver do i need?
Wed Jan 03, 2018 8:34 am
i am trying to get a usb-camera working on my raspberry pi3 with ubuntu mate.
I already have the basic stuff of gstreamer installed.
The output of the command
vainfo
is:
[email protected]:~$ vainfo
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/arm-linux-gnueabihf/dri/vc4_drv_video.so
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
The file vc4_drv_video.so doesnt exist in this folder. What do in need to install to get this file?
Greets
Xeno
PS: Also if i am in the wrong subforum im sorry and just push this topic somewhere else
topguy
Re: vainfo returns error. What driver do i need?
Wed Jan 03, 2018 9:37 am
Afaik VAAPI is a accellerated API for playing Video developed by intel. So I dont think there exist a VC4 driver for it. ( I might be wrong )
Also I dont think VAAPI is relevant for getting a usb-camera to work.
You should maybe look at https://www.mankier.com/1/v4l2-ctl instead.
Xenoshell
Wed Jan 03, 2018 11:55 am
What am i supposed to do with this? Its a tool to control video4linux drivers.
I am using the camera in a GUI built with Qt5 so i dont know if and how i could use it.
I try to get the camera to show up but till now it just a black screen
topguy
Wed Jan 03, 2018 12:17 pm
What were you expecting to use "vainfo" for ?
QtMultimedia either uses V4L2 driver directly or via gstreamer. So if you are unsure if your camera is detected properly/correclty then investigating the V4L2 driver seemed like a good place to start.
There is of course a lot of other software to test with ( https://wiki.archlinux.org/index.php/we ... our_webcam ) to either verify that your camera is correctly installed or working.
Just looking to see if you have "/dev/video0" present should tell you that the camera is detected and no additional drivers should be needed.
ghans
Wed Jan 03, 2018 12:31 pm
You should look into V4L2 instead of VAAPI. VAAPI is the wrong address if you want to play around with cameras/video input devices.
sudo apt-get install qv4l2
QV4L2 is a nice app to play around with/test cameras (written with Qt !). If you want to use the offcial camera module don't forget to load its official driver, too.
ghans
Who is online
Users browsing this forum: eupton, Imperf3kt, LTolledo and 68 guests
