Haris1977
Script needed !
Wed Nov 08, 2017 6:21 am
I ve managed to install an app (moonlight-embedded) on my rpi1 model B, but i want to create a scrip with 3 commands
My software is raspbian and it boots in cmd mode (i ve already downloaded wakeonlan and i m booting in cmd with username pi and password raspberry). The 3 commands of the script must be:
1) wakeonlan XX:XX:XX:XX:XX:XX (my pc mac address)
2) wait 15 seconds and then
3) moonlight stream -app mstsc.exe 192.168.1.109 -1080
all of them when raspbian boots. Can anyone help? I m a linux noob :)
Re: Script needed !
Wed Nov 08, 2017 6:55 am
You could add three lines to /etc/rc.local
The way to wait is with the sleep command.
Haris1977
Re: Script needed !
Wed Nov 08, 2017 7:44 am
Thanks but i do not know much about commands and about the form they should be presented.
From what i ve read could it be smth like this?
sleep 15
RaTTuS
Contact: Twitter YouTube
Re: Script needed !
Wed Nov 08, 2017 8:11 am
edit your .bashrc file
like
nano .basrc
and right at the end
put
if [ $(tty) == /dev/tty1 ]; then
sleep 15
fi
if your rpi is set to autologin as user pi then this will work after a reboot
Covfefe
Re: Script needed !
Wed Nov 08, 2017 11:45 am
sleep 15
You'll want it to have
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
sleep 15
moonlight stream -app mstsc.exe 192.168.1.109 -1080 &
exit 0
Or in RaTTus' version
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
# If not running interactively, don't do anything
case $- in
    *i*) ;;
      *) return;;
esac
# don't put duplicate lines or lines starting with space in the history.
# See bash(1) for more options
HISTCONTROL=ignoreboth
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# If set, the pattern "**" used in a pathname expansion context will
# match all files and zero or more directories and subdirectories.
#shopt -s globstar
# make less more friendly for non-text input files, see lesspipe(1)
#[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
    debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
    xterm-color|*-256color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
    if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
        # We have color support; assume it's compliant with Ecma-48
        # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
        # a case would tend to support setf rather than setaf.)
        color_prompt=yes
    else
        color_prompt=
    fi
fi
if [ "$color_prompt" = yes ]; then
    PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w \$\[\033[00m\] '
else
    PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
    PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
    test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
    alias ls='ls --color=auto'
    #alias dir='dir --color=auto'
    #alias vdir='vdir --color=auto'
    alias grep='grep --color=auto'
    alias fgrep='fgrep --color=auto'
    alias egrep='egrep --color=auto'
fi
# colored GCC warnings and errors
#export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
# some more ls aliases
#alias ll='ls -l'
#alias la='ls -A'
#alias l='ls -CF'
# Alias definitions.
# You may want to put all your additions into a separate file like
# ~/.bash_aliases, instead of adding them here directly.
# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
    . ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
  if [ -f /usr/share/bash-completion/bash_completion ]; then
    . /usr/share/bash-completion/bash_completion
  elif [ -f /etc/bash_completion ]; then
    . /etc/bash_completion
  fi
fi
sleep 15
fi
Because I assume moonlight is a daemon program that doesn't terminate.
Haris1977
Re: Script needed !
Wed Nov 08, 2017 1:19 pm
Thank you guys:) I will test them to see if i am ok with these :)
Haris1977
Re: Script needed !
Thu Nov 09, 2017 9:09 am
Well. I run @DougieLawson's script and it can't be run:
It states:
/bin/sh: 0: Illegal option -
The script is this
#!/bin/sh -e
# rc.local
# value on error.
# bits.
if [ "$_IP" ]; then
fi
wakeonlan XXXXXXXXXXXXXX
sleep 65
exit 0
So is this wrong?
@RaTTuS this only works if you power off and on your pi. If you reboot it gets this error:
send: Network is unreachable at /usr/bin/wakeonlan line 126
Re: Script needed !
Thu Nov 09, 2017 9:30 am
Change it to use /bin/bash rather than /bin/sh -e on the shebang line.
Test it with sudo bash -x /etc/rc.local from a command line or in an LXterminal window.
jadro
Re: Script needed !
