gowthamidentity
Python2 not compatible with HSC sensor library
Tue Jan 02, 2018 3:19 pm
Hello all,
I'm very new to Raspberry pi controller. I'm using Raspberry pi zero w for my project. I need to connect my Raspberry pi to the mobile application(android).
I've programmed the communication part based on python2. But I've added 1 more sensor which was programmed by my colleague in python3. After combining both the programs, commuication part is not working in python3 and sensor is not working in python2. Please hel[p me in finding a solution or idea that I can look for.
Following is the program for the sensor (python3). I don't know which function is not working in python2.
import smbus
import time
bus = smbus.SMBus(1)
dev_addr = 0x28
def bin_8(num):
 return format(num,'#010b')[2:]
def read_data():
 t = time.time()
 while t - time.time() < 5:
  temp = bus.read_i2c_block_data(dev_addr, 0x00, 4)
  condition = temp[0] & 0b11000000
  temp[0] = temp[0] & 0b00111111
  if condition == 0:
   bit = temp[0]*256 + temp[1]
   pressure = (((bit - 1638)*20)/(14745-1638)-10) * 10.197
   t_bit = temp[2]*8 + int((temp[3]&0b11100000)/0b100000)
   temperature = (t_bit/2047*200)-50
   return pressure
  time.sleep(0.1)
 return -1
def read_temp():
 if condition == 0:
  return temperature
def burst_read_data(time):
 temp = 0
 for i in range(0,time):
  temp += read_data()
 return temp/time
topguy
Re: Python2 not compatible with HSC sensor library
Tue Jan 02, 2018 3:32 pm
And you get no exceptions or errors when you run the program under Python2 ? It just produces no data ?
Tue Jan 02, 2018 3:35 pm
The best idea is to update your code to use Python 3. If I understand correctly the required changes are not huge.
See here for info: https://docs.python.org/3/howto/pyporting.html
gowthamidentity
Tue Jan 02, 2018 3:51 pm
Following is result of data which I get . In python2 the sensor readings are not correct.
pi@raspberrypi:~ $ python2 func_lid_special_withoutdisplay.py
-6.1182
-6.1182
-6.1182
-4.0788
-6.1182
-5.0985
-6.1182
-7.1379
-6.1182
-6.1182
-5.0985
-4.0788
^C
pi@raspberrypi:~ $ python3 func_lid_special_withoutdisplay.py
-0.5897097734035244
1.0456067750057216
-0.08557793545433708
-0.0933577477683678
-0.6363886472877086
1.6446523231860888
2.074097962920578
2.141004348821242
-0.9429132524605155
gowthamidentity
Tue Jan 02, 2018 3:55 pm
Heater wrote: The best idea is to update your code to use Python 3. If I understand correctly the required changes are not huge.
I'm trying to use bluetooth with this. But I'm unable to use socket programming with python3 and android application. I'm not clear whether the python uses BLE or classic bluetooth
Jednorozec
Tue Jan 02, 2018 4:13 pm
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
Tue Jan 02, 2018 4:37 pm
Python is insane.
They broke division operator after all these years. For goodness sake. How nuts is that?
Better to use a language with some proper standardization behind it. C, C++, Javascript etc.
Jednorozec
Tue Jan 02, 2018 4:51 pm
“The wonderful thing about standards is that there are so many of them to choose from.”
― Grace Murray Hopper
Tue Jan 02, 2018 5:00 pm
An oft' quoted phrase.
Totally out of context here as no version of Python is any kind of recognized standard.
It's just a hobbyist hack.
gowthamidentity
Wed Jan 03, 2018 2:21 pm
This may be your problem http://www.informit.com/articles/article.aspx?p=1439189
Thank you so much. This solved my issue. ;) ;)
Who is online
Users browsing this forum: dcaccount, HermannSW and 54 guests
