Superstone
LAN / Ethernet not working on Raspberry pi 3
Wed Nov 22, 2017 10:39 pm
I have connected my Ethernet cable to the raspberry pi. The indicator light blink but my browser said "No Internet Connection". The wifi icon also change to cellular like icon.
broe23
Re: LAN / Ethernet not working on Raspberry pi 3
Thu Nov 23, 2017 7:43 am
Open up a terminal and run ifconfig > wired.txt along with iwconfig >wireless.txt
Both files will save to your directory in Home under your username. If you want those files saved in downloads, you would just do a cd >Downloads , then run the two commands I posted and the files will be saved in the downloads directory. Just remember that the word 'd' is capitalized and Linux does not ignore that without some changes.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
willieaames
Thu Nov 23, 2017 7:49 am
My guess is that your pi is in manual mode and is either not pulling the DNS from your router and/or not getting an IP.
