Fauveboy
Format SD card
Sun Nov 19, 2017 11:23 pm
Im trying to format my raspberry pi sd card but it it wont let because it says its write protected? How can I get rid of this? thanks
bucker
Re: Format SD card
Sun Nov 19, 2017 11:26 pm
Look for a small switch in your SD card labeled "Lock" and you're good to go.
Winning is for losers.
Pi Zero W (inside a Pikachu case ;) ) with DietPi running Sonarr,Couchpotato,Pi-hole,Pi-VPN
Pi B running Home Assistant
Pi 2B & HiFiBerry DAC+ running Volumio OS
Pi 3B (inside a genesis case 8-) ) running RetroPie
pcmanbob
Re: Format SD card
Mon Nov 20, 2017 12:03 am
Micro SD cards don't have a lock switch but the adaptors supplied with them some times do, if the switch is in the unlock position and your SD card is still read only then it has probably failed in some way and has go read only to protect the data contain on it.
If this is the case your only option is to replace it with a new one.
mahjongg
Re: Format SD card
Mon Nov 20, 2017 12:23 am
if the micro controller inside the SD-card senses that the flash memory inside the card is at the end of its life it switches itself to read only to protect the data that is in the flash cells.
The best thing to do is to back the card up, to a new SD-card and continue with new "fresh" flash cells.
KatBates
Re: Format SD card
Mon Nov 20, 2017 10:12 am
I've had this problem a couple of times with a Micro SD card and I thought it was broken and had to be replaced. I didn't know there was a switch on it??? Must be tiny
RaTTuS
Re: Format SD card
Mon Nov 20, 2017 10:17 am
viewtopic.php?f=63&t=198058#p1236791
however to the OP
you may be able to format it in a phone or car dvr,
but it's probably come the the end of life and you need a new one
Covfefe
DidierAubin87
Re: Format SD card
Tue Nov 28, 2017 10:01 am
however to the OP
agree, you need a new one for this situation.
kaksi
Re: Format SD card
Tue Dec 12, 2017 5:52 pm
however to the OP
Not sure, I suspect the controller working this way:
if there is data to write:
  mark the card as write-protected
  write the data
  release the write protection
In case of a power-off before the last step, the card remains write protected.
As it happens quite often to me, I try to avoid to bring it to my dealer and mostly I got it working in a camera, in a navigator... the last one in an Android phone. Unfortunately, no way to find a general rule.
