komarek
unknown problem with node-red (SOLVED)
Thu Nov 16, 2017 3:56 pm
hi guys i have a terrible problem i wonder if you can help
i am running node-red which is handled by this service:
# systemd service file to start Node-RED
[Unit]
Description=Node-RED graphical event wiring tool.
Wants=network.target
Documentation=http://nodered.org/docs/hardware/raspberrypi.html
[Service]
Type=simple
# Run as normal pi user - feel free to change...
User=pi
Group=pi
WorkingDirectory=/home/pi
Nice=5
Environment="NODE_OPTIONS=--max-old-space-size=128"
# uncomment and edit next line if you need an http proxy
#Environment="HTTP_PROXY=my.httpproxy.server.address"
# uncomment the next line for a more verbose log output
#Environment="NODE_RED_OPTIONS=-v"
#ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS
# Use SIGINT to stop
KillSignal=SIGINT
# Auto restart on crash
Restart=on-failure
# Tag things in the log
SyslogIdentifier=Node-RED
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
it used to work like charm
today nothing is working
if i check the status it says this:
● nodered.service - Node-RED graphical event wiring tool.
   Loaded: loaded (/lib/systemd/system/nodered.service; enabled)
   Active: failed (Result: start-limit) since gio 2017-11-16 16:51:53 CET; 3min 51s ago
     Docs: http://nodered.org/docs/hardware/raspberrypi.html
  Process: 16795 ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS (code=exited, status=9)
 Main PID: 16795 (code=exited, status=9)
nov 16 16:51:53 pitre systemd[1]: Unit nodered.service entered failed state.
nov 16 16:51:53 pitre systemd[1]: nodered.service holdoff time over, scheduling restart.
nov 16 16:51:53 pitre systemd[1]: Stopping Node-RED graphical event wiring tool....
nov 16 16:51:53 pitre systemd[1]: Starting Node-RED graphical event wiring tool....
nov 16 16:51:53 pitre systemd[1]: nodered.service start request repeated too quickly, refusing to start.
nov 16 16:51:53 pitre systemd[1]: Failed to start Node-RED graphical event wiring tool..
but if i run manually /usr/bin/node-red-pi
it seems to work good
any help?
thanks
komarek
Re: unknown problem with node-red
Thu Nov 16, 2017 4:25 pm
btw
if i make: node-red-start
i have this:
Once Node-RED has started, point a browser at http://192.168.1.3:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-start                         to start Node-RED again
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
Started Node-RED graphical event wiring tool..
node: --max-old-space-size=128 is not allowed in NODE_OPTIONS
nodered.service: main process exited, code=exited, status=9/n/a
Thu Nov 16, 2017 4:41 pm
Simplify this stuff
To
ExecStart=/usr/bin/env node-red-pi --max-old-space-size=128 -v
This is a doctor free zone.
komarek
found the FIX (SOLVED)
Thu Nov 16, 2017 7:26 pm
Changed the line
to
Environment="NODE_OPTIONS=--max_old_space_size=128"
now working good