Thu Nov 09, 2017 9:35 am
Please please if this is correct user and pass then CHANGE IT!!!
Oracle backend database developer
SmartHome IoT & Microprocessor enthusiast and hobbyist
Haris1977
Re: Script needed !
Thu Nov 09, 2017 9:43 am
It only says this:
pi@raspberrypi:~ $ sudo bash -x /etc/rc.local
++ hostname -I
+ _IP='192.168.1.102 2a02:587:b913:XXXX:XXXX:XXXX:XXXX:XXX '
+ '[' '192.168.1.102 XXXXXXXXXXXX ' ']'
+ printf 'My IP address is %s\n' '192.168.1.102 XXXXXXXXXXXXX '
My IP address is 192.168.1.102 XXXXX
+ exit 0
pi@raspberrypi:~ $
(i just changed the letters and numbers here with XXX)
Re: Script needed !
Thu Nov 09, 2017 9:45 am
Sorry we need to add the new code ahead of the "exit 0" line, that's what comes of writing posts on a mobile phone.
Just delete the "exit 0" line.
jadro
Re: Script needed !
Thu Nov 09, 2017 9:46 am
What this exit 0 represent at all?
Re: Script needed !
Thu Nov 09, 2017 9:47 am
It sets the value returned to the calling shell to zero (which means success).
http://tldp.org/LDP/abs/html/exitcodes.html
jadro
Re: Script needed !
Thu Nov 09, 2017 9:49 am
Great. Thanx.
Haris1977
Re: Script needed !
Thu Nov 09, 2017 9:54 am
Nope, doesnt work either. :cry: I get similar print. :? I get no error but it does nothing. Anyway, the only way i made it to work is by adding those lines at the end of the .bashrc file:
sleep 15
fi
This works :D BUT only if i power off and then on my pi. Any ideas why this is not working upon raspi's reboot?
If i reboot i get this error:
SkyRise
Re: Script needed !
Thu Nov 09, 2017 9:58 am
Sounds like your network is not up when the script is run. Put a sleep before the wake-on-lan stuff...
davidcoton
Re: Script needed !
Thu Nov 09, 2017 10:00 am
Puit a sleep before the wakeonlan line. It seems to be trying to connect before the network is ready on the Pi.
RaTTuS
Re: Script needed !
Thu Nov 09, 2017 10:23 am
or do it properly and make a systermd script for when the network is up .... ;-p [it's slightly m,ore complex]
create a script in your home directory called myscript
nano myscript
#!/bin/bash
sleep 15
make it executable [ha]
chmod 755 myscript
do the systemd stuf
sudo nano /lib/systemd/system/wol.service
[unit]
Description=Auto start my stuf
[service]
ExecStart=/home/pi/myscript
[Install]
WantedBy=multi-user.target
enable it with
sudo systemctl enable wol
run it
sudo systemctl start wol
see it
sudo systemctl status wol
[this is all blind from memory so maybe have typos .....
Covfefe
Haris1977
Re: Script needed !
Thu Nov 09, 2017 10:29 am
Well thanks guys for all your help here :D You helped me a lot. Will check them out!
And one last thing: When the pi initiates the 1st command the screen log is:
Sending magic packet to XXXXXX with 192.168.X.XXX
When the pi initiates the 3rd command the screen log e.g is:
Connecting to 192.XXX.X.XXX
Initializing platform...done
Resolving host name...done
Starting RTSP handshake..done blah blah etc.
Is there any "easy" way to "hide" all those lines (from Sending magic packet to Starting RTSP handshake) from seeing them in the terminal every time i reboot? I mean smth like SILENT BOOT on Raspbian (maybe with a boot splash screen :P :P ).
If not i am fine with it :D I m just curious..
SkyRise
Re: Script needed !
Thu Nov 09, 2017 10:57 am
Standard output can be removed using "command >/dev/null"
To redirect stderr messages as well, use "command > /dev/null 2>&1"
Haris1977
Re: Script needed !
Fri Nov 10, 2017 6:42 am
Thanks but i was thinking smth like this:
https://raspberrypi.stackexchange.com/q ... -in-jessie or
https://www.pi-supply.com/make/disablin ... pberry-pi/
Duno if this will work but i will try
Thank y all! :D
