pigpio cleanup doesnt release gpio pin
Posted: Tue Jan 02, 2018 10:36 pm
by Kalman
Hi folks!
Needed to change an air-fan. Mowed/mounted over a lid regulating the airflow. The lid is turned by a servo motor. To find out the new positions I try to run a short tesprogram under Python3
First in terminalwindow I start the sudo pigpiod
Then start Python 3
Write commando after the pyton prompt>>>>
This is the program I wrote doing the same job.
import pigpio
pi = pigpio.pi() # Connect to local Pi.
pi.set_mode(12, pigpio.OUTPUT)
pi.set_servo_pulsewidth(12, 1550) #closed
pi.set_servo_pulsewidth(12,1400) #open a little
pi.stop()
Functions okey.
The problem is when pi.stop( )is executed the servomotor has small diminutive vibrations and the big problem is it doesn't release the motor. So I can not turn the lid by hand untill I shut of power from the engine. And after reconnected the power the lid/servomotor turns imidiatly back to the latest position.
What shall I write to avoid this?
I need to able to turn the lid/servomotor by hand, free it up, and the "main" program shall turn it to the next position where ever I have turned it. But let it wtay where I put it untill that time.
Some helping with this , maybee Joan?
Thank You.
Re: pigpio cleanup doesnt release gpio pin
Posted: Wed Jan 03, 2018 12:34 am
by pcmanbob
Most modern servos will hold the last posting they are instructed to move to, that's how servos are designed to work.
So no you cant turn them manually while power is still applied even after you stop sending them commands.
You may find a stepper motor is what you need as once you stop powering the individual coils you find you can turn it easily by hand.
Posted: Wed Jan 03, 2018 4:28 am
by saltydog
Set it to 0 (off)
import pigpio
pi.set_servo_pulsewidth(12,0)
pi.stop()
Posted: Wed Jan 03, 2018 5:00 am
by saltydog
IIRC, pi.stop only cleans up the socket connection to the pigpio daemon, started when you created the instance pi = pigpio.pi()
Chris
Posted: Wed Jan 03, 2018 5:32 am
by saltydog
Can you use a magnetometer to determine and set your current servo position?
Chris
Posted: Wed Jan 03, 2018 8:20 am
by joan
The Python pigpio module does not change any user settings when pi.stop() is called. It does not try to double guess the user's intentions. The user must manually do any needed termination.
If you want to stop servo pulses set 0 (as mentioned by saltydog).
Posted: Thu Jan 04, 2018 3:36 pm
by Kalman
Thank You all for your patience with me. :)
I just forgot the:
It works now and free the lid and no "jitter"
Thanks.
