Failure in file transfer with sftp
Posted: Wed Dec 20, 2017 9:50 am
I Raspberry Pi 2 as a Torrent Box. I recently attach to it an external usb HDD formatted in NTFS. I can download successfully any file in the hardisk but when I try to connect to my Raspberry with Filezilla and trying to download file stored in the external disk I got this error message:
I also run the command to see how much free space I have and this is the output:
I don't have any problem with the space.
The permissions of the folder are given recursively and are:
So, what is the problem?
error while reading: received failure with description 'Failure'
Transfer FailedCode: Select all
df -hCode: Select all
File system Dim. Usati Dispon. Uso% Montato su
/dev/root 5,9G 3,9G 1,8G 69% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 6,5M 456M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 462M 0 462M 0% /sys/fs/cgroup
/dev/mmcblk0p6 65M 21M 45M 33% /boot
/dev/sda1 233G 875M 233G 1% /media/pi/external-hardisk
tmpfs 93M 0 93M 0% /run/user/1000The permissions of the folder are given recursively and are:
drwxrwxrwx 1 root root 4096 dic 16 17:30 external-hardisk
